Daniel8192 6 Posted October 20, 2023 Posted October 20, 2023 (edited) Hey, I'm back again, was trying out Emby in August and ran out of time. I am now been running Emby since October 6 and having good success with on disk TV shows, Movies, and Live TV via m3u and XMLTvlisting and will buy a lifetime pass shortly, but am having trouble introducing a HDHomeRun - figured that was easier than using TVHeadend and my USB tuners. Environ: Raspberry 4B/8. Debian 64 bit. All up to date, Docker/docker-compose. I tried adding a working HDHomerun with a reserved IP to Emby. The auto-detect didn't work, but I wasn't surprised as Emby is not on the lan subnet, but behind docker and gluetun. But when I tried providing the IP address it just errored on trying to add. I figure it is the gluetun network stack. Gluetun knows what is local to the LAN and what should go out the VPN, but needs to be told of ports being used by dependant containers. I listed 8096 and 8920 for Emby, and that works fine.. Occasionally a Firestick Emby app gets confused and can't see the server after a Firestick restart, but a retry fixes that. I think I read that Emby is using udp to communicate with HDHomeRuns. I believe I would need to list the UDP port numbers in gluetun's configuration and rely on gluetun to deliver incoming dup back to the Emby container. I tried adding ports: - 65001:65001/udp to gluetun, but still no joy. Who can help a guy out? Docker Compose environ. Running Emby using gluetun's network providing me with a VPN tunnel through Nord. docker-compose.yml version: '2.0' services: // other containers snipped // qbittorrent, radarr, sonarr, jackett, apcupsd gluetun: image: qmcgaw/gluetun container_name: gluetun cap_add: - NET_ADMIN environment: - VPN_SERVICE_PROVIDER=nordvpn - VPN_TYPE=openvpn # or wireguard - OPENVPN_USER=<<secret>> - OPENVPN_PASSWORD=<<secret>> - SERVER_COUNTRIES=Canada ports: - 8096:8096 - 8920:8920 emby: #image: emby/embyserver:beta image: emby/embyserver_arm64v8 container_name: emby #network_mode: host network_mode: "service:gluetun" environment: - PUID=1000 - PGID=1000 - TZ=America/Toronto volumes: - /mnt/emby:/config - /mnt/television:/data/tvshows - /mnt/movies:/data/movies # - /opt/vc/lib:/opt/vc/lib #ports: # - 8096:8096 # - 8920:8920 restart: unless-stopped Edited October 20, 2023 by Daniel8192
Daniel8192 6 Posted October 20, 2023 Author Posted October 20, 2023 (edited) Update to this - I tried running the Emby container as host network, scanned for and found the HDHomerun, added it, and my 42 OTA channels and was able to watch. Then set the Emby container back to gluetun network, added ports 8096TCP, 8920TCP and 65001UDP to gluetun, but sadly, no. Could not watch any live channels, Emby reporting that it can't reach the channel. I was hoping that with the config written with the IP address of the HDHomerun that Emby would just work. but no, somewhere in the distance a sad tuba played. --- Update #2 Tried adding all HDHomeRun ports I could find: Still nada. ports: - 8096:8096 - 8920:8920 - 65001:65001/udp - 5000:5000/udp - 5002:5002/udp - 5004:5004/udp Edited October 20, 2023 by Daniel8192
Daniel8192 6 Posted October 21, 2023 Author Posted October 21, 2023 Amy there there was the Homerun may be sending back on the same port numbers to Emby for UDP, maybe Gluetun needed that do surface the listening container? But in any event, that didn't work. When not using the gluetun stack, Emby connects to the Homerun on tcp port 5004 using some random high number port, but that should absolutely work regard of port directives to Docker, as those are for reserve listening ports form the host machine stack. Makes no sense. This should just work. Now I did find that Emby was listening on UDP port 1900 and 7359, and also two others that were rurally just changing. So added the 1900 and 7359 to Gutun and tried. No. I guess I'll have to add a sniffer into the equation to figure out what is happening.
Solution Daniel8192 6 Posted October 21, 2023 Author Solution Posted October 21, 2023 Okay, I think I have success.. I gave gluetun host mode, which is really the "I have no idea what ports I need to open, or they are changing randomly, so give gluetun free reign of the stack" Mode. From the embryo container the VPN is still working, My public IP at the moment is 69.X.X.X and if I open a shell on the embryo container and run wget -qO- http://ipecho.net/plain | xargs echo, I am getting back a 86.x.x.x So.. Solved, just not the way I'd like, but really fine. gluetun: image: qmcgaw/gluetun container_name: gluetun cap_add: - NET_ADMIN network_mode: host environment: - VPN_SERVICE_PROVIDER=nordvpn - VPN_TYPE=openvpn # or wireguard - OPENVPN_USER=<<secret>> - OPENVPN_PASSWORD=<<secret>> - SERVER_COUNTRIES=Canada #ports: # - 8096:8096 # - 8920:8920 # - 65001:65001/udp # - 65001:65001/tcp # - 5000:5000/udp # - 5002:5002/udp # - 5004:5004/udp # - 1900:1900/udp # - 7359:7359/udp 1
Luke 42243 Posted October 30, 2023 Posted October 30, 2023 Sounds like a very complex setup. Glad to hear you got it working.
