Chusof 0 Posted October 22, 2023 Posted October 22, 2023 (edited) Estoy teniendo problemas para poder reproducir ciertos contenidos de alto bitrate tanto en local como en remoto, tengo una conexion mas que de sobra pero al intentar reproducir algunas peliculas la pantalla se queda en negro solo funcionando el audio. en otros servidores multimedia no tengo este problema. no se que puede ser lo que este pasando. tengo pagado emby premiere. adjunto registro para poder mostrar que pasa. ffmpeg-transcode-617367d5-1ae9-4a01-9063-8829f4dc6e08_1.txt Edited October 22, 2023 by Chusof
Chusof 0 Posted October 22, 2023 Author Posted October 22, 2023 (edited) . Edited October 22, 2023 by Chusof
Luke 42240 Posted October 23, 2023 Posted October 23, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Chusof 0 Posted October 23, 2023 Author Posted October 23, 2023 12 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Black screen...
Chusof 0 Posted October 24, 2023 Author Posted October 24, 2023 (edited) On 10/23/2023 at 3:53 AM, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. On 10/23/2023 at 3:53 AM, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Black screen... He intalado la app del sitio que me indicas y aun asi no ha funcionado como puedes ver en la foto se queda la pantalla en negro. No me pasa ni con jellyfin ni con plex Edited October 24, 2023 by Chusof
Clangrijan 19 Posted October 24, 2023 Posted October 24, 2023 21 hours ago, Chusof said: Black screen... Has probado cambiando la opción de calidad de internet al máximo? eso está en opciones > reproducción > Video. Eso desde el cliente desde donde reproduces la peli. Saludos!
Chusof 0 Posted October 24, 2023 Author Posted October 24, 2023 Si eso esta puesto al maximo tanto en local como para remoto 1 hour ago, Clangrijan said: Has probado cambiando la opción de calidad de internet al máximo? eso está en opciones > reproducción > Video. Eso desde el cliente desde donde reproduces la peli. Saludos! Si eso esta puesto a 160 mb/s en los 2 campos
vdatanet 1619 Posted October 24, 2023 Posted October 24, 2023 Transcodifica por error de reproducción, no por calidad seleccionada. Deberías enviar los logs desde la aplicación para que @ebrpueda identificar el error.
Chusof 0 Posted October 24, 2023 Author Posted October 24, 2023 15 minutes ago, vdatanet said: Transcodifica por error de reproducción, no por calidad seleccionada. Deberías enviar los logs desde la aplicación para que@ebrpueda identificar el error. no es el archivo que mande en el primer mensaje?
vdatanet 1619 Posted October 24, 2023 Posted October 24, 2023 1 minute ago, Chusof said: no es el archivo que mande en el primer mensaje? No, desde la aplicación de Android TV.
Chusof 0 Posted October 24, 2023 Author Posted October 24, 2023 (edited) 28 minutes ago, vdatanet said: No, desde la aplicación de Android TV. Vale ya lo he enviado creo que lo he enviado adecuadamente. registro enviado a las 18:00h española, nombre de usuario chusof, reporduciendo varios archivos remux mkv @ebr Edited October 24, 2023 by Chusof
Chusof 0 Posted October 24, 2023 Author Posted October 24, 2023 Tambien he provado en un firestick 4k max en conexion local y me pasa exactamente lo mismo por si sirve de ayuda
Clangrijan 19 Posted October 25, 2023 Posted October 25, 2023 A lo mejor digo una tontería pero podrías probar quitando los subtítulos? Es decir con el MKVToolnix eliminar los subtítulos y probar a reproducir la pista sin ellos.
Chusof 0 Posted October 26, 2023 Author Posted October 26, 2023 20 hours ago, Clangrijan said: A lo mejor digo una tontería pero podrías probar quitando los subtítulos? Es decir con el MKVToolnix eliminar los subtítulos y probar a reproducir la pista sin ellos. No no eso esta todo correctamente ya te digo que solo me pasa con ciertas películas pero con el addon emby de kofi me funcioka sin problema
Clangrijan 19 Posted October 26, 2023 Posted October 26, 2023 3 hours ago, Chusof said: No no eso esta todo correctamente ya te digo que solo me pasa con ciertas películas pero con el addon emby de kofi me funcioka sin problema Lo decía porque me sonaba que algunas películas con algunos subtítulos daba problemas, por eso decía de probar. Kodi se lo come todo da igual lo que le eches jeje
Chusof 0 Posted October 27, 2023 Author Posted October 27, 2023 16 hours ago, Clangrijan said: Lo decía porque me sonaba que algunas películas con algunos subtítulos daba problemas, por eso decía de probar. Kodi se lo come todo da igual lo que le eches jeje A ver si se pronuncia @ebry me dice algo del registro enviado. Aunque realmente me resulta raro que una opcion como jellyfin sea capaz de hacerlo y emby en su versión premiere no pueda. Realmente es extraño
ebr 16334 Posted October 28, 2023 Posted October 28, 2023 On 10/24/2023 at 11:59 AM, Chusof said: Okay, I've already sent it, I think I've sent it properly. record sent at 18:00 Spanish, username chusof, playing several remux mkv files@ebr Hi. There was no playback in this log. Can you please send the log right after the problem occurs? Thanks.
Chusof 0 Posted October 29, 2023 Author Posted October 29, 2023 17 hours ago, ebr said: Hi. There was no playback in this log. Can you please send the log right after the problem occurs? Thanks. Hi i send new log 9:15h name chusof
Chusof 0 Posted October 29, 2023 Author Posted October 29, 2023 He enviado varios registros con la velocidad de btirate al maximo para evitar transcoding
ebr 16334 Posted October 29, 2023 Posted October 29, 2023 How was this video created? It isn't supported natively on the device but we are trying to use ffmpeg to decode it and, I guess, that is failing as well.
Chusof 0 Posted October 29, 2023 Author Posted October 29, 2023 Son varias remasterizaciones realmente no se como estan creadas, yo no soy em creador de los videos. No hay ninguna forma para poder reproducirlo?
Luke 42240 Posted October 30, 2023 Posted October 30, 2023 Can you provide a sample video for testing? Thanks.
Chusof 0 Posted November 3, 2023 Author Posted November 3, 2023 1 minute ago, Luke said: @Chusof? Perdona por no contestar he tenido poco tiempo, no se como podria enviar un archivo de minimo 90gb
Luke 42240 Posted November 3, 2023 Posted November 3, 2023 57 minutes ago, Chusof said: Perdona por no contestar he tenido poco tiempo, no se como podria enviar un archivo de minimo 90gb Dropbox or google drive would be a great place for a sample file. You can just slice a small sample of the file. Thanks !
