enqbcvqw 3 Posted October 25, 2023 Posted October 25, 2023 Hello, I had a very large m3u playlist with an even larger epg that was causing very bad performance issues on emby while it was being refreshed. I'm trying to trim that down so I removed both the guide and the playlist. After doing that, I'm seeing a lot of these messages in the log: Quote Info SqliteItemRepository: Deleting directory /config/metadata/livetv/188f34ff7b5f025afe2b9ff2fd055a9b/metadata It's taking a very long time to remove all those items. If I look at the config path, there are over 30,000 items waiting to be deleted. Quote $ find /opt/emby/metadata/livetv/ | wc -l 31160 Is there any way to speed that up? Performance is quite bad while this is happening, with content failing to load and lots of buffering when it does. Thanks
Luke 42242 Posted October 25, 2023 Posted October 25, 2023 HI, yes, we are continuing to work on improving it. Thanks for the feedback.
enqbcvqw 3 Posted October 25, 2023 Author Posted October 25, 2023 So no way to speed it up or bulk delete them from the DB directly?
Luke 42242 Posted October 25, 2023 Posted October 25, 2023 Hi there, yes we are looking into improving it. Thanks.
Chillout 111 Posted October 27, 2023 Posted October 27, 2023 A work-around many of us are using is a 3rd party tool to organize the channel and epg listing so Emby only brings in only channels you want, greatly reducing the size and improving speed of managing channels within the Emby. One such popular program is https://iptvboss.pro/ . The free version lets you configure up to two different providers.
