Bagul 182 Posted October 19, 2023 Posted October 19, 2023 (edited) Hello, I don't know if I'm in the right section of the forum. What does the "Selecting the secondary audio track" transcoding mean ? (And I don't understand why the transcoding bar is stuck.) Edited October 19, 2023 by Bagul
Luke 42288 Posted October 19, 2023 Posted October 19, 2023 Quote (And I don't understand why the transcoding bar is stuck.) Hi, it's not stuck. Anyway this means you selected a secondary audio track, and the only way it can be played is with some transcoding.
Bagul 182 Posted October 20, 2023 Author Posted October 20, 2023 14 hours ago, Luke said: Hi, it's not stuck. Yes the bar loads quickly I thought it was blocked ahah. 14 hours ago, Luke said: Anyway this means you selected a secondary audio track, and the only way it can be played is with some transcoding. Ah, so if it's not the main audio track that's chosen then there's transcoding?
pwhodges 2039 Posted October 20, 2023 Posted October 20, 2023 The audio tracks are not necessarily encoded the same way - so one might be OK to direct play, but the other might need decoding. Paul
Bagul 182 Posted October 20, 2023 Author Posted October 20, 2023 5 minutes ago, pwhodges said: The audio tracks are not necessarily encoded the same way - so one might be OK to direct play, but the other might need decoding. Paul Yes, I can understand that. But in my case, the 2 audios available for this particular media have the same codec and channel.
Luke 42288 Posted October 20, 2023 Posted October 20, 2023 2 hours ago, Bagul said: Yes, I can understand that. But in my case, the 2 audios available for this particular media have the same codec and channel. That doesn’t matter. What matters is that it’s secondary.
Bagul 182 Posted October 20, 2023 Author Posted October 20, 2023 2 minutes ago, Luke said: That doesn’t matter. What matters is that it’s secondary. I was just responding to pwhodges. But I don't understand what a secondary track is. Hence my question: 6 hours ago, Bagul said: Ah, so if it's not the main audio track that's chosen then there's transcoding?
pwhodges 2039 Posted October 20, 2023 Posted October 20, 2023 4 minutes ago, Luke said: That doesn’t matter. What matters is that it’s secondary. Why does that make a difference that requires transcoding? At the worst I would understand direct streaming with the second audio being placed in first position... Paul
Luke 42288 Posted October 20, 2023 Posted October 20, 2023 Because there’s no way to tell chrome or chromecast to play the secondary audio track, so it can only be accomplished with transcoding. 1
pwhodges 2039 Posted October 20, 2023 Posted October 20, 2023 Or repackaging, surely? That's what I expected. Paul
Bagul 182 Posted October 20, 2023 Author Posted October 20, 2023 3 minutes ago, Luke said: Because there’s no way to tell chrome or chromecast to play the secondary audio track, so it can only be accomplished with transcoding. Oh ok I understand, thanks for the answer. 1
