tech37 9 Posted October 15, 2023 Posted October 15, 2023 I have a few thousand channels that haven't had guide data auto-mapped from my provider, but most aren't critical so I'd like to disable them. Is there a way I can bulk disable all channels on the Live TV > Channels > Not Mapped to Guide Data screen? Even just pointing me to a couple API endpoints that would give me the info to loop through and disable them would be wonderful.
Luke 42237 Posted October 15, 2023 Posted October 15, 2023 Hi, bulk edit features will be coming in future updates. Thanks.
tech37 9 Posted October 16, 2023 Author Posted October 16, 2023 Thanks Luke! Is there by chance an API endpoint that would let me grab all unmapped live TV channels? And then am I correct that this would be the correct endpoint to iteratively update each channel to disable it? Much appreciated
Solution Luke 42237 Posted October 16, 2023 Solution Posted October 16, 2023 HI, if you use the filter dialog on the channel management screen, you'll notice there are filters for this. Try using those and then if you want to script it with the api, then just monitor the requests that are being sent using the browser debugger. 1
tech37 9 Posted October 16, 2023 Author Posted October 16, 2023 To anyone finding this thread in the future, I created a repo that contains a Python script for bulk disabling unmapped live TV channels: https://github.com/coulterpeterson/emby-bulk-actions 1 3
afogleson 15 Posted August 13, 2025 Posted August 13, 2025 On 10/16/2023 at 1:15 PM, tech37 said: To anyone finding this thread in the future, I created a repo that contains a Python script for bulk disabling unmapped live TV channels: https://github.com/coulterpeterson/emby-bulk-actions Two years later and it is very useful. I may extend it so i can enable with filters and such but it did handle the disabling perfectly. (i did not want to manually click something like 1200 channels.
sufamic 0 Posted September 22, 2025 Posted September 22, 2025 On 10/16/2023 at 12:15 PM, tech37 said: To anyone finding this thread in the future, I created a repo that contains a Python script for bulk disabling unmapped live TV channels: https://github.com/coulterpeterson/emby-bulk-actions It looks like this may be out of date in 2025. I ran into the same issue and created an updated repo that contains a script for bulk disabling unmapped channels: https://github.com/sufamic/emby-channel-manager. Thank you for the inspiration!
afogleson 15 Posted September 22, 2025 Posted September 22, 2025 1 hour ago, sufamic said: It looks like this may be out of date in 2025. I ran into the same issue and created an updated repo that contains a script for bulk disabling unmapped channels: https://github.com/sufamic/emby-channel-manager. Thank you for the inspiration! Weird... what problem did you see? I used the original repo to bulk disable the unmapped channels from my feed. Where i have problems is disabling channels that ARE mapped but the url in the m3u is outdated or invalid. i did it by hand now but such is life. im far too lazy to write the code to do it lol. Though i may include it as some feature of my comcutting and remuxing app. (right now only command line, and not perfect... works most times but sometimes not)
