Shield and thumb image display UX not great vs. Plex/others
Go to solution Solved by Luke,
4 hours ago, blgentry said:
I use the AndroidTV app on a Shield.  It seems pretty quick to me.  I ONLY use a local library.  I do not use Live TV, which I think you mentioned in a prior post.
If there is a specific navigation action that you are interested in, I can go play with that at home tonight and report my experience.  I also have the regular Android client side loaded on the Shield.  I could compare the two for some specific thing if you'd like.
Brian.
The regular Android client is the one that’s slow.
