unisoft 355 Posted October 19, 2023 Posted October 19, 2023 These channels are missing EPG data (manual mapping cant be done as no data!) for England. Actual LCN channel number from multiplex shown. 62 Great TV +1 65 That's Christmas 63 Great Christmas Movies +1 37 QVC 2 Can these get sorted please?
Luke 42237 Posted October 19, 2023 Posted October 19, 2023 Hi, @Carlocan report this to our guide data provider. Thanks. 1
Carlo 4561 Posted October 21, 2023 Posted October 21, 2023 On 10/19/2023 at 11:31 AM, unisoft said: These channels are missing EPG data (manual mapping cant be done as no data!) for England. Actual LCN channel number from multiplex shown. 62 Great TV +1 65 That's Christmas 63 Great Christmas Movies +1 37 QVC 2 Can these get sorted please? What the is the Emby Guide Data source shown for this guide? Should be shown right under the Guide source you added. Thanks, Carlo
unisoft 355 Posted October 28, 2023 Author Posted October 28, 2023 On 21/10/2023 at 03:30, Carlo said: What the is the Emby Guide Data source shown for this guide? Should be shown right under the Guide source you added. Thanks, Carlo Do you mean GBR-1000083-DEFAULT? There is no data for these channels and none to manually map to. After reporting, it appears that LCN 62 and 63 are HBB channels over Broadband but 37 and 65 are not.
Carlo 4561 Posted November 2, 2023 Posted November 2, 2023 What did you select for these two options?
