grahamcoyswanst 2 Posted October 20, 2023 Author Posted October 20, 2023 bear with me trying to work out how to copy and paste all that info for you.
grahamcoyswanst 2 Posted October 20, 2023 Author Posted October 20, 2023 ps -ef|grep Emby judgey 180033 1 2 12:25 ? 00:00:08 /opt/judgey/emby-server/syst em/EmbyServer -programdata /home/judgey/.config/Emby -ffdetect /opt/judgey/emby- server/bin/ffdetect -ffmpeg /opt/judgey/emby-server/bin/ffmpeg -ffprobe /opt/jud gey/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{v ersion}_amd64.deb root 188538 186135 0 12:30 ? 00:00:00 /opt/quickbox/system/manage -c #!/bin/bash ################################################# ############################### # <START METADATA> # @file_name: manage # @versi on: 1.0.452 # @project_name: quickbox_pro_v3 # @description: collection of manag e scripts # # @save_tasks: # automated_versioning: true # automated_documentat ion: true # # @build_tasks: # automated_comment_strip: true # automated_encryp tion: true # # @author: Jason Matthews (JMSolo) # @author_contact: support@quick box.io # @author: Jamie Dobbs (mschf) # @author_contact: jamie.dobbs@mschf.dev # # @license: BSD-3 Clause (Included in LICENSE) # Copyright (C) 2019-2023, Quick Box.IO # All rights reserved. # <END METADATA> # shellcheck disable=SC1091,SC203 4,SC2140,SC2165,SC2167,SC2312 ################################################## ############################## ################################################ ################################ # @description: sets up environment for command s # @noargs # @internal # @return_code: 1 script should be run via qb ########## ###################################################################### manage::e nvironment::init() { ?declare script_name ?script_name=$(basename -- "$0") ?[[ $ {qb_invoked:-0} -eq 0 ]] && { echo -ne "\033[38;5;203merror\e[0m[1]: ${script_na me} should be run via qb\n" >&2 && exit 1; } ?. "/opt/mflibs/src/init.sh" ?mflib s::import shell,quickbox,status,log,info } quickbox::dashboard::log() { ?admin_ name="$(quickbox::database "SELECT username FROM user_information WHERE user_lev el = '10';")" ?if [[ ! -f "/srv/quickbox/logs/dashboard" ]]; then ??mkdir -p /sr v/quickbox/logs ??touch /srv/quickbox/logs/dashboard ??chown www-data:www-data / srv/quickbox/logs/dashboard ?fi ?if [[ ! -f "/srv/quickbox/logs/${username:-${ad min_name}}.dashboard" ]]; then ??mkdir -p /srv/quickbox/logs ??touch "/srv/quick box/logs/${username:-${admin_name}}.dashboard" ??chown www-data:www-data "/srv/q uickbox/logs/${username:-${admin_name}}.dashboard" ?fi ?if [[ -n ${username} ]]; then ??echo "${1:-null}" | sed -z "s/\n/\n<br>/" >"/srv/quickbox/logs/${usernam e:-}.dashboard" ?else ??echo "${1:-null}" | sed -z "s/\n/\n<br>/" >"/srv/quickbo x/logs/${admin_name:-}.dashboard" ?fi ?echo "${1:-null}" } #################### ############################################################ # @description: man ages api key activation and deactivation # @noargs ############################# ################################################### api::settings() { ?######## ######################################################################## ?# @des cription: pulls information from database and quickbox.io ?# @noargs ?########## ###################################################################### ?api::var iable::assign() { ??declare mflibs_log_location="${quickbox_base_path:="/opt/qui ckbox"}/logs/system_log" ??declare -g api_activated api_activated_date api_key a pi_instance api_ip api_product_id api_code api_execution api_status api_activate d api_activations_remaining api_total_activations api_total_activations_purchase d ??declare api_json ??IFS=$'\n' read -d '' -ra api_array <<<"$(quickbox::databa se "SELECT configuration_name,configuration_value FROM system_configuration WHER E configuration_name = 'api_key' OR configuration_name = 'api_instance' OR confi guration_name = 'api_activated_date' OR configuration_name = 'api_product_id' OR configuration_name = 'api_activated' OR configuration_name = 'api_ip'")" ??for i in "${api_array[@]}"; do ???array_configuration_name="$(echo "${i}" | cut -d ' |' -f1)" ???array_configuration_value="$(echo "${i}" | cut -d '|' -f2-)" ???case "${array_configuration_name}" in ???api_key) api_key="${array_configuration_val ue}" ;; ???api_ip) api_ip="${array_configuration_value}" ;; ???api_product_id) a pi_product_id="${array_configuration_value}" ;; ???api_instance) api_instance="$ {array_configuration_value}" ;; ???api_activated_date) api_activated_date="${arr ay_configuration_value}" ;; ???*) ;; ???esac ??done ??api_json=$(curl -s4 -k "ht tps://quickbox.io/?wc-api=wc-am-api&product_id=${api_product_id}&object=${api_ip }&instance=${api_instance}&api_key=${api_key}&request=status") ??for value in $( jq 'keys | .[]' <<<"${api_json}"); do ???if [[ ${value} == '"code"' ]]; then ??? ?mflibs::shell::text::red "invalid response" ????api_code=$(jq -r ".${value}" << <"${api_json}") ????break ???elif [[ ${value} == '"api_call_execution_time"' ]]; then ????api_execution=$(jq -r ".${value}" <<<"${api_json}") ???elif [[ ${value } == '"status_check"' ]]; then ????api_status=$(jq -r ".${value}" <<<"${api_json }") ???elif [[ ${value} == '"data"' ]]; then ????for data_value in $(jq '.data | keys | .[]' <<<"${api_json}"); do ?????if [[ ${data_value} == '"activated"' ]]; then ??????api_activated=$(jq -r ".data.${data_value}" <<<"${api_json}") ?????e lif [[ ${data_value} == '"activations_remaining"' ]]; then ??????api_activations _remaining=$(jq -r ".data.${data_value}" <<<"${api_json}") ?????elif [[ ${data_v alue} == '"total_activations"' ]]; then ??????api_total_activations=$(jq -r ".da ta.${data_value}" <<<"${api_json}") ?????elif [[ ${data_value} == '"total_activa tions_purchased"' ]]; then ??????api_total_activations_purchased=$(jq -r ".data. ${data_value}" <<<"${api_json}") ?????fi ????done ???fi ??done ?} ?############ #################################################################### ?# @descrip tion: outputs api status in terminal window ?# @noargs ?######################## ######################################################## ?api::status::view() { ??column -ts '|' <<<"$( ???mflibs::shell::text::yellow "local information|" ???m flibs::shell::text::white::sl "api execution time:|" ???mflibs::shell::text::gre en::bold "${api_execution}" ???mflibs::shell::text::white::sl "api key:|" ???mfl ibs::shell::text::green::bold "${api_key}" ???mflibs::shell::text::white::sl "ap i activation date:|" ???mflibs::shell::text::green::bold "${api_activated_date}" ???mflibs::shell::text::white::sl "api ip:|" ???mflibs::shell::text::green::bol d "${api_ip}" ???mflibs::shell::text::white::sl "product id:|" ???mflibs::shell: :text::green::bold "${api_product_id}" ???mflibs::shell::text::white::sl "instan ce id:|" ???mflibs::shell::text::green::bold "${api_instance}" ???mflibs::shell: :misc::nl ???mflibs::shell::text::yellow "remote information|" ???mflibs::shell: :text::white::sl "api total activations:|" ???mflibs::shell::text::green::bold " ${api_total_activations}" ???mflibs::shell::text::white::sl "api activations rem aining:|" ???mflibs::shell::text::green::bold "${api_activations_remaining}" ??? mflibs::shell::text::white::sl "api activated:|" ???mflibs::shell::text::green:: bold "${api_activated}" ???mflibs::shell::text::white::sl "api status:|" ???mfli bs::shell::text::green::bold "${api_status}" ??)" ?} ?######################### ####################################################### ?# @description: deactiv ates api key ?# @noargs ?####################################################### ######################### ?api::key::deactivate() { ??declare deactivate_check ? ?if [[ ${api_force:-0} -eq "0" ]]; then ???mflibs::shell::misc::nl ???mflibs::sh ell::text::white::sl "deactivate api key? " ???mflibs::shell::text::green::sl "[ y]" ???mflibs::shell::text::white::sl "es " ???mflibs::shell::text::white "or [n ]o:" ???mflibs::shell::icon::arrow::white ???read -r input ???case "${input,,}" in ???[y] | [y][e][s] | "") : ;; ???*) exit 0 ;; ???esac ??fi ??deactivate_check =$(curl -s4 -k "https://quickbox.io/?wc-api=wc-am-api&product_id=${api_product_i d}&object=${api_ip}&instance=${api_instance}&api_key=${api_key}&request=deactiva te" | jq -r ".deactivated") ??if [[ ${api_force} -eq "0" ]]; then ???if [[ ${dea ctivate_check} == "true" ]]; then ????quickbox::database "UPDATE system_configur ation set configuration_value = 'false' WHERE configuration_name='api_activated' ;" ???else ????mflibs::shell::text::red "unable to deactivate api key" ???fi ??f i ?} ?######################################################################### ####### ?# @description: checks api key ?# @noargs ?############################ #################################################### ?api::key::check() { ??decl are check_status ??check_status=$(curl -s4 -k "https://quickbox.io/?wc-api=wc-am -api&product_id=${api_product_id}&object=${api_ip}&instance=${api_instance}&api_ key=${api_key}&request=status" | jq -r '.data."activated"') ??if [[ ${api_force} -eq "0" ]]; then ???if [[ ${check_status} == "true" ]]; then ????mflibs::shell: :text::green "api key is activated" ????quickbox::database "UPDATE system_config uration set configuration_value = 'true' WHERE configuration_name='api_activated ';" ????\cp -rf /opt/quickbox/dashboard/inc/plugins/nav/dash_navigation-pro.php /srv/quickbox/dash_navigation.php ???else ????mflibs::shell::text::red "api key is not activated" ????quickbox::database "UPDATE system_configuration set config uration_value = 'false' WHERE configuration_name='api_activated';" ????\cp -rf / opt/quickbox/dashboard/inc/plugins/nav/dash_navigation-community.php /srv/quickb ox/dash_navigation.php ???fi ??fi ?} ?######################################### ####################################### ?# @description: activates api key ?# @n oargs ?######################################################################### ####### ?api::key::activate() { ??if [[ ${api_force:-0} -eq "0" ]]; then ???mfli bs::shell::misc::nl ???mflibs::shell::text::white::sl "activate api key? " ???mf libs::shell::text::green::sl "[y]" ???mflibs::shell::text::white::sl "es " ???mf libs::shell::text::white "or [n]o:" ???mflibs::shell::icon::arrow::white ???read -r input ???case "${input,,}" in ???[y] | [y][e][s] | "") : ;; ???*) exit 0 ;; ???esac ??fi ??declare -a product_codes ??declare api_instance api_date product public_ip api_key quickbox_version ??api_date=$(date +"%b %d, %Y %l:%M") ??publi c_ip=$(mflibs::info::ipv4::local) ??api_instance=$(date +%s | sha256sum | base64 | head -c 16) ??product_codes=("13256" "24449" "24450" "24451" "24452" "13257" "24453" "24454" "24455" "24456" "13324" "349206") ??quickbox_version=$(quickbox: :database "SELECT configuration_value FROM system_configuration WHERE configurat ion_name = 'server_current_version'") ??if [[ -z ${man_api_key:-} ]]; then ???mf libs::shell::misc::nl ???mflibs::shell::text::white "enter api key: " ???mflibs: :shell::icon::arrow::white ???read -r api_key ??fi ??for product in "${product_c odes[@]}"; do ???api_activated=$(curl -s4 -k "https://quickbox.io/?wc-api=wc-am- api&product_id=${product}&object=${public_ip}&version=${quickbox_version}&instan ce=${api_instance}&api_key=${man_api_key:-${api_key}}&request=activate" | grep - Eoi '"activated":true' | cut -d: -f2-) ???if [[ ${api_activated} == "true" ]]; t hen ????api_product_id="${product}" ????break ???fi ??done ??[[ ${api_activated} != "true" ]] && mflibs::shell::text::red "invalid api key; please contact suppo rt" && api::environment::cleanup ??quickbox::database "WITH Tmp(configuration_na me, configuration_value) AS (VALUES ('api_activated', 'true'), ('api_activated_d ate', '${api_date}'),('api_key', '${man_api_key:-${api_key}}'), ('api_instance', '${api_instance}'), ('api_ip', '${public_ip}'), ('api_product_id', '${api_produ ct_id}')) UPDATE system_configuration SET configuration_value = (SELECT configur ation_value FROM Tmp WHERE system_configuration.configuration_name = Tmp.configu ration_name) WHERE configuration_name IN (SELECT configuration_name FROM Tmp);" ??if [[ -z ${api_force} ]]; then ???mflibs::shell::misc::nl ???mflibs::shell::te xt::green "api key has been activated" ???mflibs::shell::misc::nl ??fi ?} ?api: :variable::assign ?if [[ ${qb_option[*]:-} == *"deactivate"* || -n ${man_api_key } ]]; then ??[[ ${qb_option[*]:-} == *"force"* || -n ${man_api_key} ]] && declar e -gi api_force=1 ??api::key::deactivate ??api::key::activate ??api::variable::a ssign ?elif [[ ${qb_option[*]:-} == *"check"* ]]; then ??api::key::check ?elif [ [ ${api_code} != "100" ]]; then ??api::status::view ??api::key::deactivate ??api ::key::activate ?fi ?if [[ ${qb_option[*]:-} == *"deactivate"* ]]; then ??quickb ox::database "INSERT INTO system_log ("user_id", "log_source", "log_type", "log_ operation", "timestamp") VALUES ('${user_id:-1}', 'qb manage api -o deactivate . ..', 'system', 'DEACTIVATE_QUICKBOX_API', '$(date +"%Y-%m-%d %H:%M:%S")');" ?eli f [[ ${qb_option[*]:-} == *"activate"* ]]; then ??quickbox::database "INSERT INT O system_log ("user_id", "log_source", "log_type", "log_operation", "timestamp") VALUES ('${user_id:-1}', 'qb manage api -o activate ...', 'system', 'ACTIVATE_Q UICKBOX_API', '$(date +"%Y-%m-%d %H:%M:%S")');" ?elif [[ ${qb_option[*]:-} == *" check"* ]]; then ??: ?else ??quickbox::database "INSERT INTO system_log ("user_i d", "log_source", "log_type", "log_operation", "timestamp") VALUES ('${user_id:- 1}', 'qb manage api', 'system', 'ACTIVATION_INFO_STATS', '$(date +"%Y-%m-%d %H:% M:%S")');" ?fi } ############################################################## ################## # @description: manages fail2ban settings on the server # @no args # @example: qb manage fail2ban -o [config|unban] # @null ################## ############################################################## fail2ban::setting s() { ?for option in "${qb_option[@]}"; do ??case "${option,,}" in ??"config") ? ??fail2ban_dir="/etc/fail2ban/" ???if [[ ! -d ${fail2ban_dir} ]]; then ????mflib s::shell::text::red "Fail2ban is not installed. Would you like to install this? [y/N]:" ????echo -en "> " ????read -r input ????case ${input} in ????[yY] | [yY] [Ee][Ss]) ?????/usr/local/bin/qb install fail2ban ?????exit 1 ?????;; ????[nN] | [nN][Oo]) ?????mflibs::shell::text::red "Exiting Script." && exit 1 ?????;; ??? ?