djon 16 Posted September 29, 2023 Posted September 29, 2023 If a watch part of a TV-Show or movie but do not finish it, I can see the watched progress fine in Kodi and if I resume that will work too - until I reboot Kodi (which it does every time I turn off the TV as my Odroid N2+ power is being turned off). On Emby server the Watched progress is still correct, but after restarting Kodi, watched progress is gone. I can see this a lot in the kodi log: "resumetime" in ListItem.setProperty() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setResumePoint(). And wonder if that has something to do with it? 01_KODI.log
Luke 42237 Posted September 29, 2023 Posted September 29, 2023 Hi there, can you please provide a specific example for @quickmic thanks.
djon 16 Posted September 29, 2023 Author Posted September 29, 2023 I searched and searched but nowhere in the log does it specifically say that it can't get a correct progress for a video I just watched some of, before taking the power off the Odroid and turning it on again. It just doesn't seem to retrieve the watched progress from Emby server.
quickmic 1709 Posted September 30, 2023 Posted September 30, 2023 All warnings in the log are not from e4k plugin. Some 3rd party plugin using deprecated APis. Quote It just doesn't seem to retrieve the watched progress from Emby server. It does, the question is. Is it correct and complete. 2023-09-29 08:06:05.265 T:6898 info <general>: EMBY.database.library: THREAD: --->[ retrieve changes ] 2023-09-29 08:06:05.267 T:6898 info <general>: EMBY.database.dbio: ---> DBOpenRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_remove3236467392 2023-09-29 08:06:05.268 T:6898 info <general>: EMBY.database.dbio: ---< DBCloseRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_remove3236467392 2023-09-29 08:06:05.268 T:6898 info <general>: EMBY.database.library: -->[ worker remove started ] queue size: 0 2023-09-29 08:06:05.270 T:6898 info <general>: EMBY.database.dbio: ---> DBOpenRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_update3236467392 2023-09-29 08:06:05.271 T:6898 info <general>: EMBY.database.dbio: ---< DBCloseRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_update3236467392 2023-09-29 08:06:05.271 T:6898 info <general>: EMBY.database.library: -->[ worker update started ] queue size: 0 2023-09-29 08:06:05.272 T:6896 info <general>: Emby.hooks.websocket: ---<[ websocket connect ] 2023-09-29 08:06:05.272 T:6900 info <general>: Emby.hooks.websocket: THREAD: --->[ ping ] 2023-09-29 08:06:05.273 T:6898 info <general>: EMBY.database.dbio: ---> DBOpenRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_userdata3236467392 2023-09-29 08:06:05.273 T:6898 info <general>: EMBY.database.library: -->[ worker userdata started ] queue size: 0 2023-09-29 08:06:05.274 T:6898 info <general>: EMBY.database.dbio: ---< DBCloseRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_userdata3236467392 2023-09-29 08:06:05.276 T:6898 info <general>: EMBY.database.dbio: ---> DBOpenRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_library3236467392 2023-09-29 08:06:05.277 T:6898 info <general>: EMBY.database.dbio: ---< DBCloseRO: bd46f2f7431d45ca8b4ffc46ce1ff655worker_library3236467392 2023-09-29 08:06:05.277 T:6898 info <general>: EMBY.database.library: -->[ worker library started ] queue size: 0 2023-09-29 08:06:05.277 T:6898 info <general>: EMBY.database.library: --<[ worker library empty ] 2023-09-29 08:06:05.277 T:6898 info <general>: EMBY.database.library: Retrieve changes, last synced: 2023-09-29T05:36:48Z 2023-09-29 08:06:05.278 T:6898 info <general>: EMBY.helper.utils: Progress Bar open: 1 2023-09-29 08:06:05.278 T:6898 info <general>: EMBY.database.library: -->[ Kodi companion ] 2023-09-29 08:06:05.298 T:6898 error <general>: EMBY.emby.http: [ Statuscode ] 404 2023-09-29 08:06:05.298 T:6898 info <general>: EMBY.database.library: --<[ Kodi companion ] 2023-09-29 08:06:05.298 T:6898 info <general>: EMBY.database.library: [ retrieve changes ] 11 / TV shows 2023-09-29 08:06:05.886 T:6898 info <general>: Skipped 3 duplicate messages.. 2023-09-29 08:06:05.886 T:6898 info <general>: EMBY.database.library: [ retrieve changes ] 4 / Movies 2023-09-29 08:06:06.118 T:6898 info <general>: Skipped 2 duplicate messages.. 2023-09-29 08:06:06.118 T:6898 info <general>: EMBY.database.library: [ retrieve changes ] 7324 / Kids Movies 2023-09-29 08:06:06.333 T:6829 info <general>: Skipped 2 duplicate messages.. 2023-09-29 08:06:06.333 T:6829 info <general>: [ script.embuary.info ] Finished next airing database refreshing 2023-09-29 08:06:06.424 T:6898 info <general>: EMBY.helper.utils: Progress Bar close: 0 2023-09-29 08:06:06.436 T:6898 info <general>: EMBY.database.dbio: ---> DBOpenRW: bd46f2f7431d45ca8b4ffc46ce1ff655/set_syncdate 2023-09-29 08:06:06.454 T:6898 info <general>: EMBY.database.dbio: ---< DBCloseRW: bd46f2f7431d45ca8b4ffc46ce1ff655 / 2 / set_syncdate rows updated on db close 2023-09-29 08:06:06.484 T:6898 info <general>: EMBY.database.library: THREAD: ---<[ retrieve changes ] Is the date correct -> "Retrieve changes, last synced: 2023-09-29T05:36:48Z" Also it updates content: 2023-09-29 08:06:06.771 T:6898 info <general>: EMBY.core.tvshows: UPDATE episode [38 / 53 / 401 / 2895] 21834: Do or Die First, check if content progress is at any time in sync on Emby server. Especially before Kodi start. btw, I hope you don't powercut Kodi. Can you reproduce the issue? If yes, give me exact instructions, how to trigger it.
Solution djon 16 Posted October 6, 2023 Author Solution Posted October 6, 2023 On 9/30/2023 at 5:42 AM, quickmic said: btw, I hope you don't powercut Kodi. That made me think and I could see I had set CEC to suspend Odroid, which would then be power cut when the TV turned off. I changed the CEC behavior to Shutdown instead, and that seems to have fixed the progress issues. 1
