Meeko 35 Posted October 29, 2023 Posted October 29, 2023 (edited) Hi @Luke, After .deb installation. Emby Theater cant play hevc and transcode error. Why?: No found the ATI driver and Mesa-Loader! here Pic with error: Solution: Your start script (/usr/bin/emby-theater) don't use a Absolute path for ldconfig! here the Pic: I change it to this: and all is working correct. Please fix it for other Users! Best regards Edited October 29, 2023 by Soldize 1
Luke 42234 Posted October 30, 2023 Posted October 30, 2023 Hi, we'll take a look at this. Thanks for reporting. 1
alucryd 318 Posted October 30, 2023 Posted October 30, 2023 It does not use an absolute path to be compatible with all distros out there, unfortunately not every debian-based distro puts ldconfig in /usr/sbin, and the fact that Debian 12 does not put /usr/sbin in PATH is simply beyond me (it's so ridiculous even that there's probably something else going on, you can't not put /usr/sbin in PATH). In any case I will have to make an exception to look in PATH first, then fallback to /usr/sbin/ldconfig. 1
Meeko 35 Posted October 30, 2023 Author Posted October 30, 2023 (edited) Cool....man could also include a "whereis" instead of the exception.... so the distro does not matter Edited October 30, 2023 by Soldize
an333 2 Posted March 4, 2024 Posted March 4, 2024 On 10/29/2023 at 7:34 PM, Soldize said: Hi @Luke, After .deb installation. Emby Theater cant play hevc and transcode error. Why?: No found the ATI driver and Mesa-Loader! here Pic with error: Solution: Your start script (/usr/bin/emby-theater) don't use a Absolute path for ldconfig! here the Pic: I change it to this: and all is working correct. Please fix it for other Users! Best regards Thanks man, that helped me! I'm using MX Linux 23.2 based on Debian 12.5 and after editing, I can finally use the Emby Theater application 1 1
Luke 42234 Posted June 20, 2024 Posted June 20, 2024 Hi, can you please try our new Emby Theater 3.0.21 package? https://emby.media/download Please let us know how this compares. Thanks !
Meeko 35 Posted November 10, 2024 Author Posted November 10, 2024 On 11/8/2024 at 2:20 AM, Luke said: @Meeko @an333 FYI: Big thanks but is closed!