*) ?????mflibs::shell::text::red "Exiting Script." && exit 1 ?????;; ????esac ? ??fi ???mflibs::shell::text::white "Ban time for incorrect login (Default 10m) [ 5m/3h/12d]:" ???unset input ???echo -en "> " ???read -r input ???bantime="${inpu t//[^0-9]*/}" ???if [[ ${input} == "" ]]; then ????bantime=600 ???elif [[ ${inpu t} == *"m" ]]; then ????bantime=$((bantime * 60)) ???elif [[ ${input} == *"h" ]] ; then ????bantime=$((bantime * 60 * 60)) ???elif [[ ${input} == *"d" ]]; then ? ???bantime=$((bantime * 60 * 60 * 12)) ???fi ???mflibs::shell::text::white "Time between incorrect logins for ban (Default 10m) [5m/3h/12d]:" ???unset input ??? echo -en "> " ???read -r input ???findtime="${input//[^0-9]*/}" ???if [[ ${input } == "" ]]; then ????findtime=600 ???elif [[ ${input} == *"m" ]]; then ????findt ime=$((findtime * 60)) ???elif [[ ${input} == *"h" ]]; then ????findtime=$((find time * 60 * 60)) ???elif [[ ${input} == *"d" ]]; then ????findtime=$((findtime * 60 * 60 * 12)) ???fi ???mflibs::shell::text::white "Max number of retries withi n time (Default 5):" ???unset input ???echo -en "> " ???read -r input ???maxretr y="${input//[^0-9]*/}" ???if [[ ${input} == "" ]]; then ????maxretry=5 ???fi ??? mflibs::shell::text::white "IPs ignored by fail2ban (Default none) [1.1.1.1,2.2. 2.2]" ???mflibs::shell::text::green "Your IP is $(who am i | awk '{ print $5}' | tr -d '()'):" ???unset input ???echo -en "> " ???read -r input ???ignoreip="${i nput}" ???mflibs::shell::text::white "Monitor SSH Logins? ([y]/n):" ???unset inp ut ???echo -en "> " ???read -r input ???case ${input} in ???[yY] | [yY][Ee][Ss]) ????SSH="true" ????;; ???[nN] | [nN][Oo]) ????SSH="false" ????;; ???*) ????SSH= "true" ????;; ???esac ???mflibs::shell::text::white "Monitor Nginx Logins? ([y]/ n):" ???unset input ???echo -en "> " ???read -r input ???case ${input} in ???[yY ] | [yY][Ee][Ss]) ????nginx="true" ????;; ???[nN] | [nN][Oo]) ????nginx="false" ????;; ???*) ????nginx="true" ????;; ???esac ???mflibs::shell::text::white "Moni tor QuickBox Logins? ([y]/n):" ???unset input ???echo -en "> " ???read -r input ???case ${input} in ???[yY] | [yY][Ee][Ss]) ????quickbox="true" ????;; ???[nN] | [nN][Oo]) ????quickbox="false" ????;; ???*) ????quickbox="true" ????;; ???esac ???mflibs::shell::text::white "Applying Configuration..." ???\cp -f "/opt/quickb ox/config/software/fail2ban/quickbox.conf" "/etc/fail2ban/filter.d/quickbox.conf " ???if [[ -f "/etc/fail2ban/jail.local" ]]; then ????\cp -f "/etc/fail2ban/jail .local" "/etc/fail2ban/jail.bak" ???fi ???\cp -f "/opt/quickbox/config/software/ fail2ban/jail.local" "/etc/fail2ban/jail.local" ???sed -i -e "s/IGNORE_CONFIG/${ ignoreip}/g" /etc/fail2ban/jail.local -e "s/BANTIME_CONFIG/${bantime}/g" /etc/fa il2ban/jail.local -e "s/FINDTIME_CONFIG/${findtime}/g" /etc/fail2ban/jail.local -e "s/RETRY_CONFIG/${maxretry}/g" /etc/fail2ban/jail.local -e "s/SSHD_CONFIG/${S SH}/g" /etc/fail2ban/jail.local -e "s/NGINX_CONFIG/${nginx}/g" /etc/fail2ban/jai l.local -e "s/QUICKBOX_CONFIG/${quickbox}/g" /etc/fail2ban/jail.local ???mflibs: :log "systemctl restart fail2ban" ???mflibs::shell::text::green "Configuration a pplied" ???;; ??"unban") ???fail2ban_dir="/etc/fail2ban/" ???if [[ ! -d ${fail2b an_dir} ]]; then ????mflibs::shell::text::red "Fail2ban is not installed. Would you like to install this? [y/N]:" ????echo -en "> " ????read -r input ????case $ {input} in ????[yY] | [yY][Ee][Ss]) ?????/usr/local/bin/qb install fail2ban ???? ?exit 1 ?????;; ????[nN] | [nN][Oo]) ?????mflibs::shell::text::red "Exiting Scri pt." && exit 1 ?????;; ????*) ?????mflibs::shell::text::red "Exiting Script." && exit 1 ?????;; ????esac ???fi ???fail2banjails=$(fail2ban-client status | grep "Jail list" | cut -f2- | sed 's/,//g') ???mflibs::shell::text::white "Unbanning ${option}..." ???for jails in ${fail2banjails}; do ????fail2ban-client set "${ja ils}" unbanip "${option}" >/dev/null 2>&1 ???done ???mflibs::shell::text::green "${option} unbanned." ???;; ??"inclog") ???# trunk-ignore(shellcheck/SC2001) ??? ip=$(echo "${domain}" | sed 's/\s//g') ???echo "${ip} -- [$(date +%d)/$(date +%b )/$(date +%Y):$(date +%H):$(date +%M):$(date +%S)] -- Failed Login - ${username} " >>/srv/quickbox/logs/fail2ban.log ???;; ??*) ???mflibs::shell::text::red "Inva lid option: ${option}" ???;; ??esac ?done } ################################## ############################################## # @description: manages language settings on the server # @arg: -o [de|german|dk|danish|en|english|es|spanish|fr| french|pt|portuguese|zh-cn|chinese] # @example: qb manage lang -o en(or english) # @null ####################################################################### ######### lang::settings() { ?declare language code_name ?declare -g quickbox_ba se_path="/opt/quickbox" ?code_name=$(lsb_release -cs) ?for lang in "${qb_option[ @]}"; do ??case "${lang,,}" in ??de | german*) ???source /root/.bashrc ???declar e -g locale_sed quickbox_lang ???locale_sed=de_DE ???quickbox_lang=de ???cp -f " ${quickbox_base_path}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/localize.php" "/sr v/quickbox/inc/localize.php" ???sed -i -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UT F-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8/s/^#*/#/g' -e '/zh_C N.UTF-8/s/^#*/#/g' -e 's/^#.*\(de_DE.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>& 1 ???#sudo locale-gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-fil e=/etc/default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend nonint eractive locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??dk | danish*) ? ??source /root/.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=da_D K ???quickbox_lang=dk ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lan g}/locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${q uickbox_lang}/localize.php" "/srv/quickbox/inc/localize.php" ???sed -i -e '/de_D E.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/ pt_PT.UTF-8/s/^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(da_DK.UTF-8\)/\1/ ' /etc/locale.gen >/dev/null 2>&1 ???#sudo locale-gen --purge >/dev/null 2>&1 ?? ?sudo update-locale --locale-file=/etc/default/locale >/dev/null 2>&1 ???sudo dp kg-reconfigure --frontend noninteractive locales >/dev/null 2>&1 ???source /root /.bashrc ???;; ??en | english*) ???source /root/.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=en_US ???quickbox_lang=en ???cp -f "${quickbox_base _path}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${qu ickbox_base_path}/config/lang/${quickbox_lang}/localize.php" "/srv/quickbox/inc/ localize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8/s/^#*/# /g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(en_US.UTF-8\)/\1/' /etc/locale.gen ? ??#sudo locale-gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-file=/ etc/default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend nonintera ctive locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??es | spanish*) ??? source /root/.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=es_ES ???quickbox_lang=es ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang} /locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${qui ckbox_lang}/localize.php" "/srv/quickbox/inc/localize.php" ???sed -i -e '/de_DE. UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt _PT.UTF-8/s/^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(es_ES.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>&1 ???#sudo locale-gen --purge >/dev/null 2>&1 ???s udo update-locale --locale-file=/etc/default/locale >/dev/null 2>&1 ???sudo dpkg -reconfigure --frontend noninteractive locales >/dev/null 2>&1 ???source /root/. bashrc ???;; ??fr | french*) ???source /root/.bashrc ???declare -g locale_sed qu ickbox_lang ???locale_sed=fr_FR ???quickbox_lang=fr ???cp -f "${quickbox_base_pa th}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${quick box_base_path}/config/lang/${quickbox_lang}/localize.php" "/srv/quickbox/inc/loc alize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8/s/^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(fr_FR.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>&1 ???#sudo locale- gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-file=/etc/default/loc ale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend noninteractive locales > /dev/null 2>&1 ???source /root/.bashrc ???;; ??pt | portuguese*) ???source /root /.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=pt_PT ???quickbox_ lang=pt ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/locale" "/e tc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/ localize.php" "/srv/quickbox/inc/localize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/ #/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/ ^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(pt_PT.UTF-8\)/\1/' /etc/locale. gen >/dev/null 2>&1 ???#sudo locale-gen --purge >/dev/null 2>&1 ???sudo update-l ocale --locale-file=/etc/default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend noninteractive locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??zh-cn | chinese*) ???source /root/.bashrc ???declare -g locale_sed quickbox_l ang ???locale_sed=zh_CN ???quickbox_lang=zh-cn ???mflibs::log "apt-get -y instal l language-pack-zh-hans language-pack-zh-hans-base fonts-noto" ???cp -f "${quick box_base_path}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/localize.php" "/srv/quick box/inc/localize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^ #*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8 /s/^#*/#/g' -e 's/^#.*\(zh_CN.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>&1 ???#s udo locale-gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-file=/etc/ default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend noninteractiv e locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??*) ;; ??esac ?done ?if [[ -n ${locale_sed} ]]; then ??sed -i -e 's/thousands_sep.*/thousands_sep \"<U002C>\"/' "/usr/share/i18n/locales/${locale_sed}" ??[[ ${code_name} = = "stretch" ]] && sed -i -e 's/decimal_point.*/decimal_point \"<U002 C>\"/' "/usr/share/i18n/locales/${locale_sed}" ?fi ?chown www-data: /srv/quickbo x/inc/localize.php ?#mflibs::log "dpkg-reconfigure --frontend noninteractive loc ales" ?quickbox::database "UPDATE system_configuration set configuration_value = '${quickbox_lang}' WHERE configuration_name = 'server_language';" ?#mflibs::log "systemctl reload nginx" ?mflibs::log "systemctl reload php8.1-fpm > /dev/null 2>&1 &" ?mflibs::log "systemctl reload memcached > /dev/null 2>&1 &" } ######## ######################################################################## # @desc ription: manages backup, restore, and restore default for software configs # @ar g: -o [disable|enable|backup|restore|default] -u [username] -s [software] # @exa mple: qb manage nginx -o backup -s softwarename -u username # @null ############ #################################################################### nginx::sett ings() { ?if [[ ${software:?} == "netdata" || ${software:?} == "nextcloud" || ${ software:?} == "rutorrent" || ${software:?} == "tautulli" || ${software:?} == "t helounge" || ${software:?} == "transmission" || ${software:?} == "webconsole" || ${software:?} == "znc" ]]; then ??software_nginx="/etc/nginx/software/${softwar e:-}.conf" ??software_backup_nginx="/home/${username:?}/.QuickBox/software/${sof tware}/backup/nginx/${software}.conf" ??software_default_nginx="/home/${username }/.QuickBox/software/${software}/default/nginx/${software}.conf" ?else ??softwar e_nginx="/etc/nginx/software/${username:?}.${software:-}.conf" ??software_backup _nginx="/home/${username}/.QuickBox/software/${software}/backup/nginx/${username }.${software}.conf" ??software_default_nginx="/home/${username}/.QuickBox/softwa re/${software}/default/nginx/${username}.${software}.conf" ?fi ?for option in "$ {qb_option[@]}"; do ??case "${option,,}" in ??disable) ???mflibs::shell::text::w hite "disabling auth login on ${software} nginx reverse." ???if [[ ! -f ${softwa re_nginx} ]]; then ????mflibs::shell::text::red "nginx file [${software_nginx}] does not exist." ???else ????sed -i '/auth_basic/s/^#*/#/g' "${software_nginx}" ????mflibs::log "systemctl reload nginx.service" ????mflibs::shell::text::green "nginx auth has been disabled." ???fi ???;; ??enable) ???mflibs::shell::text::wh ite "enabling auth login on ${software} nginx reverse." ???if [[ ! -f ${software _nginx} ]]; then ????mflibs::shell::text::red "nginx file [${software_nginx}] do es not exist." ???else ????sed -i '/auth_basic/s/^#*//g' "${software_nginx}" ??? ?mflibs::log "systemctl reload nginx.service" ????mflibs::shell::text::green "ng inx auth has been enabled." ???fi ???;; ??backup) ???mflibs::shell::text::white "nginx file for ${software} is now being backed up." ???if [[ ! -f ${software_ng inx} ]]; then ????mflibs::shell::text::red "nginx file [${software_nginx}] does not exist." ???else ????mkdir -p "/home/${username}/.QuickBox/software/${softwar e}/backup/nginx/" ????\cp -pf "${software_nginx}" "${software_backup_nginx}" ??? ?mflibs::shell::text::green "configuration file has been backed up." ???fi ???;; ??restore) ???if [[ ! -f ${software_backup_nginx} ]]; then ????mflibs::shell::t ext::red "nginx file [${software_backup_nginx}] does not exist." ???else ????\cp -pf "${software_backup_nginx}" "${software_nginx}" ????mflibs::shell::text::gre en "backed up configuration file has been restored." ???fi ???;; ??default) ???i f [[ ! -f ${software_default_nginx} ]]; then ????mflibs::shell::text::red "deful t nginx file [${software_default_nginx}] does not exist." ???else ????\cp -pf "$ {software_default_nginx}" "${software_nginx}" ????mflibs::shell::text::green "de fault configuration file has been restored." ???fi ???;; ??*) ;; ??esac ?done } ############################################################################### # # @description: manages directory/mount checks # @arg: -o space -u [username] # @example: qb manage mount -o space -u username # @null ####################### ######################################################### mount::settings() { ?f or option in "${qb_option[@]}"; do ??case "${option,,}" in ??space) ???read -d ' ' -ra mount_path <<<"$(quickbox::database "SELECT mount FROM user_mounts WHERE u sername='${username}';")" ???for m in "${mount_path[@]}"; do ????# if mount path is '/' use `df -B1` instead ????[[ ${m} == "/" ]] && space_used=$(df -B1 | grep -w "/" | awk '{print $3}' | tail -n 1) ????[[ ${m} != "/" ]] && space_used=$(du -ac --bytes "${m}" | awk '{print $1}' | tail -n 1) ????mflibs::shell::text::gre en "updating ${m} with ${space_used}" ????quickbox::database "UPDATE user_mounts set space='${space_used}' WHERE username='${username}' AND mount='${m}';" ???do ne ???if [[ -d "/home/${username}/.config/rclone/" ]]; then ????mergerfs_service _mount=$(grep 'fuse.mergerfs' </proc/mounts | cut -d ' ' -f 2 | sed -e 's|/|-|g' | sed -ne 's|-||p' | grep "${username}") ????echo "${mergerfs_service_mount}" > "/home/${username}/.config/rclone/mergerfs_mount_service.txt" ????chown -R "${us ername}":"${username}" "/home/${username}/.config/rclone/" ????chmod 0664 "/home /${username}/.config/rclone/mergerfs_mount_service.txt" ???fi ???;; ??