mrmike13760 0 Posted October 29, 2023 Posted October 29, 2023 I try to enter pin and it says confirmed on computer but tv does nothing
Luke 42237 Posted October 29, 2023 Posted October 29, 2023 Hi there, are you trying to connect to your own Emby Server, or someone else's?
mrmike13760 0 Posted October 29, 2023 Author Posted October 29, 2023 its mine i ve had an account for years now and accidentally logged out of connect when i try to renenter the pins they just stay on that screen on my devices, pin says recognized when i entered it on the website\
mrmike13760 0 Posted October 29, 2023 Author Posted October 29, 2023 its driving me crazy because ive never had this issue before, and honestly i remember getting much easier support
ebr 16332 Posted October 29, 2023 Posted October 29, 2023 Hi. Did you press the "Next" button after confirming the PIN?
mrmike13760 0 Posted October 30, 2023 Author Posted October 30, 2023 Yes I did , however normally I haven't had to do that. It usually kicked right on...
ebr 16332 Posted October 30, 2023 Posted October 30, 2023 2 hours ago, mrmike13760 said: Yes I did , however normally I haven't had to do that. It usually kicked right on... Did it work when you did that?
