Chiefmas 40 Posted September 26, 2023 Posted September 26, 2023 I was looking at the throttling method, and it says to check the knowledge base for more info, which I did, but nothing comes up there. I'm mostly trying to decide if it makes more sense to flip to stream buffer size or not, so pros/cons I suppose. It seems straight forward from the names, but I don't want to assume too much... Thanks!
Solution Luke 42185 Posted September 28, 2023 Solution Posted September 28, 2023 HI, I would just stick with the default. This was never intended to be a personal preference where you can pick either one and they'll both always work. The option is in the diagnostic plugin mainly for troubleshooting purposes.
Chiefmas 40 Posted September 28, 2023 Author Posted September 28, 2023 Ok, thanks. You might want to remove or change the info pop up in the UI. Just have it say something like you did in the reply about it being for diagnostics and to leave it unless instructed to do so otherwise. 1
