Chromecasting outside network
Hi All
Ive been reading threads for a number of hours about this issue and believe I know why its not working for me but unable to fix. Any suggestions would be appreciated.
I have Emby running on a Windows server behind an Nginx proxy which itself is behind a Sophos firewall. As you have probably guessed Chromecasting only works locally and not externally. I believe this is due to Emby logins showing connection from the Proxy IP and not their external one so therefore treated as local users (they can control local lan chromecasts)
I have the X forward sections in config, SSL is handled by Nginx
Ill past my Nginx and Emby config below.
##EMBY Server##
    server {
listen [::]:80;
listen 80;
listen [::]:443 ssl;
listen 443 ssl;
server_name movies.#######.com;
ssl_session_timeout 30m;
ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
    ssl_certificate SSL/#######Wild.crt;
    ssl_certificate_key SSL/########.rsa;
ssl_session_cache shared:SSL:10m;
        #add_header Public-Key-Pins '
        #pin-sha256="8TzXdhbnv+l6EjDG2Vj9EmgGiSmZenrTZSNUFEwyUE=";
        #pin-sha256="YLh1dUR9y6Kja30RrAn7JKnbQG/utLMkBgFF2Fuihg=";
        #pin-sha256="Vjs8r4z+80wjNcr1KepWQboSIRi63WsWXhIMN+eWys=";
        #max-age=86400; includeSubDomains';
        add_header X-Xss-Protection "1; mode=block" always;
        add_header X-Content-Type-Options "nosniff" always;
        add_header Strict-Transport-Security "max-age=2592000; includeSubdomains" always;
        add_header X-Frame-Options "SAMEORIGIN" always;
        proxy_hide_header X-Powered-By;
        add_header 'Referrer-Policy' 'no-referrer';
        add_header Content-Security-Policy "frame-ancestors #######.com movies.#######.com;";
location / {
proxy_pass http://192.168.1.191:8096;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header Host $host;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
#Next three lines allow websockets
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
Guys I have resolved the IP issue. Not sure if Chromecasting is fixed yet or not but it was my firewall at fault rather than Nginx in the end.
I had a loopback NAT rule above the normal Nginx rule so that my domain names worked internally. This has source address set to masq. If i dropped this below the main rule then IP addresses are being correctly logged by Emby.
  • Thanks 1
HI, thanks for following up !
