neoccccc 0 Posted October 25, 2023 Posted October 25, 2023 Hello all, I've tried to access my emby library using remote access. I've set the port forwarding in my router, disconnected from my wifi and use celluar connections. I was able to connect to my home emby library using remote access ip address + port(8096). I was able to load the library and see all the contents, meta info etc, everything seems work just fine via remote access. However I was not able to play any videos, it just stuck after I click the play button. My internet has 500 Mbps download and 20 Mbps upload, so the connection speed shouldn't be an issue here as well. Any idea what's stopping videos from playing? embyserver.txt
Abobader 3485 Posted October 25, 2023 Posted October 25, 2023 Hello neoccccc, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42185 Posted October 26, 2023 Posted October 26, 2023 Hi, do you get an error message? Are you using a reverse proxy?
