David Patt 21 Posted October 18, 2023 Posted October 18, 2023 So i have some tv shows where i have nice picture but only english audio , also have that show in my language (czech) but bad image quality. So i use mkvtoolnix to separate audio tracks which gave me MKA files. I rename them to be same as MKV files i have. so i have "show xx s01e01.mkv" and "show xx s01e01.mka" in same folder. I want avoid to mix them together. But Emby dont recognise additional audio track. Is it possible ? I try search on forum but dont find anything. Thank you.
rbjtech 5335 Posted October 18, 2023 Posted October 18, 2023 (edited) 19 minutes ago, David Patt said: So i have some tv shows where i have nice picture but only english audio , also have that show in my language (czech) but bad image quality. So i use mkvtoolnix to separate audio tracks which gave me MKA files. I rename them to be same as MKV files i have. so i have "show xx s01e01.mkv" and "show xx s01e01.mka" in same folder. I want avoid to mix them together. But Emby dont recognise additional audio track. Is it possible ? I try search on forum but dont find anything. Thank you. Just curious why not just add your language as a new n+1 audio track - making it the default if you wish ? It's easy enough to automate using mkvmerge - you don't even need to demux the file with the poor video first. Edited October 18, 2023 by rbjtech
David Patt 21 Posted October 18, 2023 Author Posted October 18, 2023 Just now, rbjtech said: Just curious why not just add your language as a new n+1 audio track - making it the default if you wish ? It's easy enough to automate using mkvmerge I send you PM
