MikazukiFubuki 1 Posted October 28, 2023 Posted October 28, 2023 Fafner in the Azure: Dead Aggressor, Fafner Exodus, and Soukyuu no Fafner: Dead Aggressor - The Beyond only show up as one animation in the emby, how can them be three animations like in THE MOVIE DB. I've used different folder names and put them in different places, but still merged them together.No matter what I do with the recognition function, it only shows one animation.
MikazukiFubuki 1 Posted October 28, 2023 Author Posted October 28, 2023 Three animations uploaded separately to the media library can be recognised individually, but when all three are in the media library at the same time, only one will be shown.
GrimReaper 4845 Posted October 28, 2023 Posted October 28, 2023 How are your files named and organized?
GrimReaper 4845 Posted October 28, 2023 Posted October 28, 2023 And what are your library meta-providers enabled and in what order?
Solution GrimReaper 4845 Posted October 28, 2023 Solution Posted October 28, 2023 (edited) Ok, remove all three series from TV shows root. Scan media library to clear db. For DEAD AGGRESSOR: 1) Move those S00Exx episodes out of Season 1 folder to Season 0 folder 2) Rename series folder to: 蒼穹のファフナー Dead Aggressor (2004) [tmdbid=42836] For EXODUS: 1) Rename series folder to: 蒼穹のファフナー EXODUS (2015) [tmdbid=25891] For THE BEYOND 1) No screenshot of Season 1 folder contents but if any Specials within, follow 1) from DEAD AGGRESSOR 2) Rename series folder to: 蒼穹のファフナー THE BEYOND (2019) [tmdbid=95336] Delete any existing NFOs present in either series/season folder, if any. Move all three series folders back under TV shows root. Scan media library. Edited October 28, 2023 by GrimReaper 1 1
Neminem 1594 Posted October 28, 2023 Posted October 28, 2023 Its aways good to help emby sort identification. By adding (year) [tmdbid=xxxxx] or [TvdbId=xxxxx] to series foldername, depending on your metadata provider. and for movies (year) {TmdbId=xxxx} 1
