lrypower 1 Posted October 25, 2023 Posted October 25, 2023 EmbyServer runs well yestoday, but now I open the computer ,Localhost refused connection, I check the log, it shows SocketException(10013) error report , EmbyServer Version4.7.14.0 . I do nothing to change my computer, just open and shutdown. How to fix it ?
Abobader 3485 Posted October 25, 2023 Posted October 25, 2023 Hello lrypower, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42185 Posted October 25, 2023 Posted October 25, 2023 Hi, is the Emby Server application running? Please attach the emby server log: Emby Server Data Folder Thanks.
lrypower 1 Posted October 26, 2023 Author Posted October 26, 2023 6 hours ago, Luke said: Hi, is the Emby Server application running? Please attach the emby server log: Emby Server Data Folder Thanks. Thanks, I resoved by myself, I google error code 10013, the reason of localhost refused is the port has being occupied by microsoft. Use command net stop winnat and then net start winnat can solve this problem. 1