*) ;; ??es ac ?done } #################################################################### ############ # @description: manages backup, restore, and restore default for so ftware configs. # additionally handles the install/uninstall of rutorrent plugin s (see second example) # # notes: # - rtorrent requires no additional arguments (such as -u) as it is a system-wide # install and not user-specific (see last ex ample) # @arg: -o [backup|restore|default|] -u [username] -s [software] # @arg: -o [rutorrent] -o [install|remove] -rup [rutorrent_plugin_name] # @example: qb m anage software -o backup -u username -s softwarename # qb manage software -o bac kup -o app -u username -s softwarename # qb manage software -o rollback -o app - u username -s softwarename # qb manage software -o restore -u username -s softwa rename # qb manage software -o default -u username -s softwarename # qb manage s oftware -o rutorrent -o install -rup _cloudflare # @null # @example: qb manage s oftware -o backup -s rtorrent # @null ########################################## ###################################### software::settings() { ?declare software_ name ?software_name=$(quickbox::database "SELECT DISTINCT software_name from sof tware_information WHERE software_name = '${software:-}' LIMIT 1;") ?default_loca tion=$(quickbox::database "SELECT DISTINCT software_default_location from softwa re_information WHERE software_name = '${software:-}';") ?backup_location=$(quick box::database "SELECT DISTINCT software_backup_location from software_informatio n WHERE software_name = '${software_name}';") ?software_location=$(quickbox::dat abase "SELECT DISTINCT software_config_location from software_information WHERE software_name = '${software_name}';") ?software_title=$(quickbox::database "SELE CT DISTINCT software_title from software_information WHERE software_name = '${so ftware_name}';") ?# only set these variables if the software_name is not rtorren t OR rutorrent ?if [[ "${software_name}" != "rtorrent" ]]; then ??declare backup _version ??user_id=$(quickbox::database "SELECT id FROM user_information WHERE u sername='${username}';") ??backup_version=$(quickbox::database "SELECT DISTINCT software_version from user_software WHERE user_id = '${user_id:?}' AND software_ name = '${software_name}' LIMIT 1;") ??defaultConf="/home/${username:-}/.QuickBo x/software${default_location}" ??backupConf="/home/${username}/.QuickBox/softwar e${backup_location}" ??softwareConf="/home/${username}${software_location}" ?fi ?for option in "${qb_option[@]}"; do ??case "${option,,}" in ??backup) ???[[ "${ qb_option[*]}" =~ "vi=" ]] && declare skip_check=1 ???vi=$(grep -oP 'vi=\K.*' << <"${qb_option[*]}") ???if [[ "${software_name}" =~ "rtorrent" ]]; then ????read -d '' -ra users_all <<<"$(quickbox::database "SELECT username FROM user_informat ion")" ????for user in "${users_all:-[@]}"; do ?????[[ -z ${skip_check} ]] && mf libs::shell::text::white "$(quickbox::lang::backup::configf)" ?????declare time_ stamp ?????time_stamp=$(date '+%Y-%m-%d %H:%M') ?????package_date=${time_stamp// /_} ?????userid=$(quickbox::database "SELECT id FROM user_information WHERE use rname='${user}';") ?????backup_version=$(quickbox::database "SELECT DISTINCT sof tware_version from user_software WHERE user_id = '${userid:?}' AND software_name = '${software_name}' LIMIT 1;") ?????defaultConf="/home/${user:-}/.QuickBox/sof tware${default_location}" ?????backupConf="/home/${user}/.QuickBox/software${bac kup_location}" ?????softwareConf="/home/${user}${software_location}" ?????backup ="/home/${user}/.QuickBox/software/rtorrent/backup/" ?????mkdir -p "${backup}" & & cp -prf "${softwareConf}" "${backupConf}_${package_date}" && cp -prf "${backup Conf}_${package_date}" "${backupConf}" ?????find "/home/${user}/.QuickBox" -type d \( ! -user www-data -o ! -group www-data \) -print0 | xargs -0 chown www-data :www-data >/dev/null 2>&1 ?????find "/home/${user}/.QuickBox" -type d ! -perm 07 55 -print0 | xargs -0 chmod 0755 >/dev/null 2>&1 ?????[[ -z ${skip_check} ]] && mflibs::shell::text::green "$(quickbox::lang::backup::configf::success)" ????don e ???else ????[[ -z ${skip_check} ]] && mflibs::shell::text::white "$(quickbox:: lang::backup::configf)" ????if [[ ! -f ${softwareConf} ]]; then ?????mflibs::she ll::text::red "$(quickbox::lang::backup::configf::error)" ?????exit 1 ????fi ??? ?user_id=$(quickbox::database "SELECT id FROM user_information WHERE username='$ {username}';") ????backup_version=$(quickbox::database "SELECT DISTINCT software _version from user_software WHERE user_id = '${user_id:?}' AND software_name = ' ${software_name}' LIMIT 1;") ????defaultConf="/home/${username:-}/.QuickBox/soft ware${default_location}" ????backupConf="/home/${username}/.QuickBox/software${b ackup_location}" ????softwareConf="/home/${username}${software_location}" ????[[ "${software_name}" =~ "deluged" ]] && backup="/home/${username}/.QuickBox/softw are/deluge/backup/" ????[[ "${software_name}" != "deluged" ]] && backup="/home/$ {username}/.QuickBox/software/${software_name}/backup/" ????mkdir -p "${backup}" && cp -prf "${softwareConf}" "${backupConf}" ????find "/home/${username}/.Quick Box" -type d \( ! -user www-data -o ! -group www-data \) -print0 | xargs -0 chow n www-data:www-data >/dev/null 2>&1 ????find "/home/${username}/.QuickBox" -type d ! -perm 0755 -print0 | xargs -0 chmod 0755 >/dev/null 2>&1 ????[[ -z ${skip_c heck} ]] && mflibs::shell::text::green "$(quickbox::lang::backup::configf::succe ss)" ???fi ???# check if `-o app` is set, if so, backup the application install and config directories ???if [[ "${qb_option[*]}" =~ "app" ]]; then ????# set cu stom conditions for software installation directories ????if [[ "${software_name }" =~ "emby" ]]; then ?????install_directory="/opt/${username}/emby-server" ???? elif [[ "${software_name}" =~ "plex" ]]; then ?????install_directory="/usr/lib/p lexmediaserver" ????else ?????install_directory=$(find "/opt/${username}" -maxde pth 1 -type d -name "${software_title}" -printf '%f\n') ????fi ????if [[ -z "${i nstall_directory}" ]]; then ?????mflibs::shell::text::red "$(quickbox::lang::bac kup::installdir::error)" ?????exit 1 ????fi ????backup="/home/${username}/.Quick Box/software/${software_name}/backup/" ????mkdir -p "${backup}" && cp -prf "${so ftwareConf}" "${backupConf}" ????declare time_stamp package_date ????time_stamp= $(date '+%Y-%m-%d %H:%M') ????package_date=${time_stamp// /_} ????mflibs::shell: :text::white "$(quickbox::lang::backup::installdir)" ????# create a tarball of t he software installation directory ????if [[ "${software_name}" =~ "emby" || "${ software_name}" =~ "plex" ]]; then ?????tar -czf "${backup}/${software_name}-${b ackup_version}-application_${package_date}.tar.gz" -C "${install_directory}" . > /dev/null 2>&1 ????else ?????tar -czf "${backup}/${software_name}-${backup_versi on}-application_${package_date}.tar.gz" -C "/opt/${username}/${install_directory }" . >/dev/null 2>&1 ????fi ????mflibs::shell::text::white "$(quickbox::lang::ba ckup::configdir)" ????# create a tarball of the software configuration directory ????if [[ "${software_name}" =~ "emby" ]]; then ?????tar -czf "${backup}/${soft ware_name}-${backup_version}-config_${package_date}.tar.gz" -C "/home/${username }/.config/Emby" . >/dev/null 2>&1 ????elif [[ "${software_name}" =~ "plex" ]]; t hen ?????tar -czf "${backup}/${software_name}-${backup_version}-config_${package _date}.tar.gz" -C "/home/${username}/.config/Plex Media Server" . >/dev/null 2>& 1 ????elif [[ "${software_name}" =~ "jellyseerr" ]]; then ?????tar -czf "${backu p}/${software_name}-${backup_version}-config_${package_date}.tar.gz" -C "/opt/${ username}/Jellyseerr/config" . >/dev/null 2>&1 ????elif [[ "${software_name}" =~ "overseerr" ]]; then ?????tar -czf "${backup}/${software_name}-${backup_version }-config_${package_date}.tar.gz" -C "/opt/${username}/Overseerr/config" . >/dev/ null 2>&1 ????else ?????tar -czf "${backup}/${software_name}-${backup_version}-c onfig_${package_date}.tar.gz" -C "/home/${username}/.config/${software_title}" . >/dev/null 2>&1 ????fi ????find "/home/${username}/.QuickBox" -type d \( ! -use r www-data -o ! -group www-data \) -print0 | xargs -0 chown www-data:www-data >/ dev/null 2>&1 ????find "/home/${username}/.QuickBox" -type d ! -perm 0755 -print 0 | xargs -0 chmod 0755 >/dev/null 2>&1 ????chown www-data:www-data -R "${backup }/${software_name}"-*.tar.gz >/dev/null 2>&1 ????chown "${username}":"${username }" "${backupConf}" "${softwareConf}" ????quickbox::database "INSERT INTO softwar e_rollbacks ("username", "software_name", "software_version", "software_date") V ALUES ('${username}', '${software_name:-}', '${backup_version:-}', '${time_stamp :-}');" ????mflibs::shell::text::green "$(quickbox::lang::backup::installdir::su ccess)" ????unset time_stamp package_date backup_version software_name ???fi ??? ;; ??restore) ???if [[ ! -f ${backupConf} ]]; then ????mflibs::shell::text::red "$(quickbox::lang::restore::configf::error)" ???else ????cp -prf "${backupConf}" "${softwareConf}" ????find "/home/${username}/.QuickBox" -type d \( ! -user www -data -o ! -group www-data \) -print0 | xargs -0 chown www-data:www-data >/dev/n ull 2>&1 ????find "/home/${username}/.QuickBox" -type d ! -perm 0755 -print0 | x args -0 chmod 0755 >/dev/null 2>&1 ????chown "${username}":"${username}" "${back upConf}" "${softwareConf}" ????mflibs::shell::text::green "$(quickbox::lang::res tore::configf::success)" ???fi ???;; ??default) ???if [[ ! -f ${defaultConf} ]]; then ????mflibs::shell::text::red "$(quickbox::lang::default::configf::error)" ???else ????cp -prf "${defaultConf}" "${softwareConf}" ????find "/home/${usernam e}/.QuickBox" -type d \( ! -user www-data -o ! -group www-data \) -print0 | xarg s -0 chown www-data:www-data >/dev/null 2>&1 ????find "/home/${username}/.QuickB ox" -type d ! -perm 0755 -print0 | xargs -0 chmod 0755 >/dev/null 2>&1 ????chown "${username}":"${username}" "${backupConf}" "${softwareConf}" ????mflibs::shell ::text::green "$(quickbox::lang::default::configf::success)" ???fi ???;; ??rollb ack) ???if [[ "${qb_option[*]}" =~ "app" ]]; then ????user_id=$(quickbox::databa se "SELECT id FROM user_information WHERE username='${username}';") ????software _title=$(quickbox::database "SELECT DISTINCT software_title from software_inform ation WHERE software_name = '${software}';") ????software_service_name=$(quickbo x::database "SELECT DISTINCT software_service_name from software_information WHE RE software_name = '${software}';") ????backup_path="/home/${username}/.QuickBox /software/${software}/backup/" ????[[ -f "/etc/systemd/system/${software_service _name}@${username}.service" ]] && systemctl stop "${software_service_name}"@"${u sername}" >/dev/null 2>&1 ????[[ -f "/etc/systemd/system/${software_service_name }.service" ]] && systemctl stop "${software_service_name}" >/dev/null 2>&1 ????# set custom conditions for software directories on rollback ????if [[ "${softwar e}" =~ "emby" ]]; then ?????install_directory="/opt/${username}/emby-server" ??? ?elif [[ "${software}" =~ "plex" ]]; then ?????install_directory="/usr/lib/plexm ediaserver" ????else ?????install_directory=$(find "/opt/${username}" -maxdepth 1 -type d -name "${software_title}" -printf '%f\n') ????fi ????if [[ -z "${insta ll_directory}" ]]; then ?????mflibs::shell::text::red "$(quickbox::lang::rollbac k::installdir::error)" ?????exit 1 ????fi ????[[ "${qb_option[*]}" =~ "vi=" ]] & & declare skip_check=1 ????swvi=1 ????IFS=$'\n' read -d '' -ra backups <<<"$(qui ckbox::database "SELECT software_version,software_date from software_rollbacks W HERE software_name = '${software}' AND username = '${username}';")" ????backup_m enu=() ????for i in "${backups[@]}"; do ?????backup_version="$(echo "${i}" | cut -d '|' -f1)" ?????backup_date="$(echo "${i}" | cut -d '|' -f2-)" ?????backup_me nu+=(" ${swvi}) $(quickbox::lang::rollback::selection::version) ${backup_ver sion} $(quickbox::lang::rollback::selection::date) ${backup_date}") ?????swvi =$((swvi + 1)) ????done ????# display the menu ????mflibs::shell::text::white "$ (quickbox::lang::rollback::selection)" ????for backup_display in "${backup_menu[ @]}"; do ?????echo "${backup_display}" ????done ????# set the version from the s election ????declare -gi vi ????declare version ????if [[ ${skip_check} == 1 ]]; then ?????# set the vi= to the value in the -o vi= option ?????vi=$(grep -oP 'v i=\K.*' <<<"${qb_option[*]}") ????else ?????IFS=$'\n' read -r version_selection ?????vi=$(grep -oP "${version_selection}" <<<"${backup_menu[@]}" | grep -oP '[0- 9]*' | head -n 1) ????fi ????version=$(grep -oP 'version: \K.*(?= date)' <<<" ${backup_menu[$((vi - 1))]}") ????# set confirmation if input provided is correc t ????if [[ -z "${version}" ]]; then ?????mflibs::shell::text::red "$(quickbox:: lang::rollback::selection::invalid)" ?????IFS=$'\n' read -r version_selection ?? ??else ?????# show selection and confirmation request ?????declare selected_date app_package config_package ?????selected_date=$(grep -oP 'date: \K.*' <<<"${bac kup_menu[$((vi - 1))]}") ?????package_date=${selected_date// /_} ?????app_packag e=$(find "${backup_path}" -maxdepth 1 -type f -name "${software}-${version}-appl ication_${package_date}.tar.gz" -printf '%f\n') ?????if [[ -z "${app_package}" ] ]; then ??????mflibs::shell::text::red "$(quickbox::lang::rollback::software::er ror)" ??????exit 1 ?????fi ?????config_package=$(find "${backup_path}" -maxdepth 1 -type f -name "${software}-${version}-config_${package_date}.tar.gz" -printf '%f\n') ?????if [[ -z "${config_package}" ]]; then ??????mflibs::shell::text::re d "$(quickbox::lang::rollback::config::error)" ??????exit 1 ?????fi ?????mflibs: :shell::text::white "$(quickbox::lang::rollback::selection::display)" ?????if [[ -z ${skip_check} ]]; then ??????mflibs::shell::text::white "$(quickbox::lang::r ollback::selection::confirm)" ??????IFS=$'\n' read -r version_confirm ??????# lo op until a valid selection is made ??????while [[ "${version_confirm}" != "y" ]] && [[ "${version_confirm}" != "n" ]]; do ???????mflibs::shell::text::red "$(qui ckbox::lang::rollback::selection::invalid)" ???????IFS=$'\n' read -r version_con firm ??????done ??????# if the selection is no, exit the script ??????if [[ "${v ersion_confirm}" == "n" ]]; then ???????mflibs::shell::text::red "$(quickbox::la ng::rollback::cancelled)" ???????exit 0 ??????fi ?????fi ????fi ????# display co nfirmation of the version selection and proceed with the rollback ????mflibs::sh ell::text::white "$(quickbox::lang::rollback::continue)" ????