Zanr7 0 Posted October 18, 2023 Posted October 18, 2023 I'm using Emby on Casa OS on a zimaboard i have set everything up i have set a pin code to use within the local area network but ever time i try to log in using it gives Sign In Error Invalid username or password. Please try again. which they are not. very confused they only i can get in is with the password. please if you need any logs please ask thank you
GrimReaper 4898 Posted October 18, 2023 Posted October 18, 2023 Hm, PIN login should still work at that version (login procedure has been revamped for 4.8). Just tested it on 4.7.14 stable and have no issues logging in with user/PIN. Which client app you're using? @Luke, are updated client apps still allowing this on 4.7+ stable?
Zanr7 0 Posted October 18, 2023 Author Posted October 18, 2023 (edited) I have Tried logging via the browser and Emby theater Version 4.7.14.0 and android phone app version also4.7.14.0 all the same result Edited October 18, 2023 by Zanr7
GrimReaper 4898 Posted October 18, 2023 Posted October 18, 2023 3 minutes ago, Zanr7 said: I have Tried logging via the browse Local or hosted Web app (IP:Port or app.emby.media)?
Zanr7 0 Posted October 18, 2023 Author Posted October 18, 2023 (edited) hosted via container on casaos with a local IP 10.10.20.133 / 8096 Port number Edited October 18, 2023 by Zanr7
Luke 42245 Posted October 18, 2023 Posted October 18, 2023 Hi, most likely the server doesn't think you're on the local network. You should review your reverse proxy configuration and emby server network settings. My advice though, don't use this feature and just sign in with the full password instead, because the local network password is being deprecated in the upcoming 4.8 server release.
