saj3471 3 Posted September 27, 2023 Posted September 27, 2023 Hello, How do I define the "{path}" under “Live TV > Advanced > Recording Post Processing” when using the comskip application ? The documentation for comskip states that {path} is the exact file path including the actual file name, this obviously is not a good setting because Emby creates unique folders and files for each program that it records. Also, I've tried using the ScripterX plugin with the "emby_preprocessing.sh" script but nothing happens when the "onLiveTVRecordingStart" is configured. As instructed in the script docs, I only configure "Recording Post Processing" or "onLiveTVRecordingStart" but never both during my testing to see which would work. At this point I'm out of ideas, can someone please share how they got this to work. If I manually run "comskip" or "emby_preprocessing.sh" with "emby" as the user using the command line they both work without issue. Emby-server - version 4.7.14.0 ScripterX plugin - version 3.0.5.5 OS Ubuntu Linux : 22.04.3
Solution richt 95 Posted September 28, 2023 Solution Posted September 28, 2023 (edited) I've run into 2 problems running comskip under Linux Mint (based on Ubuntu) Sometimes Comskip version 0.82.010 doesn't run the first time, but simply errors out. (Comskip failed: Exit code 139). Strangely, if you run it a second time right away, it works just fine. When running comskip under the context of emby (post processing task), the emby environment forced comskip to a set of libraries that did not include a library version that comskip needed, so comskip failed. I was able to get it to work by using the following line in a script and calling the script as a post processing task. This error condition may no longer exist as I haven't bothered to re-test without the script. LD_LIBRARY_PATH=$(pwd)/usr/lib/ /usr/local/bin/comskip --ini=/etc/comskip.ini "$1" The only argument required in "Post-processor command line arguments" is "{path}". This post contains a script you can call as a post processing task that creates a comskip log. Very handy if you need to debug a comskip failure. The Comskipper topic contains other posts about problems running comskip, so if these don't help you might want to review it. Not completely sure from your post, but if you are trying to run comskip against a TV show as you are watching it, there is some help about that subject too. Edited September 28, 2023 by richt Added text
saj3471 3 Posted September 28, 2023 Author Posted September 28, 2023 Thanks for the suggestions, looks like I'm getting closer!! So I pulled in script file to generate the logs for comskip with the name "com_ship.sh" and called it under "Recording Post Processing" as follows: Post-processing application: /usr/local/bin/com_skip.sh Post-processor command ling arguments: "{path}" With the above sometimes it works as intended and generate the EDL file but in most cases not, below is the "comskip.txt" log entries when it fails generating an empty EDL file see below: 2023-09-28 13:40:12 : Beginning post processing script on /mnt/ext-raid/media-server/recordings/NBC News Daily (2004)/Season 2/NBC News Daily S02E09.ts 2023-09-28 13:40:12 : File exists, sleeping 1 minute before starting... 2023-09-28 13:41:18 : Comskip failed: Exit code 1 2023-09-28 13:41:18 : Contents of /mnt/ext-raid/media-server/recordings/NBC News Daily (2004)/Season 2/NBC News Daily S02E09.edl: 2023-09-28 13:41:18 : Finished post processing script on /mnt/ext-raid/media-server/recordings/NBC News Daily (2004)/Season 2/NBC News Daily S02E09.ts The above may be related to the LD_LIBRARY_PATH issue, but I don't know how to use the LD_LIBRARY_PATH script with the "com_skip.sh" script. Here is my take on how to implement the LD_LIBRARY_PATH script: #!/bin/bash LD_LIBRARY_PATH=$(pwd)/usr/lib/ /usr/local/bin/comskip --ini=/etc/comskip.ini "$1" Can I simply call the "com_skip.sh" instead of "comskip" in the above and drop the "--ini=/etc/comskip.ini" resulting in #!/bin/bash LD_LIBRARY_PATH=$(pwd)/usr/lib/ /usr/local/bin/com_skip.sh "$1" Don't laugh, novice here as can tell LOL -Thanks
saj3471 3 Posted September 28, 2023 Author Posted September 28, 2023 BTW my installed comskip version is 0.82.011 -Thanks
Luke 42241 Posted September 28, 2023 Posted September 28, 2023 To answer the original question, how you define the path in the command line arguments depends on what your post processing application expects. So it looks like you've created an .sh script. If that's expecting the path to the recording file as the first argument, then you probably want the default value of just {path}
saj3471 3 Posted September 29, 2023 Author Posted September 29, 2023 So it appears that my starting and stopping recordings within about 5 to 10 seconds as I was testing may have caused the com_skip.sh script to fail. I decided to just leave it alone and see how it would perform with my existing scheduled recordings. So far I have recorded 3 shows and the com_skip.sh script has generated the EDL files without error. I hope the issue is truly resolved. I will give it about a week to see how it performs. Thanks for all the help, this is awesome!!! 1
saj3471 3 Posted October 4, 2023 Author Posted October 4, 2023 No issues so far, this issue is resolved for me. -Thanks 1
saj3471 3 Posted March 20, 2025 Author Posted March 20, 2025 Hello All, ComSkip was working great until I recently upgraded my EmbyServer to version 4.8.11.0. When ComSkip tries to process a recording it generates the following: Comskip failed: Exit code 139 Comskip EDL file does not exist. Comskip version 0.82.011 OS is Ubuntu 22.04.5 LTS If I can get some guidance on how to debug the error code I'd appreciate it. Thanks
Luke 42241 Posted March 20, 2025 Posted March 20, 2025 1 hour ago, saj3471 said: Hello All, ComSkip was working great until I recently upgraded my EmbyServer to version 4.8.11.0. When ComSkip tries to process a recording it generates the following: Comskip failed: Exit code 139 Comskip EDL file does not exist. Comskip version 0.82.011 OS is Ubuntu 22.04.5 LTS If I can get some guidance on how to debug the error code I'd appreciate it. Thanks Hi, are you sure this is an Emby question?
saj3471 3 Posted March 21, 2025 Author Posted March 21, 2025 I hate when this happens... I re-installed ComSkip and BAM! I'm back in business. Issue resolved. 1
