sven01 4 Posted October 7, 2023 Posted October 7, 2023 I have a set of albums for King Gizzard &.... and then another set with King Gizzard and... i tried renaming the folder to & and also changed the name of the band on each song individually inside one of the album folders. also tried to mess with the meta data/change inside the emby web interface. no luck so far. what else should i try and do? thanks.
Solution Luke 42245 Posted October 7, 2023 Solution Posted October 7, 2023 Hi, how are the files tagged with embedded information? Please see our music naming guide: Music Naming This goes over what is required to get songs to group together into an album. It is the embedded information that matters more than the file names. Let us know if this helps. Thanks. 1
sven01 4 Posted October 7, 2023 Author Posted October 7, 2023 thanks, changing tags with musicbrainz worked! 1
