Solution Kathy1 0 Posted October 20, 2023 Solution Posted October 20, 2023 We have been using Emby for years and we love it! We had to get a new fire stick but forget what channel the tv needs to be on when using it? I am hoping this is the problem and not that I need a new tv. I am old and get confused so I really appreciate your help.Â
GrimReaper 4893 Posted October 20, 2023 Posted October 20, 2023 (edited) Depends which HDMI slot you inserted it into - change input to HDMI1, HDMI2, HDMI3 etc.? Edit: Btw, how did you end up in Emby Guide Data forum? That's several levels deep and very seldom just stumbled upon for general questions? Asking out of curiosity, to see whether something can/should be improved to make it easier for inexperienced users to find appropiate forum sections, more relevant to their queries. Edited October 20, 2023 by GrimReaper Append
RanmaCanada 502 Posted October 21, 2023 Posted October 21, 2023 As GrimReaper says, you just need to make sure you have the TV on the right HDMI input. Check what input you plugged the stick into and then use the input button on your remote for the tv to change to said input.
