Mortified 11 Posted October 27, 2023 Posted October 27, 2023 Hello everyone, I've been unable to find this information anywhere, but is there a way to reset certain settings to their default configuration without the need for a complete reinstallation? For example, the home screen, cinema intro, etc. Thanks in advance
Mortified 11 Posted October 27, 2023 Author Posted October 27, 2023 1 hour ago, GrimReaper said: Create new User? Okay, I understand, there are no specific tricks to perform a default reset of the settings. The issue with creating a new user is that I would lose the entire media viewing history. Does anyone have another solution ?
Solution Neminem 1594 Posted October 27, 2023 Solution Posted October 27, 2023 Yes create an new user, and then compare settings. Then delete the new user 1
GrimReaper 4845 Posted October 27, 2023 Posted October 27, 2023 1 hour ago, Mortified said: The issue with creating a new user is that I would lose the entire media viewing history Use Backup & Restore plugin to restore your userdata. Quote Use the Server Configuration Backup Plugin We recommend using the Server Configuration Backup plugin, which is designed to make this process really painless by doing the work for you. This plugin requires Emby Premiere and can be found in our plugin catalog. The Server Configuration Backup plugin can help you backup and restore the following: Server configuration Users User data (play-states, favorites, etc). Installed plugins Plugin settings Playlists https://emby.media/support/articles/Backup.html 1