# extract the tarba ll of the software installation directory ????if [[ "${software}" =~ "emby" || " ${software}" =~ "plex" ]]; then ?????tar -xzf "${backup_path}/${app_package}" -C "${install_directory}" >/dev/null 2>&1 ????else ?????tar -xzf "${backup_path}/$ {app_package}" -C "/opt/${username}/${install_directory}" >/dev/null 2>&1 ????fi ????# extract the tarball of the software configuration directory ????if [[ "${ software}" =~ "emby" ]]; then ?????tar -xzf "${backup_path}/${config_package}" - C "/home/${username}/.config/Emby" >/dev/null 2>&1 ?????chown "${username}":"${u sername}" -R "${install_directory}" "/home/${username}/.config/Emby" 2>&1 ????el if [[ "${software}" =~ "plex" ]]; then ?????tar -xzf "${backup_path}/${config_pa ckage}" -C "/home/${username}/.config/Plex Media Server" >/dev/null 2>&1 ?????ch own "${username}":"${username}" -R "${install_directory}" "/home/${username}/.co nfig/Plex Media Server" 2>&1 ????elif [[ "${software_name}" =~ "jellyseerr" ]]; then ?????tar -xzf "${backup_path}/${config_package}" -C "/opt/${username}/Jelly seerr/config" >/dev/null 2>&1 ?????chown "${username}":"${username}" -R "${insta ll_directory}" "/home/${username}/.config/Jellyseerr" 2>&1 ????elif [[ "${softwa re_name}" =~ "overseerr" ]]; then ?????tar -xzf "${backup_path}/${config_package }" -C "/opt/${username}/Overseerr/config" >/dev/null 2>&1 ?????chown "${username }":"${username}" -R "${install_directory}" "/home/${username}/.config/Overseerr" 2>&1 ????else ?????tar -xzf "${backup_path}/${config_package}" -C "/home/${user name}/.config/${software_title}" >/dev/null 2>&1 ?????chown "${username}":"${use rname}" -R "/opt/${username}/${install_directory}" "/home/${username}/.config/${ software_title}" 2>&1 ????fi ????quickbox::database "UPDATE user_software SET so ftware_version='${version}' WHERE software_name='${software}' AND user_id='${use r_id:?}';" ????[[ -f "/etc/systemd/system/${software_service_name}@${username}.s ervice" ]] && systemctl start "${software_service_name}"@"${username}" >/dev/nul l 2>&1 ????[[ -f "/etc/systemd/system/${software_service_name}.service" ]] && sy stemctl start "${software_service_name}" >/dev/null 2>&1 ????/usr/local/bin/qb s oftware check >/dev/null 2>&1 ????mflibs::shell::text::green "$(quickbox::lang:: rollback::complete)" ????unset version version_selection vi selected_date app_pa ckage config_package ???fi ???;; ??delete) ???if [[ "${qb_option[*]}" =~ "app" ] ]; then ????user_id=$(quickbox::database "SELECT id FROM user_information WHERE username='${username}';") ????software_title=$(quickbox::database "SELECT DISTIN CT software_title from software_information WHERE software_name = '${software}'; ") ????software_service_name=$(quickbox::database "SELECT DISTINCT software_serv ice_name from software_information WHERE software_name = '${software}';") ????ba ckup_path="/home/${username}/.QuickBox/software/${software}/backup/" ????install _directory=$(find "/opt/${username}" -maxdepth 1 -type d -name "${software_title }*" -printf '%f\n') ????config_directory=$(find "/home/${username}/.config" -max depth 1 -type d -name "${software_title}*" -printf '%f\n') ????[[ "${qb_option[* ]}" =~ "vi=" ]] && declare skip_check=1 ????swvi=1 ????IFS=$'\n' read -d '' -ra backups <<<"$(quickbox::database "SELECT software_version,software_date from sof tware_rollbacks WHERE software_name = '${software}' AND username = '${username}' ;")" ????backup_menu=() ????for i in "${backups[@]}"; do ?????backup_version="$( echo "${i}" | cut -d '|' -f1)" ?????backup_date="$(echo "${i}" | cut -d '|' -f2- )" ?????backup_menu+=(" ${swvi}) $(quickbox::lang::delete::selection::versio n) ${backup_version} $(quickbox::lang::delete::selection::date) ${backup_date }") ?????swvi=$((swvi + 1)) ????done ????# display the menu ????mflibs::shell::t ext::white "$(quickbox::lang::delete::selection)" ????for backup_display in "${b ackup_menu[@]}"; do ?????echo "${backup_display}" ????done ????# set the version from the selection ????declare -gi vi ????declare version ????if [[ ${skip_chec k} == 1 ]]; then ?????# set the vi= to the value in the -o vi= option ?????vi=$( grep -oP 'vi=\K.*' <<<"${qb_option[*]}") ????else ?????IFS=$'\n' read -r version _selection ?????vi=$(grep -oP "${version_selection}" <<<"${backup_menu[@]}" | gr ep -oP '[0-9]*' | head -n 1) ????fi ????version=$(grep -oP 'version: \K.*(?= date)' <<<"${backup_menu[$((vi - 1))]}") ????# set confirmation if input provide d is correct ????if [[ -z "${version}" ]]; then ?????mflibs::shell::text::red "$ (quickbox::lang::delete::selection::invalid)" ?????IFS=$'\n' read -r version_sel ection ????else ?????# show selection and confirmation request ?????declare sele cted_date app_package config_package ?????selected_date=$(grep -oP 'date: \K.*' <<<"${backup_menu[$((vi - 1))]}") ?????package_date=${selected_date// /_} ?????a pp_package=$(find "${backup_path}" -maxdepth 1 -type f -name "${software}-${vers ion}-application_${package_date}.tar.gz" -printf '%f\n') ?????config_package=$(f ind "${backup_path}" -maxdepth 1 -type f -name "${software}-${version}-config_${ package_date}.tar.gz" -printf '%f\n') ?????mflibs::shell::text::white "$(quickbo x::lang::delete::selection::display)" ?????if [[ -z ${skip_check} ]]; then ????? ?mflibs::shell::text::white "$(quickbox::lang::delete::selection::confirm)" ???? ??IFS=$'\n' read -r version_confirm ??????# loop until a valid selection is made ??????while [[ "${version_confirm}" != "y" ]] && [[ "${version_confirm}" != "n" ]]; do ???????mflibs::shell::text::red "$(quickbox::lang::delete::selection::in valid)" ???????IFS=$'\n' read -r version_confirm ??????done ??????# if the selec tion is no, exit the script ??????if [[ "${version_confirm}" == "n" ]]; then ??? ????mflibs::shell::text::red "$(quickbox::lang::delete::cancelled)" ???????exit 0 ??????fi ?????fi ????fi ????# display confirmation of the version selection an d proceed with the rollback ????mflibs::shell::text::white "$(quickbox::lang::de lete::continue)" && sleep 2 ????# remove the selected tarball of the software in stallation backup directory ????rm -f "${backup_path}/${app_package}" >/dev/null 2>&1 ????# remove the selected tarball of the software configuration backup dir ectory ????rm -f "${backup_path}/${config_package}" >/dev/null 2>&1 ????# remove the selected version/date from the database ????quickbox::database "DELETE FROM software_rollbacks WHERE software_name='${software}' AND username='${username}' AND software_version='${version}' AND software_date='${selected_date}';" ????mf libs::shell::text::green "$(quickbox::lang::delete::complete)" ????unset version version_selection vi selected_date app_package config_package ???fi ???;; ??rut orrent) ???plugin_vault_directory="/opt/quickbox/bin/software/rutorrent/plugins/ " ???plugin_install_directory="/srv/rutorrent/plugins" ???for option in "${qb_op tion[@]}"; do ????case "${option,,}" in ????install) ?????echo "accessing ${ruto rrent_plugin:-} in the plugin vault ... " ?????cd "${plugin_install_directory:-} " || { echo "${plugin_install_directory:-} does not exist" && exit; } ?????echo "installing ${rutorrent_plugin:-} plugin ... " ?????if [[ ${rutorrent_plugin:-} == "autodl-irssi" ]]; then ??????if [[ $(quickbox::software::count autodl) -eq 1 ]]; then ???????rm -rf "${plugin_vault_directory:-}autodl-irssi" ???????git clo ne https://lab.quickbox.io/jmsolo/autodl-rutorrent.git "${plugin_vault_directory :-}autodl-irssi" ??????else ???????echo "AutoDL-iRSSi is not installed on the sy stem, skipping." ??????fi ?????fi ?????for i in ${rutorrent_plugin:-}; do ?????? \cp -rf "${plugin_vault_directory:-}${i}" . ?????done ?????if [[ ${rutorrent_plu gin:-} == "_cloudflare" ]]; then ??????/usr/bin/python3 -m pip install --upgrade --exists-action s cloudscraper python_anticaptcha >/dev/null 2>&1 ??????\cp -f "/opt/quickbox/config/software/rutorrent/plugins/${rutorrent_plugin:-}/conf.php" "${plugin_install_directory:-}/${rutorrent_plugin:-}/conf.php" ?????fi ?????if [[ ${rutorrent_plugin:-} == "diskspace" ]]; then ??????\cp -f "/opt/quickbox/con fig/software/rutorrent/plugins/${rutorrent_plugin:-}/action.php" "${plugin_insta ll_directory:-}/${rutorrent_plugin:-}/action.php" ?????fi ?????if [[ ${rutorrent _plugin:-} == "filemanager-share" ]]; then ??????\cp -f "/opt/quickbox/config/so ftware/rutorrent/plugins/${rutorrent_plugin:-}/conf.php" "${plugin_install_direc tory:-}/${rutorrent_plugin:-}/conf.php" ?????fi ?????echo "adjusting permissions ... " ?????chown -R www-data: "${plugin_install_directory:-}/${rutorrent_plugin :-}" ?????echo "${rutorrent_plugin:-} plugin install complete!" ?????[[ ${qb_opt ion[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/null 2>&1 & ?????exit ?????;; ????remove) ?????echo "uninstalling the ${rutorrent_plugin:?} plugin .. . " ?????for i in ${rutorrent_plugin:-}; do ??????rm -rf "${plugin_install_direc tory:?}/${i}" ?????done ?????echo "${rutorrent_plugin:-} plugin uninstall comple te!" ?????[[ ${qb_option[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/ null 2>&1 & ?????exit ?????;; ????*) ;; ????esac ???done ???;; ??*) ;; ??esac ?d one } ######################################################################### ####### # @description: dashboard theme switching # @arg: -o [defaulted|smoked] # @example: qb manage theme -o smoked # @null ################################## ############################################## theme::settings() { ?for option i n "${qb_option[@]}"; do ??case "${option,,}" in ??smoked) ???sed -i -r 's/defaul ted.css/smoked.css/g' /srv/quickbox/assets/css/plugins.css ???sed -i -r 's/defau lted.css/smoked.css/g' /srv/quickbox/dash_header.php ???sed -i -r 's/defaulted.c ss/smoked.css/g' /srv/quickbox/assets/css/plugins_1.css ???rm -rf /srv/quickbox/ db/.theme_defaulted.lock ???printf "" >/srv/quickbox/db/.theme_smoked.lock ???ch own www-data:www-data /srv/quickbox/db/.theme_smoked.lock ???[[ ${qb_option[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/null 2>&1 & ???;; ??defaulted ) ???sed -i -r 's/smoked.css/defaulted.css/g' /srv/quickbox/assets/css/plugins.c ss ???sed -i -r 's/smoked.css/defaulted.css/g' /srv/quickbox/dash_header.php ??? sed -i -r 's/smoked.css/defaulted.css/g' /srv/quickbox/assets/css/plugins_1.css ???rm -rf /srv/quickbox/db/.theme_smoked.lock ???printf "" >/srv/quickbox/db/.th eme_defaulted.lock ???chown www-data:www-data /srv/quickbox/db/.theme_defaulted. lock ???[[ ${qb_option[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/nu ll 2>&1 & ???;; ??*) ;; ??esac ?done } ######################################## ######################################## # @description: manages blocking and al lowing of public trackers # @noargs ############################################ #################################### tracker::settings() { ?for option in "${qb_ option[@]}"; do ??case "${option,,}" in ??enable) ???mflibs::shell::text::red "$ (quickbox::lang::trackers::enable)" ???mflibs::log "/sbin/iptables -F qb-public- trackers" && mflibs::log "/sbin/iptables -X qb-public-trackers" ???awk 'NR==FNR{ a[$0];next} !($0 in a){print > FILENAME".filtered"}' "${quickbox_base_path}/conf ig/system/trackers/host_trackers" /etc/hosts ???mv -f "/etc/hosts.filtered" "/et c/hosts" ???rm -f /etc/cron.daily/deny_public ???;; ??disable) ???declare line ? ??mflibs::shell::text::green "$(quickbox::lang::trackers::disable)" ???cp -f "${ quickbox_base_path:="/opt/quickbox"}/config/system/trackers/deny_public" "/etc/c ron.daily/" ???chmod +x /etc/cron.daily/deny_public ???mflibs::log "/sbin/iptabl es -N qb-public-trackers" ???while IFS= read -r line; do ????mflibs::log "/sbin/ iptables -A qb-public-trackers -s ${line} -j DROP" ???done < <(grep -v '^ *#' <" ${quickbox_base_path:="/opt/quickbox"}/config/system/trackers/tracker_list") ??? awk 'NR==FNR{a[$0];next} !($0 in a){print > FILENAME".filtered"}' "${quickbox_ba se_path}/config/system/trackers/host_trackers" /etc/hosts ???mv -f "/etc/hosts.f iltered" "/etc/hosts" ???cat "${quickbox_base_path}/config/system/trackers/host_ trackers" >>/etc/hosts ???;; ??*) ;; ??esac ?done } ########################### ##################################################### # @description: sets the s erver web root for dashboard access # @arg: -o [server_ip (or) domain] # @exampl e: qb manage webroot -o 192.168.0.1 (or) myawesomedomain.com # @null ########### ##################################################################### webroot::s ettings() { ?quickbox::database "UPDATE system_configuration set configuration_v alue = 'https://${qb_option[*]:-}/' WHERE configuration_name='server_web_root';" ?mflibs::log "systemctl restart nginx.service" ?mflibs::log "systemctl reload p hp8.1-fpm.service" } ########################################################## ###################### # @description: calls functions in the required order ### ############################################################################# ma nage::environment::init "$@" # shellcheck disable=SC2068 quickbox::args::process $@ case "${1}" in api) ?api::settings ?;; fail2ban) ?fail2ban::settings ?;; lan g) ?lang::settings ?;; nginx) ?nginx::settings ?;; mount) ?mount::settings ?;; s oftware) ?software::settings ?;; trackers) ?tracker::settings ?;; theme) ?theme: :settings ?;; webroot) ?webroot::settings ?;; *) ;; esac /opt/quickbox/system/m anage mount manage mount -o space -u judgey root 188575 188538 0 12:30 ? 00:00:00 /opt/quickbox/system/manage -c #!/bin/bash ################################################# ############################### # <START METADATA> # @file_name: manage # @versi on: 1.0.452 # @project_name: quickbox_pro_v3 # @description: collection of manag e scripts # # @save_tasks: # automated_versioning: true # automated_documentat ion: true # # @build_tasks: # automated_comment_strip: true # automated_encryp tion: true # # @author: Jason Matthews (JMSolo) # @author_contact: support@quick box.io # @author: Jamie Dobbs (mschf) # @author_contact: jamie.dobbs@mschf.dev # # @license: BSD-3 Clause (Included in LICENSE) # Copyright (C) 2019-2023, Quick Box.IO # All rights reserved. # <END METADATA> # shellcheck disable=SC1091,SC203 4,SC2140,SC2165,SC2167,SC2312 ################################################## ############################## ################################################ ################################ # @description: sets up environment for command s # @noargs # @internal # @return_code: 1 script should be run via qb ########## ###################################################################### manage::e nvironment::init() { ?declare script_name ?script_name=$(basename -- "$0") ?