vdrover 62 Posted May 9, 2024 Posted May 9, 2024 @Daniel8192Are you using a reverse proxy in this setup? Would love a peak at your full compose file. Any issues accessing Emby outside your local network?
Daniel8192 6 Posted May 9, 2024 Author Posted May 9, 2024 Give me a few minutes and I'll see what I can put together for you. For outside, I have strict rules on my network for outside access, and they would not allow direct port forwarding to Emby, but that should work fine, instead I have another RPI that runs WireGuard VPN. If I wish to connect to Emby from my cell when out and about, I connect to my VPN first. If you wanted direct access, then you would wish to harden this installation, and likely put on its own VLAN. But I know many people just go ahead and open that up.
Daniel8192 6 Posted May 9, 2024 Author Posted May 9, 2024 Here, my kimono is open! I am sharing this full compose file with the hopes that it helps others, and that others can point out where I am misguided. It was a bit painful getting this all working, but I benefitted greatly from others. Some details on the host file struct is below as well. version: '2.0' # Yes, version is obsolete now. But.. services: # Full config here, no files # runs as root gluetun: image: qmcgaw/gluetun container_name: gluetun cap_add: - NET_ADMIN network_mode: host environment: - VPN_SERVICE_PROVIDER=nordvpn - VPN_TYPE=openvpn # or wireguard - OPENVPN_USER=USER_REDACTED - OPENVPN_PASSWORD=PASSWORD_REDACTED - SERVER_COUNTRIES=Canada restart: unless-stopped # I have a APC UPS connected via USB # this machine monitors it and can shutdown # all of my RPIs and then this one on # critical battery # This is a custom image as I had some trouble with the vendor supplied one. # # runs as root, reads configs and scripts, does not write. apcupsd: image: 1000-apcupsd-wth-wget-ssh devices: - /dev/usb/hiddev0 network_mode: "host" environment: - UPSNAME=NAME_REDACTED - UPSCABLE=usb - UPSTYPE=usb - DEVICE=/dev/usb/hiddev0 - TZ=America/Toronto volumes: - /mnt/apcupsd/etc:/etc/apcupsd - /mnt/apcupsd/ssh:/root/.ssh restart: unless-stopped # qbittorrent uses socks5 proxy server connection # to NordVPN. Tried also using the gluetun but # the sun went down on my efforts - trouble with # tracker files # runs as first RPI user, not root qbittorrent: image: lscr.io/linuxserver/qbittorrent:latest container_name: qbittorrent environment: - PUID=1000 - PGID=1000 - TZ=Etc/UTC - WEBUI_PORT=8080 volumes: - /mnt/torrent/config:/config - /mnt/torrent/downloads:/downloads network_mode: host restart: unless-stopped # Yes, all this stuff runs as root network rather # than opening the ports on a docker buit network # too much fiddle fucking, not enough time/ # but will address sometime. # runs as first RPI user, not root radarr: image: lscr.io/linuxserver/radarr:latest container_name: radarr environment: - PUID=1000 - PGID=1000 - TZ=Etc/UTC volumes: - /mnt/radarr/config:/config - /mnt/radarr/movies:/movies - /mnt/torrent/downloads:/downloads network_mode: host restart: unless-stopped # Running out of comments to make # runs as first RPI user, not root sonarr: image: lscr.io/linuxserver/sonarr:latest container_name: sonarr environment: - PUID=1000 - PGID=1000 - TZ=Etc/UTC volumes: - /mnt/sonarr/config:/config - /mnt/sonarr/television:/tv - /mnt/torrent/downloads:/downloads network_mode: host restart: unless-stopped # the fall lines are looking groovy # runs as first RPI user, not root jackett: image: lscr.io/linuxserver/jackett:latest container_name: jackett environment: - PUID=1000 - PGID=1000 - TZ=Etc/UTC - AUTO_UPDATE=true - RUN_OPTS= # volumes: - /mnt/jackett/config:/config - /mnt/jackett/blackhole:/downloads network_mode: host restart: unless-stopped # Yeah, here we go, Emby using gluetun # runs as first RPI user, not root emby: #image: emby/embyserver:beta image: