Pookeye 1 Posted January 18, 2024 Posted January 18, 2024 443, yeah everything works, I just needed to put https:// for it to work, as I just put the server name 1
ebr 16337 Posted January 18, 2024 Posted January 18, 2024 13 hours ago, Pookeye said: 443, Hi. Did you enter the port before entering the server address? Because, if you enter 443 or 8920 as the port, the app will automatically put "https://" on your address.
