AltairGPL 2 Posted October 22, 2023 Posted October 22, 2023 Im very new to emby and I'm trying to make the hardware acceleration work (possibly always), without which most of my library buffers a lot in a way its unwatchable. When I enable hardware acceleration, nvidia gpu is not used even if I select it explicitly. I made sure my nvidia drivers are upto date. Im on Ubuntu 22.04.3. Mon Oct 23 01:51:42 2023 +---------------------------------------------------------------------------------------+ | NVIDIA-SMI 535.113.01 Driver Version: 535.113.01 CUDA Version: 12.2 | |-----------------------------------------+----------------------+----------------------+ | GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |=========================================+======================+======================| | 0 NVIDIA GeForce GTX 1050 Off | 00000000:01:00.0 Off | N/A | | N/A 44C P3 N/A / ERR! | 271MiB / 4096MiB | 4% Default | | | | N/A | +-----------------------------------------+----------------------+----------------------+ I have tried enabling only nvidia options and also with the others. I did restart the emby server everytime I changed the settings, I even did restarted the system every time I changed settings in the end. I tried it with the CUVID option as well. Even with this selected, the decoder being used was VAAPI, Here is the video details Am I missing something or doing something wrong? Let me know if more info is needed.
AltairGPL 2 Posted October 22, 2023 Author Posted October 22, 2023 (edited) Here is a log I tried with enabling only NVDEC options. ffmpeg-transcode-6e44d3d1-00a9-42ae-ba6a-02ebf56bb23e_1.txt Edited October 22, 2023 by AltairGPL
softworkz 5133 Posted November 1, 2023 Posted November 1, 2023 Lets try to narrow this down: Try playing the same file without subtitle selection (and post the ffmpeg log) Try playing a different file which is not an HDR file Thanks!
Solution AltairGPL 2 Posted November 13, 2023 Author Solution Posted November 13, 2023 Hey, I decided to install Emby beta in the mean time and it worked! Im on the latest beta version and haven't faced the issue anymore. I tried to go back to main version thinking if the fix is just because of a re-install but I was unable to do say, the server wouldn't start, due to some major config changes may be I guess. But I think its the re-install that fixed it 1 1