[[ $ {qb_invoked:-0} -eq 0 ]] && { echo -ne "\033[38;5;203merror\e[0m[1]: ${script_na me} should be run via qb\n" >&2 && exit 1; } ?. "/opt/mflibs/src/init.sh" ?mflib s::import shell,quickbox,status,log,info } quickbox::dashboard::log() { ?admin_ name="$(quickbox::database "SELECT username FROM user_information WHERE user_lev el = '10';")" ?if [[ ! -f "/srv/quickbox/logs/dashboard" ]]; then ??mkdir -p /sr v/quickbox/logs ??touch /srv/quickbox/logs/dashboard ??chown www-data:www-data / srv/quickbox/logs/dashboard ?fi ?if [[ ! -f "/srv/quickbox/logs/${username:-${ad min_name}}.dashboard" ]]; then ??mkdir -p /srv/quickbox/logs ??touch "/srv/quick box/logs/${username:-${admin_name}}.dashboard" ??chown www-data:www-data "/srv/q uickbox/logs/${username:-${admin_name}}.dashboard" ?fi ?if [[ -n ${username} ]]; then ??echo "${1:-null}" | sed -z "s/\n/\n<br>/" >"/srv/quickbox/logs/${usernam e:-}.dashboard" ?else ??echo "${1:-null}" | sed -z "s/\n/\n<br>/" >"/srv/quickbo x/logs/${admin_name:-}.dashboard" ?fi ?echo "${1:-null}" } #################### ############################################################ # @description: man ages api key activation and deactivation # @noargs ############################# ################################################### api::settings() { ?######## ######################################################################## ?# @des cription: pulls information from database and quickbox.io ?# @noargs ?########## ###################################################################### ?api::var iable::assign() { ??declare mflibs_log_location="${quickbox_base_path:="/opt/qui ckbox"}/logs/system_log" ??declare -g api_activated api_activated_date api_key a pi_instance api_ip api_product_id api_code api_execution api_status api_activate d api_activations_remaining api_total_activations api_total_activations_purchase d ??declare api_json ??IFS=$'\n' read -d '' -ra api_array <<<"$(quickbox::databa se "SELECT configuration_name,configuration_value FROM system_configuration WHER E configuration_name = 'api_key' OR configuration_name = 'api_instance' OR confi guration_name = 'api_activated_date' OR configuration_name = 'api_product_id' OR configuration_name = 'api_activated' OR configuration_name = 'api_ip'")" ??for i in "${api_array[@]}"; do ???array_configuration_name="$(echo "${i}" | cut -d ' |' -f1)" ???array_configuration_value="$(echo "${i}" | cut -d '|' -f2-)" ???case "${array_configuration_name}" in ???api_key) api_key="${array_configuration_val ue}" ;; ???api_ip) api_ip="${array_configuration_value}" ;; ???api_product_id) a pi_product_id="${array_configuration_value}" ;; ???api_instance) api_instance="$ {array_configuration_value}" ;; ???api_activated_date) api_activated_date="${arr ay_configuration_value}" ;; ???*) ;; ???esac ??done ??api_json=$(curl -s4 -k "ht tps://quickbox.io/?wc-api=wc-am-api&product_id=${api_product_id}&object=${api_ip }&instance=${api_instance}&api_key=${api_key}&request=status") ??for value in $( jq 'keys | .[]' <<<"${api_json}"); do ???if [[ ${value} == '"code"' ]]; then ??? ?mflibs::shell::text::red "invalid response" ????api_code=$(jq -r ".${value}" << <"${api_json}") ????break ???elif [[ ${value} == '"api_call_execution_time"' ]]; then ????api_execution=$(jq -r ".${value}" <<<"${api_json}") ???elif [[ ${value } == '"status_check"' ]]; then ????api_status=$(jq -r ".${value}" <<<"${api_json }") ???elif [[ ${value} == '"data"' ]]; then ????for data_value in $(jq '.data | keys | .[]' <<<"${api_json}"); do ?????if [[ ${data_value} == '"activated"' ]]; then ??????api_activated=$(jq -r ".data.${data_value}" <<<"${api_json}") ?????e lif [[ ${data_value} == '"activations_remaining"' ]]; then ??????api_activations _remaining=$(jq -r ".data.${data_value}" <<<"${api_json}") ?????elif [[ ${data_v alue} == '"total_activations"' ]]; then ??????api_total_activations=$(jq -r ".da ta.${data_value}" <<<"${api_json}") ?????elif [[ ${data_value} == '"total_activa tions_purchased"' ]]; then ??????api_total_activations_purchased=$(jq -r ".data. ${data_value}" <<<"${api_json}") ?????fi ????done ???fi ??done ?} ?############ #################################################################### ?# @descrip tion: outputs api status in terminal window ?# @noargs ?######################## ######################################################## ?api::status::view() { ??column -ts '|' <<<"$( ???mflibs::shell::text::yellow "local information|" ???m flibs::shell::text::white::sl "api execution time:|" ???mflibs::shell::text::gre en::bold "${api_execution}" ???mflibs::shell::text::white::sl "api key:|" ???mfl ibs::shell::text::green::bold "${api_key}" ???mflibs::shell::text::white::sl "ap i activation date:|" ???mflibs::shell::text::green::bold "${api_activated_date}" ???mflibs::shell::text::white::sl "api ip:|" ???mflibs::shell::text::green::bol d "${api_ip}" ???mflibs::shell::text::white::sl "product id:|" ???mflibs::shell: :text::green::bold "${api_product_id}" ???mflibs::shell::text::white::sl "instan ce id:|" ???mflibs::shell::text::green::bold "${api_instance}" ???mflibs::shell: :misc::nl ???mflibs::shell::text::yellow "remote information|" ???mflibs::shell: :text::white::sl "api total activations:|" ???mflibs::shell::text::green::bold " ${api_total_activations}" ???mflibs::shell::text::white::sl "api activations rem aining:|" ???mflibs::shell::text::green::bold "${api_activations_remaining}" ??? mflibs::shell::text::white::sl "api activated:|" ???mflibs::shell::text::green:: bold "${api_activated}" ???mflibs::shell::text::white::sl "api status:|" ???mfli bs::shell::text::green::bold "${api_status}" ??)" ?} ?######################### ####################################################### ?# @description: deactiv ates api key ?# @noargs ?####################################################### ######################### ?api::key::deactivate() { ??declare deactivate_check ? ?if [[ ${api_force:-0} -eq "0" ]]; then ???mflibs::shell::misc::nl ???mflibs::sh ell::text::white::sl "deactivate api key? " ???mflibs::shell::text::green::sl "[ y]" ???mflibs::shell::text::white::sl "es " ???mflibs::shell::text::white "or [n ]o:" ???mflibs::shell::icon::arrow::white ???read -r input ???case "${input,,}" in ???[y] | [y][e][s] | "") : ;; ???*) exit 0 ;; ???esac ??fi ??deactivate_check =$(curl -s4 -k "https://quickbox.io/?wc-api=wc-am-api&product_id=${api_product_i d}&object=${api_ip}&instance=${api_instance}&api_key=${api_key}&request=deactiva te" | jq -r ".deactivated") ??if [[ ${api_force} -eq "0" ]]; then ???if [[ ${dea ctivate_check} == "true" ]]; then ????quickbox::database "UPDATE system_configur ation set configuration_value = 'false' WHERE configuration_name='api_activated' ;" ???else ????mflibs::shell::text::red "unable to deactivate api key" ???fi ??f i ?} ?######################################################################### ####### ?# @description: checks api key ?# @noargs ?############################ #################################################### ?api::key::check() { ??decl are check_status ??check_status=$(curl -s4 -k "https://quickbox.io/?wc-api=wc-am -api&product_id=${api_product_id}&object=${api_ip}&instance=${api_instance}&api_ key=${api_key}&request=status" | jq -r '.data."activated"') ??if [[ ${api_force} -eq "0" ]]; then ???if [[ ${check_status} == "true" ]]; then ????mflibs::shell: :text::green "api key is activated" ????quickbox::database "UPDATE system_config uration set configuration_value = 'true' WHERE configuration_name='api_activated ';" ????\cp -rf /opt/quickbox/dashboard/inc/plugins/nav/dash_navigation-pro.php /srv/quickbox/dash_navigation.php ???else ????mflibs::shell::text::red "api key is not activated" ????quickbox::database "UPDATE system_configuration set config uration_value = 'false' WHERE configuration_name='api_activated';" ????\cp -rf / opt/quickbox/dashboard/inc/plugins/nav/dash_navigation-community.php /srv/quickb ox/dash_navigation.php ???fi ??fi ?} ?######################################### ####################################### ?# @description: activates api key ?# @n oargs ?######################################################################### ####### ?api::key::activate() { ??if [[ ${api_force:-0} -eq "0" ]]; then ???mfli bs::shell::misc::nl ???mflibs::shell::text::white::sl "activate api key? " ???mf libs::shell::text::green::sl "[y]" ???mflibs::shell::text::white::sl "es " ???mf libs::shell::text::white "or [n]o:" ???mflibs::shell::icon::arrow::white ???read -r input ???case "${input,,}" in ???[y] | [y][e][s] | "") : ;; ???*) exit 0 ;; ???esac ??fi ??declare -a product_codes ??declare api_instance api_date product public_ip api_key quickbox_version ??api_date=$(date +"%b %d, %Y %l:%M") ??publi c_ip=$(mflibs::info::ipv4::local) ??api_instance=$(date +%s | sha256sum | base64 | head -c 16) ??product_codes=("13256" "24449" "24450" "24451" "24452" "13257" "24453" "24454" "24455" "24456" "13324" "349206") ??quickbox_version=$(quickbox: :database "SELECT configuration_value FROM system_configuration WHERE configurat ion_name = 'server_current_version'") ??if [[ -z ${man_api_key:-} ]]; then ???mf libs::shell::misc::nl ???mflibs::shell::text::white "enter api key: " ???mflibs: :shell::icon::arrow::white ???read -r api_key ??fi ??for product in "${product_c odes[@]}"; do ???api_activated=$(curl -s4 -k "https://quickbox.io/?wc-api=wc-am- api&product_id=${product}&object=${public_ip}&version=${quickbox_version}&instan ce=${api_instance}&api_key=${man_api_key:-${api_key}}&request=activate" | grep - Eoi '"activated":true' | cut -d: -f2-) ???if [[ ${api_activated} == "true" ]]; t hen ????api_product_id="${product}" ????break ???fi ??done ??[[ ${api_activated} != "true" ]] && mflibs::shell::text::red "invalid api key; please contact suppo rt" && api::environment::cleanup ??quickbox::database "WITH Tmp(configuration_na me, configuration_value) AS (VALUES ('api_activated', 'true'), ('api_activated_d ate', '${api_date}'),('api_key', '${man_api_key:-${api_key}}'), ('api_instance', '${api_instance}'), ('api_ip', '${public_ip}'), ('api_product_id', '${api_produ ct_id}')) UPDATE system_configuration SET configuration_value = (SELECT configur ation_value FROM Tmp WHERE system_configuration.configuration_name = Tmp.configu ration_name) WHERE configuration_name IN (SELECT configuration_name FROM Tmp);" ??if [[ -z ${api_force} ]]; then ???mflibs::shell::misc::nl ???mflibs::shell::te xt::green "api key has been activated" ???mflibs::shell::misc::nl ??fi ?} ?api: :variable::assign ?if [[ ${qb_option[*]:-} == *"deactivate"* || -n ${man_api_key } ]]; then ??[[ ${qb_option[*]:-} == *"force"* || -n ${man_api_key} ]] && declar e -gi api_force=1 ??api::key::deactivate ??api::key::activate ??api::variable::a ssign ?elif [[ ${qb_option[*]:-} == *"check"* ]]; then ??api::key::check ?elif [ [ ${api_code} != "100" ]]; then ??api::status::view ??api::key::deactivate ??api ::key::activate ?fi ?if [[ ${qb_option[*]:-} == *"deactivate"* ]]; then ??quickb ox::database "INSERT INTO system_log ("user_id", "log_source", "log_type", "log_ operation", "timestamp") VALUES ('${user_id:-1}', 'qb manage api -o deactivate . ..', 'system', 'DEACTIVATE_QUICKBOX_API', '$(date +"%Y-%m-%d %H:%M:%S")');" ?eli f [[ ${qb_option[*]:-} == *"activate"* ]]; then ??quickbox::database "INSERT INT O system_log ("user_id", "log_source", "log_type", "log_operation", "timestamp") VALUES ('${user_id:-1}', 'qb manage api -o activate ...', 'system', 'ACTIVATE_Q UICKBOX_API', '$(date +"%Y-%m-%d %H:%M:%S")');" ?elif [[ ${qb_option[*]:-} == *" check"* ]]; then ??: ?else ??quickbox::database "INSERT INTO system_log ("user_i d", "log_source", "log_type", "log_operation", "timestamp") VALUES ('${user_id:- 1}', 'qb manage api', 'system', 'ACTIVATION_INFO_STATS', '$(date +"%Y-%m-%d %H:% M:%S")');" ?fi } ############################################################## ################## # @description: manages fail2ban settings on the server # @no args # @example: qb manage fail2ban -o [config|unban] # @null ################## ############################################################## fail2ban::setting s() { ?for option in "${qb_option[@]}"; do ??case "${option,,}" in ??"config") ? ??fail2ban_dir="/etc/fail2ban/" ???if [[ ! -d ${fail2ban_dir} ]]; then ????mflib s::shell::text::red "Fail2ban is not installed. Would you like to install this? [y/N]:" ????echo -en "> " ????read -r input ????case ${input} in ????[yY] | [yY] [Ee][Ss]) ?????/usr/local/bin/qb install fail2ban ?????exit 1 ?????;; ????[nN] | [nN][Oo]) ?????mflibs::shell::text::red "Exiting Script." && exit 1 ?????;; ??? ?*) ?????mflibs::shell::text::red "Exiting Script." && exit 1 ?????;; ????esac ? ??fi ???mflibs::shell::text::white "Ban time for incorrect login (Default 10m) [ 5m/3h/12d]:" ???unset input ???echo -en "> " ???read -r input ???bantime="${inpu t//[^0-9]*/}" ???if [[ ${input} == "" ]]; then ????bantime=600 ???elif [[ ${inpu t} == *"m" ]]; then ????bantime=$((bantime * 60)) ???elif [[ ${input} == *"h" ]] ; then ????bantime=$((bantime * 60 * 60)) ???elif [[ ${input} == *"d" ]]; then ? ???bantime=$((bantime * 60 * 60 * 12)) ???fi ???mflibs::shell::text::white "Time between incorrect logins for ban (Default 10m) [5m/3h/12d]:" ???unset input ??? echo -en "> " ???read -r input ???findtime="${input//[^0-9]*/}" ???if [[ ${input } == "" ]]; then ????findtime=600 ???elif [[ ${input} == *"m" ]]; then ????findt ime=$((findtime * 60)) ???elif [[ ${input} == *"h" ]]; then ????findtime=$((find time * 60 * 60)) ???elif [[ ${input} == *"d" ]]; then ????findtime=$((findtime * 60 * 60 * 12)) ???fi ???mflibs::shell::text::white "Max number of retries withi n time (Default 5):" ???unset input ???echo -en "> " ???read -r input ???maxretr y="${input//[^0-9]*/}" ???if [[ ${input} == "" ]]; then ????maxretry=5 ???fi ??? mflibs::shell::text::white "IPs ignored by fail2ban (Default none) [1.1.1.1,2.2. 2.2]" ???mflibs::shell::text::green "Your IP is $(who am i | awk '{ print $5}' | tr -d '()'):" ???unset input ???echo -en "> " ???read -r input ???ignoreip="${i nput}" ???mflibs::shell::text::white "Monitor SSH Logins? ([y]/n):" ???unset inp ut ???echo -en "> " ???read -r input ???case ${input} in ???[yY] | [yY][Ee][Ss]) ????SSH="true" ????;; ???[nN] | [nN][Oo]) ????SSH="false" ????;; ???*) ????SSH= "true" ????;; ???esac ???mflibs::shell::text::white "Monitor Nginx Logins? ([y]/ n):" ???unset input ???echo -en "> " ???read -r input ???case ${input} in ???[yY ] | [yY][Ee][Ss]) ????nginx="true" ????;; ???[nN] | [nN][Oo]) ????nginx="false" ????;; ???*) ????nginx="true" ????;; ???esac ???mflibs::shell::text::white "Moni tor QuickBox Logins? ([y]/n):" ???unset input ???echo -en "> " ???read -r input ???case ${input} in ???[yY] | [yY][Ee][Ss]) ????quickbox="true" ????;; ???[nN] | [nN][Oo]) ????quickbox="false" ????;; ???