Mikayla09 2 Posted October 19, 2023 Author Posted October 19, 2023 I did and that's when the http version started working again. Just now have to get used to using these browsers instead of Chrome. 1
Luke 42290 Posted October 19, 2023 Posted October 19, 2023 OK just be aware I have no problem doing this with Chrome. You just have to manually change https to http in the browser address bar.
Mikayla09 2 Posted October 19, 2023 Author Posted October 19, 2023 Every time I manually take out the "s" in https and leave it http it just opens again secure with https. No matter how many times I try. Maybe it was some sort of chrome security update or something. I can't find anyway to open it http.
visproduction 338 Posted October 19, 2023 Posted October 19, 2023 Mk, Clear your cache. In chrom browsers use [Ctrl] [Shift] [Del] together to get to the clear cache option.
Steveo369 11 Posted October 19, 2023 Posted October 19, 2023 I can confirm that I am having the same problem as the OP, and it seems to be related to the http/https redirect in Chrome. This is a relatively new issue, and I'm guessing related to some type of Chrome update (maybe). I navigate to app.emby.media and I receive the message to sign in. Sign in with my Emby Connect credentials, and my server is no longer listed. I only see the Add Server and Sign in with Emby Connect options. I can configure my server manually using my external NoIP dyndns address or my local IP, and then log in and see my Emby page, but this all used to be 'automatic'. Chrome requires me to change the https to http, and then it will 'find' the server, Edge just tells me the page is unsecure. No SSL, no VPN, cleared cookies and cache from the browser, etc. iOS app and Emby Theater app (on same machine as web browser) both work fine.
Luke 42290 Posted October 19, 2023 Posted October 19, 2023 27 minutes ago, Steveo369 said: This is a relatively new issue, and I'm guessing related to some type of Chrome update (maybe). Hi, yes it's because chrome has gotten more aggressive about this in it's latest version.
