chizz44 9 Posted October 16, 2023 Posted October 16, 2023 I had to rebuild my server last night to recover from a corrupted database. I'm now running stable on version 4.7.14.0, Truenas Core Release 13.1-RELEASE-p9. I was having an issue where my TV Guide data wouldn't populate. I have Emby Premiere and my key says it's valid. I tried deleting the Emby Guide plugin, thinking I could reinstall it from the catalog, but it won't load, my server log is attached. embyserver.txt
SKull77 3 Posted October 16, 2023 Posted October 16, 2023 InnerException: System.Security.Authehttps://emby.media/blog.xmlntication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: PartialChain Looks like an invalid certificate. I'm on FreeBSD as well and can't load Plugins either. But my error seems way more general: System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Connection reset by peer (www.mb3admin.com:443) ---> System.Net.Sockets.SocketException (54): Connection reset by peer at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackages(CancellationToken cancellationToken, Boolean withRegistration, String packageType, Version applicationVersion) at Emby.Api.PackageService.Get(GetPackages request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Net.Sockets.SocketException: Connection reset by peer Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
chizz44 9 Posted October 16, 2023 Author Posted October 16, 2023 Yeah I saw that reference to the certificate chain in the log, but have no clue how to fix it.
Luke 42237 Posted October 17, 2023 Posted October 17, 2023 Hi, are you still having an issue with this?
chizz44 9 Posted October 18, 2023 Author Posted October 18, 2023 Yes I am. I was going to spin up a new jail, install Emby and try to get a new copy of the Emby Guide plugin, but I really don't want to do that. I'd like to resolve the catalog error, any thoughts based on the log I attached?
Solution chizz44 9 Posted October 18, 2023 Author Solution Posted October 18, 2023 (edited) I resolved this by running "pkg install ca_root_nss" in my Truenas jail. I was able to reinstall the Emby Guide plugin and get my guide data back! Edited October 18, 2023 by chizz44 1 3
Luke 42237 Posted October 18, 2023 Posted October 18, 2023 2 hours ago, chizz44 said: I resolved this by running "pkg install ca_root_nss" in my Truenas jail. I was able to reinstall the Emby Guide plugin and get my guide data back! Thanks for following up !
Arvald 2 Posted November 10, 2023 Posted November 10, 2023 Thank you for posting fix. Worked for me in same situation. 1
Insanity_Pants 2 Posted January 20, 2024 Posted January 20, 2024 On 18/10/2023 at 17:17, chizz44 said: I resolved this by running "pkg install ca_root_nss" in my Truenas jail. I was able to reinstall the Emby Guide plugin and get my guide data back! Thank you so much for this info. I was having exactly the same issue, and this fixed it for me. 1
DiogoFeitosa11 1 Posted February 5, 2025 Posted February 5, 2025 Ola a todos, consegui resolver desta forma: Último Recurso: Desativar IPv6 Se nada acima funcionar, tente desativar o IPv6 (caso seu servidor esteja tentando usar ele e falhando). Edite o arquivo de configuração: sudo nano /etc/sysctl.conf 2️Adicione essas linhas no final: net.ipv6.conf.all.disable_ipv6 = 1 net.ipv6.conf.default.disable_ipv6 = 1 net.ipv6.conf.lo.disable_ipv6 = 1 Salve (CTRL+X, Y, Enter) e aplique: sudo sysctl -p Agora, teste novamente: wget https://www.mb3admin.com/admin/service/EmbyPackages.json perceba que o catalogo vai funcionar novamente! 1