*) ????quickbox="true" ????;; ???esac ???mflibs::shell::text::white "Applying Configuration..." ???\cp -f "/opt/quickb ox/config/software/fail2ban/quickbox.conf" "/etc/fail2ban/filter.d/quickbox.conf " ???if [[ -f "/etc/fail2ban/jail.local" ]]; then ????\cp -f "/etc/fail2ban/jail .local" "/etc/fail2ban/jail.bak" ???fi ???\cp -f "/opt/quickbox/config/software/ fail2ban/jail.local" "/etc/fail2ban/jail.local" ???sed -i -e "s/IGNORE_CONFIG/${ ignoreip}/g" /etc/fail2ban/jail.local -e "s/BANTIME_CONFIG/${bantime}/g" /etc/fa il2ban/jail.local -e "s/FINDTIME_CONFIG/${findtime}/g" /etc/fail2ban/jail.local -e "s/RETRY_CONFIG/${maxretry}/g" /etc/fail2ban/jail.local -e "s/SSHD_CONFIG/${S SH}/g" /etc/fail2ban/jail.local -e "s/NGINX_CONFIG/${nginx}/g" /etc/fail2ban/jai l.local -e "s/QUICKBOX_CONFIG/${quickbox}/g" /etc/fail2ban/jail.local ???mflibs: :log "systemctl restart fail2ban" ???mflibs::shell::text::green "Configuration a pplied" ???;; ??"unban") ???fail2ban_dir="/etc/fail2ban/" ???if [[ ! -d ${fail2b an_dir} ]]; then ????mflibs::shell::text::red "Fail2ban is not installed. Would you like to install this? [y/N]:" ????echo -en "> " ????read -r input ????case $ {input} in ????[yY] | [yY][Ee][Ss]) ?????/usr/local/bin/qb install fail2ban ???? ?exit 1 ?????;; ????[nN] | [nN][Oo]) ?????mflibs::shell::text::red "Exiting Scri pt." && exit 1 ?????;; ????*) ?????mflibs::shell::text::red "Exiting Script." && exit 1 ?????;; ????esac ???fi ???fail2banjails=$(fail2ban-client status | grep "Jail list" | cut -f2- | sed 's/,//g') ???mflibs::shell::text::white "Unbanning ${option}..." ???for jails in ${fail2banjails}; do ????fail2ban-client set "${ja ils}" unbanip "${option}" >/dev/null 2>&1 ???done ???mflibs::shell::text::green "${option} unbanned." ???;; ??"inclog") ???# trunk-ignore(shellcheck/SC2001) ??? ip=$(echo "${domain}" | sed 's/\s//g') ???echo "${ip} -- [$(date +%d)/$(date +%b )/$(date +%Y):$(date +%H):$(date +%M):$(date +%S)] -- Failed Login - ${username} " >>/srv/quickbox/logs/fail2ban.log ???;; ??*) ???mflibs::shell::text::red "Inva lid option: ${option}" ???;; ??esac ?done } ################################## ############################################## # @description: manages language settings on the server # @arg: -o [de|german|dk|danish|en|english|es|spanish|fr| french|pt|portuguese|zh-cn|chinese] # @example: qb manage lang -o en(or english) # @null ####################################################################### ######### lang::settings() { ?declare language code_name ?declare -g quickbox_ba se_path="/opt/quickbox" ?code_name=$(lsb_release -cs) ?for lang in "${qb_option[ @]}"; do ??case "${lang,,}" in ??de | german*) ???source /root/.bashrc ???declar e -g locale_sed quickbox_lang ???locale_sed=de_DE ???quickbox_lang=de ???cp -f " ${quickbox_base_path}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/localize.php" "/sr v/quickbox/inc/localize.php" ???sed -i -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UT F-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8/s/^#*/#/g' -e '/zh_C N.UTF-8/s/^#*/#/g' -e 's/^#.*\(de_DE.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>& 1 ???#sudo locale-gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-fil e=/etc/default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend nonint eractive locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??dk | danish*) ? ??source /root/.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=da_D K ???quickbox_lang=dk ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lan g}/locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${q uickbox_lang}/localize.php" "/srv/quickbox/inc/localize.php" ???sed -i -e '/de_D E.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/ pt_PT.UTF-8/s/^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(da_DK.UTF-8\)/\1/ ' /etc/locale.gen >/dev/null 2>&1 ???#sudo locale-gen --purge >/dev/null 2>&1 ?? ?sudo update-locale --locale-file=/etc/default/locale >/dev/null 2>&1 ???sudo dp kg-reconfigure --frontend noninteractive locales >/dev/null 2>&1 ???source /root /.bashrc ???;; ??en | english*) ???source /root/.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=en_US ???quickbox_lang=en ???cp -f "${quickbox_base _path}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${qu ickbox_base_path}/config/lang/${quickbox_lang}/localize.php" "/srv/quickbox/inc/ localize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8/s/^#*/# /g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(en_US.UTF-8\)/\1/' /etc/locale.gen ? ??#sudo locale-gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-file=/ etc/default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend nonintera ctive locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??es | spanish*) ??? source /root/.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=es_ES ???quickbox_lang=es ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang} /locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${qui ckbox_lang}/localize.php" "/srv/quickbox/inc/localize.php" ???sed -i -e '/de_DE. UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt _PT.UTF-8/s/^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(es_ES.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>&1 ???#sudo locale-gen --purge >/dev/null 2>&1 ???s udo update-locale --locale-file=/etc/default/locale >/dev/null 2>&1 ???sudo dpkg -reconfigure --frontend noninteractive locales >/dev/null 2>&1 ???source /root/. bashrc ???;; ??fr | french*) ???source /root/.bashrc ???declare -g locale_sed qu ickbox_lang ???locale_sed=fr_FR ???quickbox_lang=fr ???cp -f "${quickbox_base_pa th}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${quick box_base_path}/config/lang/${quickbox_lang}/localize.php" "/srv/quickbox/inc/loc alize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8/s/^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(fr_FR.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>&1 ???#sudo locale- gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-file=/etc/default/loc ale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend noninteractive locales > /dev/null 2>&1 ???source /root/.bashrc ???;; ??pt | portuguese*) ???source /root /.bashrc ???declare -g locale_sed quickbox_lang ???locale_sed=pt_PT ???quickbox_ lang=pt ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/locale" "/e tc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/ localize.php" "/srv/quickbox/inc/localize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/ #/g' -e '/da_DK.UTF-8/s/^#*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/ ^#*/#/g' -e '/zh_CN.UTF-8/s/^#*/#/g' -e 's/^#.*\(pt_PT.UTF-8\)/\1/' /etc/locale. gen >/dev/null 2>&1 ???#sudo locale-gen --purge >/dev/null 2>&1 ???sudo update-l ocale --locale-file=/etc/default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend noninteractive locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??zh-cn | chinese*) ???source /root/.bashrc ???declare -g locale_sed quickbox_l ang ???locale_sed=zh_CN ???quickbox_lang=zh-cn ???mflibs::log "apt-get -y instal l language-pack-zh-hans language-pack-zh-hans-base fonts-noto" ???cp -f "${quick box_base_path}/config/lang/${quickbox_lang}/locale" "/etc/default/locale" ???cp -f "${quickbox_base_path}/config/lang/${quickbox_lang}/localize.php" "/srv/quick box/inc/localize.php" ???sed -i -e '/de_DE.UTF-8/s/^#*/#/g' -e '/da_DK.UTF-8/s/^ #*/#/g' -e '/es_ES.UTF-8/s/^#*/#/g' -e '/fr_FR.UTF-8/s/^#*/#/g' -e '/pt_PT.UTF-8 /s/^#*/#/g' -e 's/^#.*\(zh_CN.UTF-8\)/\1/' /etc/locale.gen >/dev/null 2>&1 ???#s udo locale-gen --purge >/dev/null 2>&1 ???sudo update-locale --locale-file=/etc/ default/locale >/dev/null 2>&1 ???sudo dpkg-reconfigure --frontend noninteractiv e locales >/dev/null 2>&1 ???source /root/.bashrc ???;; ??*) ;; ??esac ?done ?if [[ -n ${locale_sed} ]]; then ??sed -i -e 's/thousands_sep.*/thousands_sep \"<U002C>\"/' "/usr/share/i18n/locales/${locale_sed}" ??[[ ${code_name} = = "stretch" ]] && sed -i -e 's/decimal_point.*/decimal_point \"<U002 C>\"/' "/usr/share/i18n/locales/${locale_sed}" ?fi ?chown www-data: /srv/quickbo x/inc/localize.php ?#mflibs::log "dpkg-reconfigure --frontend noninteractive loc ales" ?quickbox::database "UPDATE system_configuration set configuration_value = '${quickbox_lang}' WHERE configuration_name = 'server_language';" ?#mflibs::log "systemctl reload nginx" ?mflibs::log "systemctl reload php8.1-fpm > /dev/null 2>&1 &" ?mflibs::log "systemctl reload memcached > /dev/null 2>&1 &" } ######## ######################################################################## # @desc ription: manages backup, restore, and restore default for software configs # @ar g: -o [disable|enable|backup|restore|default] -u [username] -s [software] # @exa mple: qb manage nginx -o backup -s softwarename -u username # @null ############ #################################################################### nginx::sett ings() { ?if [[ ${software:?} == "netdata" || ${software:?} == "nextcloud" || ${ software:?} == "rutorrent" || ${software:?} == "tautulli" || ${software:?} == "t helounge" || ${software:?} == "transmission" || ${software:?} == "webconsole" || ${software:?} == "znc" ]]; then ??software_nginx="/etc/nginx/software/${softwar e:-}.conf" ??software_backup_nginx="/home/${username:?}/.QuickBox/software/${sof tware}/backup/nginx/${software}.conf" ??software_default_nginx="/home/${username }/.QuickBox/software/${software}/default/nginx/${software}.conf" ?else ??softwar e_nginx="/etc/nginx/software/${username:?}.${software:-}.conf" ??software_backup _nginx="/home/${username}/.QuickBox/software/${software}/backup/nginx/${username }.${software}.conf" ??software_default_nginx="/home/${username}/.QuickBox/softwa re/${software}/default/nginx/${username}.${software}.conf" ?fi ?for option in "$ {qb_option[@]}"; do ??case "${option,,}" in ??disable) ???mflibs::shell::text::w hite "disabling auth login on ${software} nginx reverse." ???if [[ ! -f ${softwa re_nginx} ]]; then ????mflibs::shell::text::red "nginx file [${software_nginx}] does not exist." ???else ????sed -i '/auth_basic/s/^#*/#/g' "${software_nginx}" ????mflibs::log "systemctl reload nginx.service" ????mflibs::shell::text::green "nginx auth has been disabled." ???fi ???;; ??enable) ???mflibs::shell::text::wh ite "enabling auth login on ${software} nginx reverse." ???if [[ ! -f ${software _nginx} ]]; then ????mflibs::shell::text::red "nginx file [${software_nginx}] do es not exist." ???else ????sed -i '/auth_basic/s/^#*//g' "${software_nginx}" ??? ?mflibs::log "systemctl reload nginx.service" ????mflibs::shell::text::green "ng inx auth has been enabled." ???fi ???;; ??backup) ???mflibs::shell::text::white "nginx file for ${software} is now being backed up." ???if [[ ! -f ${software_ng inx} ]]; then ????mflibs::shell::text::red "nginx file [${software_nginx}] does not exist." ???else ????mkdir -p "/home/${username}/.QuickBox/software/${softwar e}/backup/nginx/" ????\cp -pf "${software_nginx}" "${software_backup_nginx}" ??? ?mflibs::shell::text::green "configuration file has been backed up." ???fi ???;; ??restore) ???if [[ ! -f ${software_backup_nginx} ]]; then ????mflibs::shell::t ext::red "nginx file [${software_backup_nginx}] does not exist." ???else ????\cp -pf "${software_backup_nginx}" "${software_nginx}" ????mflibs::shell::text::gre en "backed up configuration file has been restored." ???fi ???;; ??default) ???i f [[ ! -f ${software_default_nginx} ]]; then ????mflibs::shell::text::red "deful t nginx file [${software_default_nginx}] does not exist." ???else ????\cp -pf "$ {software_default_nginx}" "${software_nginx}" ????mflibs::shell::text::green "de fault configuration file has been restored." ???fi ???;; ??*) ;; ??esac ?done } ############################################################################### # # @description: manages directory/mount checks # @arg: -o space -u [username] # @example: qb manage mount -o space -u username # @null ####################### ######################################################### mount::settings() { ?f or option in "${qb_option[@]}"; do ??case "${option,,}" in ??space) ???read -d ' ' -ra mount_path <<<"$(quickbox::database "SELECT mount FROM user_mounts WHERE u sername='${username}';")" ???for m in "${mount_path[@]}"; do ????# if mount path is '/' use `df -B1` instead ????[[ ${m} == "/" ]] && space_used=$(df -B1 | grep -w "/" | awk '{print $3}' | tail -n 1) ????[[ ${m} != "/" ]] && space_used=$(du -ac --bytes "${m}" | awk '{print $1}' | tail -n 1) ????mflibs::shell::text::gre en "updating ${m} with ${space_used}" ????quickbox::database "UPDATE user_mounts set space='${space_used}' WHERE username='${username}' AND mount='${m}';" ???do ne ???if [[ -d "/home/${username}/.config/rclone/" ]]; then ????mergerfs_service _mount=$(grep 'fuse.mergerfs' </proc/mounts | cut -d ' ' -f 2 | sed -e 's|/|-|g' | sed -ne 's|-||p' | grep "${username}") ????echo "${mergerfs_service_mount}" > "/home/${username}/.config/rclone/mergerfs_mount_service.txt" ????chown -R "${us ername}":"${username}" "/home/${username}/.config/rclone/" ????chmod 0664 "/home /${username}/.config/rclone/mergerfs_mount_service.txt" ???fi ???;; ??*) ;; ??es ac ?done } #################################################################### ############ # @description: manages backup, restore, and restore default for so ftware configs. # additionally handles the install/uninstall of rutorrent plugin s (see second example) # # notes: # - rtorrent requires no additional arguments (such as -u) as it is a system-wide # install and not user-specific (see last ex ample) # @arg: -o [backup|restore|default|] -u [username] -s [software] # @arg: -o [rutorrent] -o [install|remove] -rup [rutorrent_plugin_name] # @example: qb m anage software -o backup -u username -s softwarename # qb manage software -o bac kup -o app -u username -s softwarename # qb manage software -o rollback -o app - u username -s softwarename # qb manage software -o restore -u username -s softwa rename # qb manage software -o default -u username -s softwarename # qb manage s oftware -o rutorrent -o install -rup _cloudflare # @null # @example: qb manage s oftware -o backup -s rtorrent # @null ########################################## ###################################### software::settings() { ?declare software_ name ?software_name=$(quickbox::database "SELECT DISTINCT software_name from sof tware_information WHERE software_name = '${software:-}' LIMIT 1;") ?default_loca tion=$(quickbox::database "SELECT DISTINCT software_default_location from softwa re_information WHERE software_name = '${software:-}';") ?backup_location=$(quick box::database "SELECT DISTINCT software_backup_location from software_informatio n WHERE software_name = '${software_name}';") ?software_location=$(quickbox::dat abase "SELECT DISTINCT software_config_location from software_information WHERE software_name = '${software_name}';") ?software_title=$(quickbox::database "SELE CT DISTINCT software_title from software_information WHERE software_name = '${so ftware_name}';") ?