sapycola 4 Posted October 29, 2023 Posted October 29, 2023 the plugin cinema intros not work on fire tv.
GrimReaper 4898 Posted October 29, 2023 Posted October 29, 2023 Which server version? Which client app version? Have you configured/enabled Cinema Intros both server-side and client-side? Internet or local trailers?
sapycola 4 Posted October 29, 2023 Author Posted October 29, 2023 Hi, Version on server: 4.7.14.0 Fire's Tv: 2.0.93a The ciname intro is enabled and files is local (duration time video 00:06 seconds). only server side. On Tv Android, Samsung and LG work fine.
Luke 42244 Posted October 29, 2023 Posted October 29, 2023 Why exactly do you think it doesn't work? How to Report a Problem
ebr 16337 Posted October 29, 2023 Posted October 29, 2023 Hi. Did you ensure the option was enabled in the Fire app?
sapycola 4 Posted October 29, 2023 Author Posted October 29, 2023 mmmm on fire app i dont know... but it's not possible to enable only on server side! On LG, Samsung other vendor... only by server-side
GrimReaper 4898 Posted October 29, 2023 Posted October 29, 2023 2 hours ago, sapycola said: mmmm on fire app i dont know... 11 hours ago, GrimReaper said: Have you configured/enabled Cinema Intros both server-side and client-side?
sapycola 4 Posted October 29, 2023 Author Posted October 29, 2023 (edited) mmm not work on last fire tv? mmmm Edited October 29, 2023 by sapycola
Luke 42244 Posted October 30, 2023 Posted October 30, 2023 What didn't get cinema intros that you expected to?
sapycola 4 Posted October 30, 2023 Author Posted October 30, 2023 1 hour ago, Luke said: What didn't get cinema intros that you expected to? I sent my file privatly on message.
ebr 16337 Posted October 30, 2023 Posted October 30, 2023 22 hours ago, sapycola said: on fire app i dont know There is a setting in the app as well. Please be sure that is enabled.
