ebr 16304 Posted October 26, 2013 Posted October 26, 2013 He means the actual folder structure in the file system. Does it follow the structure for TV in the wiki?
Luke 42171 Posted October 26, 2013 Posted October 26, 2013 Steverido - i can probably spot the issue quickly if you setup a teamviewer session.
Steverido 6 Posted October 27, 2013 Author Posted October 27, 2013 Steverido - i can probably spot the issue quickly if you setup a teamviewer session. That would be great. When can you do it and how do I add you?
Netbug 26 Posted October 27, 2013 Posted October 27, 2013 This seems to be the exact same problem I posted about here: http://mediabrowser.tv/community/index.php?/topic/1493-tv-metadata-gone-after-plugin-update/ You may want to remove my post and consolidate it here, ebr. Sorry about missing this when I was looking through for a similar issue.
Steverido 6 Posted November 2, 2013 Author Posted November 2, 2013 (edited) Hey Guys, what happened to the support please? Can someone send me a screenshot of there file structure showing tvdb and where it is situated for tv series please? Shouldn't Mediabrowser pickup the meta data in the series folder? Each series has its own named folder (Windows 8.1) and inside is the episodes and mcm id file and folder jpg, backdrop & banner so I am bemused why it does not pickup the tv meta data which is same structure as my film which is fine. Any ideas please Guys? Edited November 1, 2013 by Steverido
Luke 42171 Posted November 2, 2013 Posted November 2, 2013 Hey Guys, what happened to the support please? Can someone send me a screenshot of there file structure showing tvdb and where it is situated for tv series please? Shouldn't Mediabrowser pickup the meta data in the series folder? Each series has its own named folder (Windows 8.1) and inside is the episodes and mcm id file and folder jpg, backdrop & banner so I am bemused why it does not pickup the tv meta data which is same structure as my film which is fine. Any ideas please Guys? http://mediabrowser.tv/community/index.php?/topic/1222-tv-meta-data-not-showing-watched/page-2&do=findComment&comment=31665 1
Steverido 6 Posted November 2, 2013 Author Posted November 2, 2013 http://mediabrowser.tv/community/index.php?/topic/1222-tv-meta-data-not-showing-watched/page-2&do=findComment&comment=31665 Hi Luke, The link pushes back to your post mentioning Teamviewer. If that is correct I have posted and asked you when you are available in post and PM. I live in the UK so not sure if you are US or UK. I am available anytime today. How do we connect? Teamviewer is on. Do I PM to you my Teamviewer details? Regards Steve I have added a screenshot of two folders within Windows to show you my structure in folders.
Solution Steverido 6 Posted November 2, 2013 Author Solution Posted November 2, 2013 Thanks to Luke for sorting out my Meta data issues. Top man.