# only set these variables if the software_name is not rtorren t OR rutorrent ?if [[ "${software_name}" != "rtorrent" ]]; then ??declare backup _version ??user_id=$(quickbox::database "SELECT id FROM user_information WHERE u sername='${username}';") ??backup_version=$(quickbox::database "SELECT DISTINCT software_version from user_software WHERE user_id = '${user_id:?}' AND software_ name = '${software_name}' LIMIT 1;") ??defaultConf="/home/${username:-}/.QuickBo x/software${default_location}" ??backupConf="/home/${username}/.QuickBox/softwar e${backup_location}" ??softwareConf="/home/${username}${software_location}" ?fi ?for option in "${qb_option[@]}"; do ??case "${option,,}" in ??backup) ???[[ "${ qb_option[*]}" =~ "vi=" ]] && declare skip_check=1 ???vi=$(grep -oP 'vi=\K.*' << <"${qb_option[*]}") ???if [[ "${software_name}" =~ "rtorrent" ]]; then ????read -d '' -ra users_all <<<"$(quickbox::database "SELECT username FROM user_informat ion")" ????for user in "${users_all:-[@]}"; do ?????[[ -z ${skip_check} ]] && mf libs::shell::text::white "$(quickbox::lang::backup::configf)" ?????declare time_ stamp ?????time_stamp=$(date '+%Y-%m-%d %H:%M') ?????package_date=${time_stamp// /_} ?????userid=$(quickbox::database "SELECT id FROM user_information WHERE use rname='${user}';") ?????backup_version=$(quickbox::database "SELECT DISTINCT sof tware_version from user_software WHERE user_id = '${userid:?}' AND software_name = '${software_name}' LIMIT 1;") ?????defaultConf="/home/${user:-}/.QuickBox/sof tware${default_location}" ?????backupConf="/home/${user}/.QuickBox/software${bac kup_location}" ?????softwareConf="/home/${user}${software_location}" ?????backup ="/home/${user}/.QuickBox/software/rtorrent/backup/" ?????mkdir -p "${backup}" & & cp -prf "${softwareConf}" "${backupConf}_${package_date}" && cp -prf "${backup Conf}_${package_date}" "${backupConf}" ?????find "/home/${user}/.QuickBox" -type d \( ! -user www-data -o ! -group www-data \) -print0 | xargs -0 chown www-data :www-data >/dev/null 2>&1 ?????find "/home/${user}/.QuickBox" -type d ! -perm 07 55 -print0 | xargs -0 chmod 0755 >/dev/null 2>&1 ?????[[ -z ${skip_check} ]] && mflibs::shell::text::green "$(quickbox::lang::backup::configf::success)" ????don e ???else ????[[ -z ${skip_check} ]] && mflibs::shell::text::white "$(quickbox:: lang::backup::configf)" ????if [[ ! -f ${softwareConf} ]]; then ?????mflibs::she ll::text::red "$(quickbox::lang::backup::configf::error)" ?????exit 1 ????fi ??? ?user_id=$(quickbox::database "SELECT id FROM user_information WHERE username='$ {username}';") ????backup_version=$(quickbox::database "SELECT DISTINCT software _version from user_software WHERE user_id = '${user_id:?}' AND software_name = ' ${software_name}' LIMIT 1;") ????defaultConf="/home/${username:-}/.QuickBox/soft ware${default_location}" ????backupConf="/home/${username}/.QuickBox/software${b ackup_location}" ????softwareConf="/home/${username}${software_location}" ????[[ "${software_name}" =~ "deluged" ]] && backup="/home/${username}/.QuickBox/softw are/deluge/backup/" ????[[ "${software_name}" != "deluged" ]] && backup="/home/$ {username}/.QuickBox/software/${software_name}/backup/" ????mkdir -p "${backup}" && cp -prf "${softwareConf}" "${backupConf}" ????find "/home/${username}/.Quick Box" -type d \( ! -user www-data -o ! -group www-data \) -print0 | xargs -0 chow n www-data:www-data >/dev/null 2>&1 ????find "/home/${username}/.QuickBox" -type d ! -perm 0755 -print0 | xargs -0 chmod 0755 >/dev/null 2>&1 ????[[ -z ${skip_c heck} ]] && mflibs::shell::text::green "$(quickbox::lang::backup::configf::succe ss)" ???fi ???# check if `-o app` is set, if so, backup the application install and config directories ???if [[ "${qb_option[*]}" =~ "app" ]]; then ????# set cu stom conditions for software installation directories ????if [[ "${software_name }" =~ "emby" ]]; then ?????install_directory="/opt/${username}/emby-server" ???? elif [[ "${software_name}" =~ "plex" ]]; then ?????install_directory="/usr/lib/p lexmediaserver" ????else ?????install_directory=$(find "/opt/${username}" -maxde pth 1 -type d -name "${software_title}" -printf '%f\n') ????fi ????if [[ -z "${i nstall_directory}" ]]; then ?????mflibs::shell::text::red "$(quickbox::lang::bac kup::installdir::error)" ?????exit 1 ????fi ????backup="/home/${username}/.Quick Box/software/${software_name}/backup/" ????mkdir -p "${backup}" && cp -prf "${so ftwareConf}" "${backupConf}" ????declare time_stamp package_date ????time_stamp= $(date '+%Y-%m-%d %H:%M') ????package_date=${time_stamp// /_} ????mflibs::shell: :text::white "$(quickbox::lang::backup::installdir)" ????# create a tarball of t he software installation directory ????if [[ "${software_name}" =~ "emby" || "${ software_name}" =~ "plex" ]]; then ?????tar -czf "${backup}/${software_name}-${b ackup_version}-application_${package_date}.tar.gz" -C "${install_directory}" . > /dev/null 2>&1 ????else ?????tar -czf "${backup}/${software_name}-${backup_versi on}-application_${package_date}.tar.gz" -C "/opt/${username}/${install_directory }" . >/dev/null 2>&1 ????fi ????mflibs::shell::text::white "$(quickbox::lang::ba ckup::configdir)" ????# create a tarball of the software configuration directory ????if [[ "${software_name}" =~ "emby" ]]; then ?????tar -czf "${backup}/${soft ware_name}-${backup_version}-config_${package_date}.tar.gz" -C "/home/${username }/.config/Emby" . >/dev/null 2>&1 ????elif [[ "${software_name}" =~ "plex" ]]; t hen ?????tar -czf "${backup}/${software_name}-${backup_version}-config_${package _date}.tar.gz" -C "/home/${username}/.config/Plex Media Server" . >/dev/null 2>& 1 ????elif [[ "${software_name}" =~ "jellyseerr" ]]; then ?????tar -czf "${backu p}/${software_name}-${backup_version}-config_${package_date}.tar.gz" -C "/opt/${ username}/Jellyseerr/config" . >/dev/null 2>&1 ????elif [[ "${software_name}" =~ "overseerr" ]]; then ?????tar -czf "${backup}/${software_name}-${backup_version }-config_${package_date}.tar.gz" -C "/opt/${username}/Overseerr/config" . >/dev/ null 2>&1 ????else ?????tar -czf "${backup}/${software_name}-${backup_version}-c onfig_${package_date}.tar.gz" -C "/home/${username}/.config/${software_title}" . >/dev/null 2>&1 ????fi ????find "/home/${username}/.QuickBox" -type d \( ! -use r www-data -o ! -group www-data \) -print0 | xargs -0 chown www-data:www-data >/ dev/null 2>&1 ????find "/home/${username}/.QuickBox" -type d ! -perm 0755 -print 0 | xargs -0 chmod 0755 >/dev/null 2>&1 ????chown www-data:www-data -R "${backup }/${software_name}"-*.tar.gz >/dev/null 2>&1 ????chown "${username}":"${username }" "${backupConf}" "${softwareConf}" ????quickbox::database "INSERT INTO softwar e_rollbacks ("username", "software_name", "software_version", "software_date") V ALUES ('${username}', '${software_name:-}', '${backup_version:-}', '${time_stamp :-}');" ????mflibs::shell::text::green "$(quickbox::lang::backup::installdir::su ccess)" ????unset time_stamp package_date backup_version software_name ???fi ??? ;; ??restore) ???if [[ ! -f ${backupConf} ]]; then ????mflibs::shell::text::red "$(quickbox::lang::restore::configf::error)" ???else ????cp -prf "${backupConf}" "${softwareConf}" ????find "/home/${username}/.QuickBox" -type d \( ! -user www -data -o ! -group www-data \) -print0 | xargs -0 chown www-data:www-data >/dev/n ull 2>&1 ????find "/home/${username}/.QuickBox" -type d ! -perm 0755 -print0 | x args -0 chmod 0755 >/dev/null 2>&1 ????chown "${username}":"${username}" "${back upConf}" "${softwareConf}" ????mflibs::shell::text::green "$(quickbox::lang::res tore::configf::success)" ???fi ???;; ??default) ???if [[ ! -f ${defaultConf} ]]; then ????mflibs::shell::text::red "$(quickbox::lang::default::configf::error)" ???else ????cp -prf "${defaultConf}" "${softwareConf}" ????find "/home/${usernam e}/.QuickBox" -type d \( ! -user www-data -o ! -group www-data \) -print0 | xarg s -0 chown www-data:www-data >/dev/null 2>&1 ????find "/home/${username}/.QuickB ox" -type d ! -perm 0755 -print0 | xargs -0 chmod 0755 >/dev/null 2>&1 ????chown "${username}":"${username}" "${backupConf}" "${softwareConf}" ????mflibs::shell ::text::green "$(quickbox::lang::default::configf::success)" ???fi ???;; ??rollb ack) ???if [[ "${qb_option[*]}" =~ "app" ]]; then ????user_id=$(quickbox::databa se "SELECT id FROM user_information WHERE username='${username}';") ????software _title=$(quickbox::database "SELECT DISTINCT software_title from software_inform ation WHERE software_name = '${software}';") ????software_service_name=$(quickbo x::database "SELECT DISTINCT software_service_name from software_information WHE RE software_name = '${software}';") ????backup_path="/home/${username}/.QuickBox /software/${software}/backup/" ????[[ -f "/etc/systemd/system/${software_service _name}@${username}.service" ]] && systemctl stop "${software_service_name}"@"${u sername}" >/dev/null 2>&1 ????[[ -f "/etc/systemd/system/${software_service_name }.service" ]] && systemctl stop "${software_service_name}" >/dev/null 2>&1 ????# set custom conditions for software directories on rollback ????if [[ "${softwar e}" =~ "emby" ]]; then ?????install_directory="/opt/${username}/emby-server" ??? ?elif [[ "${software}" =~ "plex" ]]; then ?????install_directory="/usr/lib/plexm ediaserver" ????else ?????install_directory=$(find "/opt/${username}" -maxdepth 1 -type d -name "${software_title}" -printf '%f\n') ????fi ????if [[ -z "${insta ll_directory}" ]]; then ?????mflibs::shell::text::red "$(quickbox::lang::rollbac k::installdir::error)" ?????exit 1 ????fi ????[[ "${qb_option[*]}" =~ "vi=" ]] & & declare skip_check=1 ????swvi=1 ????IFS=$'\n' read -d '' -ra backups <<<"$(qui ckbox::database "SELECT software_version,software_date from software_rollbacks W HERE software_name = '${software}' AND username = '${username}';")" ????backup_m enu=() ????for i in "${backups[@]}"; do ?????backup_version="$(echo "${i}" | cut -d '|' -f1)" ?????backup_date="$(echo "${i}" | cut -d '|' -f2-)" ?????backup_me nu+=(" ${swvi}) $(quickbox::lang::rollback::selection::version) ${backup_ver sion} $(quickbox::lang::rollback::selection::date) ${backup_date}") ?????swvi =$((swvi + 1)) ????done ????# display the menu ????mflibs::shell::text::white "$ (quickbox::lang::rollback::selection)" ????for backup_display in "${backup_menu[ @]}"; do ?????echo "${backup_display}" ????done ????# set the version from the s election ????declare -gi vi ????declare version ????if [[ ${skip_check} == 1 ]]; then ?????# set the vi= to the value in the -o vi= option ?????vi=$(grep -oP 'v i=\K.*' <<<"${qb_option[*]}") ????else ?????IFS=$'\n' read -r version_selection ?????vi=$(grep -oP "${version_selection}" <<<"${backup_menu[@]}" | grep -oP '[0- 9]*' | head -n 1) ????fi ????version=$(grep -oP 'version: \K.*(?= date)' <<<" ${backup_menu[$((vi - 1))]}") ????# set confirmation if input provided is correc t ????if [[ -z "${version}" ]]; then ?????mflibs::shell::text::red "$(quickbox:: lang::rollback::selection::invalid)" ?????IFS=$'\n' read -r version_selection ?? ??else ?????# show selection and confirmation request ?????declare selected_date app_package config_package ?????selected_date=$(grep -oP 'date: \K.*' <<<"${bac kup_menu[$((vi - 1))]}") ?????package_date=${selected_date// /_} ?????app_packag e=$(find "${backup_path}" -maxdepth 1 -type f -name "${software}-${version}-appl ication_${package_date}.tar.gz" -printf '%f\n') ?????if [[ -z "${app_package}" ] ]; then ??????mflibs::shell::text::red "$(quickbox::lang::rollback::software::er ror)" ??????exit 1 ?????fi ?????config_package=$(find "${backup_path}" -maxdepth 1 -type f -name "${software}-${version}-config_${package_date}.tar.gz" -printf '%f\n') ?????if [[ -z "${config_package}" ]]; then ??????mflibs::shell::text::re d "$(quickbox::lang::rollback::config::error)" ??????exit 1 ?????fi ?????mflibs: :shell::text::white "$(quickbox::lang::rollback::selection::display)" ?????if [[ -z ${skip_check} ]]; then ??????mflibs::shell::text::white "$(quickbox::lang::r ollback::selection::confirm)" ??????IFS=$'\n' read -r version_confirm ??????# lo op until a valid selection is made ??????while [[ "${version_confirm}" != "y" ]] && [[ "${version_confirm}" != "n" ]]; do ???????mflibs::shell::text::red "$(qui ckbox::lang::rollback::selection::invalid)" ???????IFS=$'\n' read -r version_con firm ??????done ??????# if the selection is no, exit the script ??????if [[ "${v ersion_confirm}" == "n" ]]; then ???????mflibs::shell::text::red "$(quickbox::la ng::rollback::cancelled)" ???????exit 0 ??????fi ?????fi ????fi ????# display co nfirmation of the version selection and proceed with the rollback ????mflibs::sh ell::text::white "$(quickbox::lang::rollback::continue)" ????# extract the tarba ll of the software installation directory ????if [[ "${software}" =~ "emby" || " ${software}" =~ "plex" ]]; then ?????tar -xzf "${backup_path}/${app_package}" -C "${install_directory}" >/dev/null 2>&1 ????else ?????tar -xzf "${backup_path}/$ {app_package}" -C "/opt/${username}/${install_directory}" >/dev/null 2>&1 ????fi ????# extract the tarball of the software configuration directory ????if [[ "${ software}" =~ "emby" ]]; then ?????tar -xzf "${backup_path}/${config_package}" - C "/home/${username}/.config/Emby" >/dev/null 2>&1 ?????chown "${username}":"${u sername}" -R "${install_directory}" "/home/${username}/.config/Emby" 2>&1 ????el if [[ "${software}" =~ "plex" ]]; then ?????tar -xzf "${backup_path}/${config_pa ckage}" -C "/home/${username}/.config/Plex Media Server" >/dev/null 2>&1 ?????ch own "${username}":"${username}" -R "${install_directory}" "/home/${username}/.co nfig/Plex Media Server" 2>&1 ????elif [[ "${software_name}" =~ "jellyseerr" ]]; then ?????tar -xzf "${backup_path}/${config_package}" -C "/opt/${username}/Jelly seerr/config" >/dev/null 2>&1 ?????chown "${username}":"${username}" -R "${insta ll_directory}" "/home/${username}/.config/Jellyseerr" 2>&1 ????elif [[ "${softwa re_name}" =~ "overseerr" ]]; then ?????tar -xzf "${backup_path}/${config_package }" -C "/opt/${username}/Overseerr/config" >/dev/null 2>&1 ?????chown "${username }":"${username}" -R "${install_directory}" "/home/${username}/.config/Overseerr" 2>&1 ????else ?????tar -xzf "${backup_path}/${config_package}" -C "/home/${user name}/.config/${software_title}" >/dev/null 2>&1 ?????chown "${username}":"${use rname}" -R "/opt/${username}/${install_directory}" "/home/${username}/.config/${ software_title}" 2>&1 ????fi ????quickbox::database "UPDATE user_software SET so ftware_version='${version}' WHERE software_name='${software}' AND user_id='${use r_id:?