michael99 0 Posted October 18, 2023 Posted October 18, 2023 Started in emby account on my phone now I'm trying to get it over to my shield and it won't go through please help
GrimReaper 4898 Posted October 18, 2023 Posted October 18, 2023 Sorry, not following, what do you mean by 28 minutes ago, michael99 said: Started in emby account on my phone ? Can you elaborate a bit what is the actual issue you're having? How to Report a Problem
michael99 0 Posted October 18, 2023 Author Posted October 18, 2023 I started an emby account on my cell phone want to move it over to my Nvidia shield on my TV and it's not working. When I used to do it to Plex Yes I didn't want to say Plex but from my phone to my TV I would just put in a PIN number and it would automatically go over on this one it does not how do I get it to go on my Nvidia shield from my phone
GrimReaper 4898 Posted October 18, 2023 Posted October 18, 2023 There's nothing to move over, you setup local user(s) on your server and can connect with same credentials from whichever device you want: cell phone, AndroidTV box, PC, Smart TV, whatever.
Luke 42244 Posted October 18, 2023 Posted October 18, 2023 @michael99what exactly have you done on the Shield so far? Where exactly are you hung up? What is on the screen?
michael99 0 Posted October 18, 2023 Author Posted October 18, 2023 On my embry screen on my shield it says sign in with connect it gives me a code I put the code in on the phone and it doesn't work
Luke 42244 Posted October 18, 2023 Posted October 18, 2023 Where exactly did you put the code in on your phone? Why do you think it doesn't work? What exactly did you do? What exactly happened?
michael99 0 Posted October 18, 2023 Author Posted October 18, 2023 It says pin confirmed and then nothing happens after that
michael99 0 Posted October 18, 2023 Author Posted October 18, 2023 I started an enby account on my phone then I put it on my nividia shield then on the video it says enter the code and it gives me five numbers I put those numbers on my phone it says pin confirmed and then nothing happens
pwhodges 2033 Posted October 18, 2023 Posted October 18, 2023 2 minutes ago, michael99 said: I started an enby account on my phone What do you mean by that? Have you either (a) set up your own Emby server to connect to, or (b) been given access to someone else's Emby server, with instructions how to connect to it? The Emby client is no use to you without a server to connect to - the Emby organisation doesn't provide such a server - they are software developers. Paul
michael99 0 Posted October 18, 2023 Author Posted October 18, 2023 Ok so my brother gives me his emby
Luke 42244 Posted October 18, 2023 Posted October 18, 2023 3 hours ago, michael99 said: Ok so my brother gives me his emby Did he give you instructions on how to connect to his server?
ebr 16337 Posted October 21, 2023 Posted October 21, 2023 On 10/18/2023 at 2:38 PM, michael99 said: It says pin confirmed and then nothing happens after that Hi. Did you press the "Next" button on the Shield app?
michael99 0 Posted October 21, 2023 Author Posted October 21, 2023 Yeah and it just says enter manually which they want IP ---or sign out of connect
Luke 42244 Posted October 24, 2023 Posted October 24, 2023 @michael99 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Luke 42244 Posted November 19, 2023 Posted November 19, 2023 17 minutes ago, michael99 said: I got it lol thanks @michael99can you please let us know the results of our questions above? Thanks !
Pookeye 1 Posted January 16, 2024 Posted January 16, 2024 New to emby here, still confused by this as well, my iOS emby app is connected to a server a friend gave me and I’m able to see content no problem, but once I connect to emby via my nvidia shield no servers are displayed. So I added the url and port and then it says error connecting. I’ll try side loading and see if that makes a difference
mik8451 2 Posted January 16, 2024 Posted January 16, 2024 Could it be that the Device Access user setting on the server has been restricted by the server manager for a user to only allow a single device?
ebr 16337 Posted January 16, 2024 Posted January 16, 2024 5 hours ago, Pookeye said: but once I connect to emby via my nvidia shield no servers are displayed Hi. Exactly what are you doing here?
Pookeye 1 Posted January 17, 2024 Posted January 17, 2024 Sorry, I’ll explain. so I am probably just confused with emby connect, on my nvidia shield, I download emby and it asks for a pin and to go to emby url /pin. I go to url in my phone and sign in, and enter my pin , it says verified, and I click next on my shield. but that’s it, it says to select server or add manually the server that my someone shares with me. I tried to use the url and port and it says error connecting. But clearly it works fine on my phone and my fire tablet. Where I connect and either add server or it already has my server information and I can begin watching content. But for some reason can’t get nvidia shield to connect to the emby server. Hope this helps
Pookeye 1 Posted January 17, 2024 Posted January 17, 2024 Ok looks like I needed to type https:// and then the server name
ebr 16337 Posted January 17, 2024 Posted January 17, 2024 So you are all set now? What port number were you entering?
