Liranics 1 Posted October 21, 2023 Posted October 21, 2023 I'm connected to my server remotely only through the WAN. Use via IP4 works great without problems. I think EMBY using IPV6 address in lan causes me a problem accessing MetaData and subtitle sites. Is there a way to force emby to use an internal IPV4 address? reaolving issue forces me to add IP address and DNS addresses under the hosts file
Luke 42242 Posted November 2, 2023 Posted November 2, 2023 Quote I think EMBY using IPV6 address in lan causes me a problem accessing MetaData and subtitle sites. Hi, how did you determine this? Can we please see an example? How to Report a Problem Thanks.