}';" ????[[ -f "/etc/systemd/system/${software_service_name}@${username}.s ervice" ]] && systemctl start "${software_service_name}"@"${username}" >/dev/nul l 2>&1 ????[[ -f "/etc/systemd/system/${software_service_name}.service" ]] && sy stemctl start "${software_service_name}" >/dev/null 2>&1 ????/usr/local/bin/qb s oftware check >/dev/null 2>&1 ????mflibs::shell::text::green "$(quickbox::lang:: rollback::complete)" ????unset version version_selection vi selected_date app_pa ckage config_package ???fi ???;; ??delete) ???if [[ "${qb_option[*]}" =~ "app" ] ]; then ????user_id=$(quickbox::database "SELECT id FROM user_information WHERE username='${username}';") ????software_title=$(quickbox::database "SELECT DISTIN CT software_title from software_information WHERE software_name = '${software}'; ") ????software_service_name=$(quickbox::database "SELECT DISTINCT software_serv ice_name from software_information WHERE software_name = '${software}';") ????ba ckup_path="/home/${username}/.QuickBox/software/${software}/backup/" ????install _directory=$(find "/opt/${username}" -maxdepth 1 -type d -name "${software_title }*" -printf '%f\n') ????config_directory=$(find "/home/${username}/.config" -max depth 1 -type d -name "${software_title}*" -printf '%f\n') ????[[ "${qb_option[* ]}" =~ "vi=" ]] && declare skip_check=1 ????swvi=1 ????IFS=$'\n' read -d '' -ra backups <<<"$(quickbox::database "SELECT software_version,software_date from sof tware_rollbacks WHERE software_name = '${software}' AND username = '${username}' ;")" ????backup_menu=() ????for i in "${backups[@]}"; do ?????backup_version="$( echo "${i}" | cut -d '|' -f1)" ?????backup_date="$(echo "${i}" | cut -d '|' -f2- )" ?????backup_menu+=(" ${swvi}) $(quickbox::lang::delete::selection::versio n) ${backup_version} $(quickbox::lang::delete::selection::date) ${backup_date }") ?????swvi=$((swvi + 1)) ????done ????# display the menu ????mflibs::shell::t ext::white "$(quickbox::lang::delete::selection)" ????for backup_display in "${b ackup_menu[@]}"; do ?????echo "${backup_display}" ????done ????# set the version from the selection ????declare -gi vi ????declare version ????if [[ ${skip_chec k} == 1 ]]; then ?????# set the vi= to the value in the -o vi= option ?????vi=$( grep -oP 'vi=\K.*' <<<"${qb_option[*]}") ????else ?????IFS=$'\n' read -r version _selection ?????vi=$(grep -oP "${version_selection}" <<<"${backup_menu[@]}" | gr ep -oP '[0-9]*' | head -n 1) ????fi ????version=$(grep -oP 'version: \K.*(?= date)' <<<"${backup_menu[$((vi - 1))]}") ????# set confirmation if input provide d is correct ????if [[ -z "${version}" ]]; then ?????mflibs::shell::text::red "$ (quickbox::lang::delete::selection::invalid)" ?????IFS=$'\n' read -r version_sel ection ????else ?????# show selection and confirmation request ?????declare sele cted_date app_package config_package ?????selected_date=$(grep -oP 'date: \K.*' <<<"${backup_menu[$((vi - 1))]}") ?????package_date=${selected_date// /_} ?????a pp_package=$(find "${backup_path}" -maxdepth 1 -type f -name "${software}-${vers ion}-application_${package_date}.tar.gz" -printf '%f\n') ?????config_package=$(f ind "${backup_path}" -maxdepth 1 -type f -name "${software}-${version}-config_${ package_date}.tar.gz" -printf '%f\n') ?????mflibs::shell::text::white "$(quickbo x::lang::delete::selection::display)" ?????if [[ -z ${skip_check} ]]; then ????? ?mflibs::shell::text::white "$(quickbox::lang::delete::selection::confirm)" ???? ??IFS=$'\n' read -r version_confirm ??????# loop until a valid selection is made ??????while [[ "${version_confirm}" != "y" ]] && [[ "${version_confirm}" != "n" ]]; do ???????mflibs::shell::text::red "$(quickbox::lang::delete::selection::in valid)" ???????IFS=$'\n' read -r version_confirm ??????done ??????# if the selec tion is no, exit the script ??????if [[ "${version_confirm}" == "n" ]]; then ??? ????mflibs::shell::text::red "$(quickbox::lang::delete::cancelled)" ???????exit 0 ??????fi ?????fi ????fi ????# display confirmation of the version selection an d proceed with the rollback ????mflibs::shell::text::white "$(quickbox::lang::de lete::continue)" && sleep 2 ????# remove the selected tarball of the software in stallation backup directory ????rm -f "${backup_path}/${app_package}" >/dev/null 2>&1 ????# remove the selected tarball of the software configuration backup dir ectory ????rm -f "${backup_path}/${config_package}" >/dev/null 2>&1 ????# remove the selected version/date from the database ????quickbox::database "DELETE FROM software_rollbacks WHERE software_name='${software}' AND username='${username}' AND software_version='${version}' AND software_date='${selected_date}';" ????mf libs::shell::text::green "$(quickbox::lang::delete::complete)" ????unset version version_selection vi selected_date app_package config_package ???fi ???;; ??rut orrent) ???plugin_vault_directory="/opt/quickbox/bin/software/rutorrent/plugins/ " ???plugin_install_directory="/srv/rutorrent/plugins" ???for option in "${qb_op tion[@]}"; do ????case "${option,,}" in ????install) ?????echo "accessing ${ruto rrent_plugin:-} in the plugin vault ... " ?????cd "${plugin_install_directory:-} " || { echo "${plugin_install_directory:-} does not exist" && exit; } ?????echo "installing ${rutorrent_plugin:-} plugin ... " ?????if [[ ${rutorrent_plugin:-} == "autodl-irssi" ]]; then ??????if [[ $(quickbox::software::count autodl) -eq 1 ]]; then ???????rm -rf "${plugin_vault_directory:-}autodl-irssi" ???????git clo ne https://lab.quickbox.io/jmsolo/autodl-rutorrent.git "${plugin_vault_directory :-}autodl-irssi" ??????else ???????echo "AutoDL-iRSSi is not installed on the sy stem, skipping." ??????fi ?????fi ?????for i in ${rutorrent_plugin:-}; do ?????? \cp -rf "${plugin_vault_directory:-}${i}" . ?????done ?????if [[ ${rutorrent_plu gin:-} == "_cloudflare" ]]; then ??????/usr/bin/python3 -m pip install --upgrade --exists-action s cloudscraper python_anticaptcha >/dev/null 2>&1 ??????\cp -f "/opt/quickbox/config/software/rutorrent/plugins/${rutorrent_plugin:-}/conf.php" "${plugin_install_directory:-}/${rutorrent_plugin:-}/conf.php" ?????fi ?????if [[ ${rutorrent_plugin:-} == "diskspace" ]]; then ??????\cp -f "/opt/quickbox/con fig/software/rutorrent/plugins/${rutorrent_plugin:-}/action.php" "${plugin_insta ll_directory:-}/${rutorrent_plugin:-}/action.php" ?????fi ?????if [[ ${rutorrent _plugin:-} == "filemanager-share" ]]; then ??????\cp -f "/opt/quickbox/config/so ftware/rutorrent/plugins/${rutorrent_plugin:-}/conf.php" "${plugin_install_direc tory:-}/${rutorrent_plugin:-}/conf.php" ?????fi ?????echo "adjusting permissions ... " ?????chown -R www-data: "${plugin_install_directory:-}/${rutorrent_plugin :-}" ?????echo "${rutorrent_plugin:-} plugin install complete!" ?????[[ ${qb_opt ion[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/null 2>&1 & ?????exit ?????;; ????remove) ?????echo "uninstalling the ${rutorrent_plugin:?} plugin .. . " ?????for i in ${rutorrent_plugin:-}; do ??????rm -rf "${plugin_install_direc tory:?}/${i}" ?????done ?????echo "${rutorrent_plugin:-} plugin uninstall comple te!" ?????[[ ${qb_option[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/ null 2>&1 & ?????exit ?????;; ????*) ;; ????esac ???done ???;; ??*) ;; ??esac ?d one } ######################################################################### ####### # @description: dashboard theme switching # @arg: -o [defaulted|smoked] # @example: qb manage theme -o smoked # @null ################################## ############################################## theme::settings() { ?for option i n "${qb_option[@]}"; do ??case "${option,,}" in ??smoked) ???sed -i -r 's/defaul ted.css/smoked.css/g' /srv/quickbox/assets/css/plugins.css ???sed -i -r 's/defau lted.css/smoked.css/g' /srv/quickbox/dash_header.php ???sed -i -r 's/defaulted.c ss/smoked.css/g' /srv/quickbox/assets/css/plugins_1.css ???rm -rf /srv/quickbox/ db/.theme_defaulted.lock ???printf "" >/srv/quickbox/db/.theme_smoked.lock ???ch own www-data:www-data /srv/quickbox/db/.theme_smoked.lock ???[[ ${qb_option[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/null 2>&1 & ???;; ??defaulted ) ???sed -i -r 's/smoked.css/defaulted.css/g' /srv/quickbox/assets/css/plugins.c ss ???sed -i -r 's/smoked.css/defaulted.css/g' /srv/quickbox/dash_header.php ??? sed -i -r 's/smoked.css/defaulted.css/g' /srv/quickbox/assets/css/plugins_1.css ???rm -rf /srv/quickbox/db/.theme_smoked.lock ???printf "" >/srv/quickbox/db/.th eme_defaulted.lock ???chown www-data:www-data /srv/quickbox/db/.theme_defaulted. lock ???[[ ${qb_option[*]} != *"web"* ]] && systemctl reload php8.1-fpm >/dev/nu ll 2>&1 & ???;; ??*) ;; ??esac ?done } ######################################## ######################################## # @description: manages blocking and al lowing of public trackers # @noargs ############################################ #################################### tracker::settings() { ?for option in "${qb_ option[@]}"; do ??case "${option,,}" in ??enable) ???mflibs::shell::text::red "$ (quickbox::lang::trackers::enable)" ???mflibs::log "/sbin/iptables -F qb-public- trackers" && mflibs::log "/sbin/iptables -X qb-public-trackers" ???awk 'NR==FNR{ a[$0];next} !($0 in a){print > FILENAME".filtered"}' "${quickbox_base_path}/conf ig/system/trackers/host_trackers" /etc/hosts ???mv -f "/etc/hosts.filtered" "/et c/hosts" ???rm -f /etc/cron.daily/deny_public ???;; ??disable) ???declare line ? ??mflibs::shell::text::green "$(quickbox::lang::trackers::disable)" ???cp -f "${ quickbox_base_path:="/opt/quickbox"}/config/system/trackers/deny_public" "/etc/c ron.daily/" ???chmod +x /etc/cron.daily/deny_public ???mflibs::log "/sbin/iptabl es -N qb-public-trackers" ???while IFS= read -r line; do ????mflibs::log "/sbin/ iptables -A qb-public-trackers -s ${line} -j DROP" ???done < <(grep -v '^ *#' <" ${quickbox_base_path:="/opt/quickbox"}/config/system/trackers/tracker_list") ??? awk 'NR==FNR{a[$0];next} !($0 in a){print > FILENAME".filtered"}' "${quickbox_ba se_path}/config/system/trackers/host_trackers" /etc/hosts ???mv -f "/etc/hosts.f iltered" "/etc/hosts" ???cat "${quickbox_base_path}/config/system/trackers/host_ trackers" >>/etc/hosts ???;; ??*) ;; ??esac ?done } ########################### ##################################################### # @description: sets the s erver web root for dashboard access # @arg: -o [server_ip (or) domain] # @exampl e: qb manage webroot -o 192.168.0.1 (or) myawesomedomain.com # @null ########### ##################################################################### webroot::s ettings() { ?quickbox::database "UPDATE system_configuration set configuration_v alue = 'https://${qb_option[*]:-}/' WHERE configuration_name='server_web_root';" ?mflibs::log "systemctl restart nginx.service" ?mflibs::log "systemctl reload p hp8.1-fpm.service" } ########################################################## ###################### # @description: calls functions in the required order ### ############################################################################# ma nage::environment::init "$@" # shellcheck disable=SC2068 quickbox::args::process $@ case "${1}" in api) ?api::settings ?;; fail2ban) ?fail2ban::settings ?;; lan g) ?lang::settings ?;; nginx) ?nginx::settings ?;; mount) ?mount::settings ?;; s oftware) ?software::settings ?;; trackers) ?tracker::settings ?;; theme) ?theme: :settings ?;; webroot) ?webroot::settings ?;; *) ;; esac /opt/quickbox/system/m anage mount manage mount -o space -u judgey judgey 189975 167039 0 12:30 pts/2 00:00:00 grep --color=auto Emby
Q-Droid 1011 Posted October 20, 2023 Posted October 20, 2023 So emby is not running the server, it's judgey. id judgey And if missing then add video and render groups for judgey then restart Emby.
grahamcoyswanst 2 Posted October 20, 2023 Author Posted October 20, 2023 hey just so you know i really appreciate the help... i did do judgey with "sudo usermod -a -G render judgey" but its still the same for some reason mate all that's showing is the software no hw. Sorry feel a pain is there anything else i could try ?
grahamcoyswanst 2 Posted October 20, 2023 Author Posted October 20, 2023 Is there a cmd line i need to use for that, would it be "sudo usermod -a -G video judgey"
Q-Droid 1011 Posted October 20, 2023 Posted October 20, 2023 Did you check to see if judgey already has it? That's why the id command was given. Yes, if judgey does not have group video then the usermod command will add it. These steps would take care of the basics but you have an atypical installation so there might be other things preventing HW access. The newer CPU can also be a factor but the OS, kernel and the beta version of Emby you are using should have those covered.
Q-Droid 1011 Posted October 20, 2023 Posted October 20, 2023 When you make the changes restart Emby and attach the newest hardware detection log.
grahamcoyswanst 2 Posted October 20, 2023 Author Posted October 20, 2023 Thanks loads i will do some more digging and get back to you. Thanks again 1
grahamcoyswanst 2 Posted October 21, 2023 Author Posted October 21, 2023 id emby uid=999(emby) gid=995(emby) groups=995(emby),44(video),105(render),1001(judgey) id judgey uid=1000(judgey) gid=1001(judgey) groups=1001(judgey),33(www-data),44(video),105(render),995(emby) Here are the groups I'm sure it's right but if you can confirm I have posted logs after a reboot. thanks hardware_detection-63833479593.txt embyserver (5).txt
Q-Droid 1011 Posted October 21, 2023 Posted October 21, 2023 Those look right to me. At this point and unless you want to do a normal installation of Emby your best bet might be to see if Quickbox support can help you figure this out.
Q-Droid 1011 Posted October 21, 2023 Posted October 21, 2023 Another thought is if Quickbox supports Docker then you could try the Emby beta image instead.
grahamcoyswanst 2 Posted October 21, 2023 Author Posted October 21, 2023 It is a shame as the Quickboxs owner had a house fire and lost everything he currently trying to get access to everything (he locked out as he lost his phone and codes) but this has been a while now so I'm not sure if or when he will be back. I understand this is not your problem but just letting you know where I'm at. unfortunately no support for docker either. I was under the impression just from what i been told over the years iQuickbox is just an installer but again I'm not clued up enough to understand it fully. Thanks for all the help if you do think of anything would you ping me, again thanks so much really appreciate it.
