voodoo5_6k 29 Posted October 22, 2023 Posted October 22, 2023 Hi there, I've been running emby on TrueNAS SCALE (22.12.4.2) for a while now, and on a Dune HD Pro Vision 4K Solo as a client (Android TV application, with the Dune's internal player as external player for emby). Now, I wanted to set up hardware assisted transcoding within emby. However, I don't get it to work. The integrated GPU of my Xeon is available for resource reservation (see screenshot), but within emby, hardware detection fails (see logs) and under Transcoding, nothing is shown when selecting Advanced (see screenshot). I've read that the required intel driver is included with emby. But obviously, I seem to be missing something. Maybe someone running this under TrueNAS SCALE knows what in regard to additional configuration is required. Thanks in advance! PS: This is more out of curiosity and because the hardware and my emby Premiere allows me to do it- I currently don't need it. But still I'd like to get it working. embyserver.txt hardware_detection-63833588101.txt
voodoo5_6k 29 Posted October 24, 2023 Author Posted October 24, 2023 Hi, I'm currently running (4.7.14.0_1.0.29) on TrueNAS SCALE 22.12.4.2 and somehow, the integrated GPU cannot be opened by emby, although it is available for selection in the TrueNAS config (so, BIOS settings etc.pp. should be fine). I also added gidlist=44,107 for groups video and render, but no dice. I had also tested with user bin being a member of groups video & render, but again, to no avail. Has anybody seen this recently? PS: I had created a separate thread because I hadn't found this one. My bad, sorry. PPS: Could this thread be "pinned" for easier access? embyserver.txt hardware_detection-63833725082.txt
voodoo5_6k 29 Posted October 24, 2023 Author Posted October 24, 2023 Just found the TrueNAS SCALE thread and posted the question/issue there. This here could be closed, I guess. But maybe the TrueNAS SCALE thread should be "pinned"?
El_Cookie 7 Posted October 24, 2023 Posted October 24, 2023 Hello, Where is the TrueNAS SCALE thread ? I also use TrueNAS with PNY NVIDIA T400 4GB.
voodoo5_6k 29 Posted October 24, 2023 Author Posted October 24, 2023 Currently, three rows below this thread
GrimReaper 4898 Posted October 24, 2023 Posted October 24, 2023 Linked topic pinned for easier navigation. 1
Solution voodoo5_6k 29 Posted October 25, 2023 Author Solution Posted October 25, 2023 Found the issue and got it working... 1
