PlutoIsAPlanet 2 Posted September 28, 2023 Posted September 28, 2023 Greetings all, according to Audio Book Images embedded images are supported. Unfortunately, no matter how I set a library up, the same image is getting shown for every item, even though each has its own embedded image. I have set up two libraries for testing, Test1 and Test2. - Test1 - Music folder structure: Other or unstructured - Test2 - Music folder structure: Perfectly organised into album folders, with tracks directly in the album folder (this is actually how the files are stored) The library settings are identical: Checked are the following options: - Enable real time monitoring - Image Extractor Everything else has not been checked, there are no album metadata downloaders or album image fetchers enabled, just the two aforementioned options. Upon initial creation, this is what I'm seeing (Test2 is identical): If I select an audio book, then I see the following image information: There are no image files in the folder, just a group of audio files. Each audio file received its image using Mp3tag. If anyone has an idea, it surely is appreciated!
Solution Luke 42185 Posted September 28, 2023 Solution Posted September 28, 2023 HI, this has been changed for the upcoming 4.8 server release, where each audiobook track will get it's own embedded image. 1
PlutoIsAPlanet 2 Posted September 29, 2023 Author Posted September 29, 2023 Hi Luke, thanks for the information! I had searched before posting and was sure that I was doing everything correct so I thought that I'd ask. Have a great weekend! 1
