embilly 2 Posted October 1, 2023 Posted October 1, 2023 I seem to have an issue where when i moved from docker to synology native app for dlna it kept the old subnet i used to use. How can the old subnet be completely removed
Luke 42241 Posted October 1, 2023 Posted October 1, 2023 Hi, what kept the old subnet? Emby server server doesn’t have any subnet settings.
embilly 2 Posted October 1, 2023 Author Posted October 1, 2023 embyserver-63831758276.txt my server address is 192.168.0.125 it used to be 192.168.18.125 dlna using can be found the device (show music, movies and photo) but it wont open with anything. it used to
embilly 2 Posted October 1, 2023 Author Posted October 1, 2023 when i go to for example, bose sound touch app, i can connect to my nas then i can selected the music folder. but then thats as far as it goes. it used to work fine
embilly 2 Posted October 1, 2023 Author Posted October 1, 2023 do you know why on the log is has the 192.168.18.125 which is not even existent on the network anymore still shows on the log
Luke 42241 Posted October 1, 2023 Posted October 1, 2023 Can you try powering off and on your sonos devices? there's some weird responses coming from them in the server log. I think they are the ones still holding onto an old address.
embilly 2 Posted October 1, 2023 Author Posted October 1, 2023 I dont have sonos. I have bose and Samsung devices
Luke 42241 Posted October 1, 2023 Posted October 1, 2023 Ok then please try rebooting those devices. Thanks.
embilly 2 Posted December 27, 2023 Author Posted December 27, 2023 It made no difference and i started to use a different dlna server
Luke 42241 Posted December 27, 2023 Posted December 27, 2023 2 minutes ago, embilly said: It made no difference and i started to use a different dlna server Can you please try the latest version, along with the Emby Dlna 1.3.0+ plugin update? Thanks !
embilly 2 Posted December 27, 2023 Author Posted December 27, 2023 I may try soon. Thanks for your response
Luke 42241 Posted December 27, 2023 Posted December 27, 2023 3 minutes ago, embilly said: I may try soon. Thanks for your response That would be great. We are happy to help. Thanks.