emby/embyserver_arm64v8 container_name: emby network_mode: "service:gluetun" environment: - UID=1000 - GID=1000 - TZ=America/Toronto volumes: - /mnt/emby:/config - /mnt/media/television:/data/tvshows - /mnt/media/movies:/data/movies restart: unless-stopped Host file struct: The docker-compose.yml sits in user 1000's home directory. As does a "build" file with instructions of how to build the machine, which has very little customization other than installing docker/ docker-compose. User 1000 has been added to the docker group All container data is in /mnt The backup of this machine is performed by user 1000 and it makes copies of its home folder (2 files and .ssh folder) and the /mnt folder. I just realized that my local Emby recordings (I don't do a lot) are being placed in /mnt/emby/data/livetv/. I should make a data folder in my /mnt/media tree for livetv and make a softlink from the embryo folder into it. Maybe tomorrow yes, mnt is owned by root sudo mkdir /mnt/other dirs sudo chown 1000:1000 /mnt/other dirs drwxr-xr-x 16 0 0 4096 Apr 23 12:35 mnt drwxr-xr-x 4 1000 1000 4096 Apr 24 15:36 apcupsd drwxr-xr-x 2 1000 1000 4096 May 6 06:53 etc drwxr-xr-x 2 1000 1000 4096 Apr 25 09:29 ssh drwxr-xr-x 11 1000 1000 4096 Apr 22 13:07 emby drwxr-xr-x 14 1000 1000 4096 Apr 22 10:49 cache drwxr-xr-x 3 1000 1000 4096 Oct 6 2023 config drwxr-xr-x 4 1000 1000 4096 Apr 26 09:35 data drwxr-xr-x 2 1000 1000 40960 May 9 04:13 logs drwxr-xr-x 9 1000 1000 4096 Oct 9 2023 metadata drwxr-xr-x 3 1000 1000 4096 Apr 22 11:06 plugins drwxr-xr-x 3 1000 1000 4096 Oct 6 2023 root drwxr-xr-x 3 1000 1000 4096 Apr 22 11:50 sync drwxr-xr-x 14 1000 1000 4096 May 9 04:13 transcoding-temp drwxr-xr-x 4 1000 1000 4096 Sep 12 2023 jackett drwxrwxrwx 2 1000 1000 4096 Jul 30 2023 blackhole drwxrwxrwx 3 1000 1000 4096 Jul 30 2023 config drwxr-xr-x 5 1000 1000 4096 Apr 23 12:46 media drwxrwxrwx 85 1000 1000 12288 Apr 23 13:06 downloads drwxr-xr-x 123 1000 1000 12288 Apr 23 10:32 movies drwxr-xr-x 11 1000 1000 4096 Apr 22 09:54 television drwxr-xr-x 3 1000 1000 4096 Apr 23 12:35 radarr drwxrwxrwx 6 1000 1000 4096 May 9 08:28 config lrwxrwxrwx 1 1000 1000 15 Apr 23 12:35 movies -> ../media/movies drwxr-xr-x 3 1000 1000 4096 Apr 23 12:36 sonarr drwxr-xr-x 8 1000 1000 4096 May 9 08:40 config lrwxrwxrwx 1 1000 1000 19 Apr 23 12:36 television -> ../media/television drwxr-xr-x 3 1000 1000 4096 Apr 23 12:46 torrent drwxrwxrwx 4 1000 1000 4096 Jul 29 2023 config lrwxrwxrwx 1 1000 1000 20 Apr 23 12:46 downloads -> /mnt/media/downloads
vdrover 62 Posted July 7, 2024 Posted July 7, 2024 (edited) @Daniel8192Sorry for the delay here, but from my research, the HD Homerun can only be accessed from Emby when they are on the same network. This is by design so folks can't easily stream/re-steam OTA channels over the internet. Since you have Emby running through Gluetun, it is no longer on the same subnet as the Homerun, and can't be added. Personally, I don't use Gluetun for Emby. Are you sure you need Emby behind Gluetun if you're only using OTA channels? You've got qBittorrent on a VPN, that's probably all you need (if I am reading the intent of your compose file correctly). Edited July 7, 2024 by vdrover
Daniel8192 6 Posted July 7, 2024 Author Posted July 7, 2024 Hey @vdrover, I have both my OTA channels through my HDHomeRun and also have a stack of streaming channels so I am running Emby through gluetun. Know that my system works. It is my primary entertainment system and have a wife that just wants a low fiddle fuck experience. I gave you my config. Emby absolutely connects to my HDHomeRun and Emby absolutely uses my gluetun network. You may notice that gluetun is using host network mode and has net admin cap. This is required to make this fly right. Best for you to try out my config and modify to your own needs and see what works best for you. Daniel
