rsaxman 0 Posted October 27, 2023 Posted October 27, 2023 I can connect from all apps (iOS, theater, Roku) but the web app simply won't connect. I get an error to make sure that the server is running. I've even deleted my virus protection entirely just to see if that was somehow it. What's weird is that if I go to the IP address directly then I can get in, but if I log into app.emby.media then I get an error message Any thoughts?
GrimReaper 4845 Posted October 27, 2023 Posted October 27, 2023 3 hours ago, rsaxman said: I go to the IP address directly then I can get in, but if I log into app.emby.media then I get an error message Your browser is likely force redirecting to https with your server not having SSL setup, make sure your browser address bar states http://app.emby.media, not https://app.emby.media (you might need to manually drop "s" from "https").
pwhodges 2023 Posted October 27, 2023 Posted October 27, 2023 7 hours ago, rsaxman said: Any thoughts? You're using Chrome, I guess, and connecting via app.emby.media. Lots of topics on this over the past week since Chrome's behaviour became more aggressive - trying to force https when its not appropriate. Paul
Richard Branches 332 Posted October 28, 2023 Posted October 28, 2023 So what should I do to use Chrome?
Luke 42185 Posted October 28, 2023 Posted October 28, 2023 1 hour ago, Richard Branches said: So what should I do to use Chrome? Choose between these options: Setup https for your emby server Make sure to use the http version of the hosted web app - http://app.emby.media . Chrome is aggressively redirecting so you may have to manually correct it a few times but it does seem to eventually remember and stop doing that. Use the web app built into your emby server via your ip address
Richard Branches 332 Posted October 28, 2023 Posted October 28, 2023 9 hours ago, Luke said: Setup https for your emby server How do I do this? By the way, why I can't open the server by using localhost:8096 from my phone while connected to the same LAN?
ebr 16307 Posted October 28, 2023 Posted October 28, 2023 19 minutes ago, Richard Branches said: why I can't open the server by using localhost:8096 from my phone Hi. Because "localhost" is a shortcut for the machine the browser is on and the server is not on your phone.
Richard Branches 332 Posted October 28, 2023 Posted October 28, 2023 I imagined that... 48 minutes ago, Richard Branches said: Setup https for your emby server How do I do this?
Richard Branches 332 Posted October 28, 2023 Posted October 28, 2023 (edited) I was able to access the server locally from my phone using my local IP address: 192.168.101.XXX:8096 And I was able to access the server remotely by using the external IP address: XXX.XXX.XXX.XXX:8096 All this without using the app.emby.media address, however, I'm trying to use a host setup at noip.com but it's a little hard to make it work, I already setup the router with it but still not success. Edited October 28, 2023 by Richard Branches
Luke 42185 Posted October 30, 2023 Posted October 30, 2023 On 10/28/2023 at 11:50 AM, Richard Branches said: I imagined that... How do I do this? There are many ways you could do this, but here is one: 1
Luke 42185 Posted October 30, 2023 Posted October 30, 2023 Quote I was able to access the server locally from my phone using my local IP address: 192.168.101.XXX:8096 And I was able to access the server remotely by using the external IP address: XXX.XXX.XXX.XXX:8096 Right, the convenience of app.emby.media is that it's one url for the browser that never changes. When you connect directly to your server, you may have to change the url in the browser depending on where you're connecting from. 1
