EladBar 4 Posted September 24, 2023 Posted September 24, 2023 AGTV2STRM Convert Apollo Group TV M3U lists to STRM files, Extracts media (TV Show / Movie) details (Title, release date) from The Movie DB (TMDB). Available at: https://gitlab.com/elad.bar/agtv2strm How it works First execution can take up to 5 minutes to create all STRM files (~113k media streams), after then, it will fetch only gaps (~15 seconds), Interval of executions is 1 minute. Stage Duration More details Load up to date M3U list from Apollo Group TV 3 seconds Any cycle Extract streams (Movies / TV Episodes) from M3U lists 1 second Any cycle Load media details from TMDB 120 seconds Initial load is about 15k titles, once cache available, only new titles will be retrieved Merge data of TMDB into streams 2 seconds Any cycle Created unique directories under /app/media 11 seconds First cycle only Build STRM files under the /app/media directory 130 seconds List invalid streams that were not processed 0 Use case: AGTV reported stream as movie, TMDB reported it as tvshow Cache For faster loading of data and debugging, cache directory located at /app/cache, It is highly suggested to map to volume to avoid losing information after redeploy image. agtv.json - M3U list from Apollo Group TV - Debug only streams.json - Streams details tmdb.json - TMDB details How to install Prerequisites Apollo Group TV account The Movie DB account with API Key Docker Compose version: '3' services: agtv2strm: image: "registry.gitlab.com/elad.bar/agtv2strm:latest" container_name: "agtv2strm" hostname: "agtv2strm" restart: "unless-stopped" environment: - AGTV_USERNAME=Username - AGTV_PASSWORD=Password - TMDB_API_KEY=APIKEY - SCAN_INTERVAL=60 - DEBUG=False volumes: - $PWD/media:/app/media - $PWD/cache:/app/cache Environment Variables Variable Default Required Description AGTV_USERNAME - + Username to Apollo Group TV service AGTV_PASSWORD - + Password of the AGTV account TMDB_API_KEY - + The Movie DB API Key SCAN_INTERVAL 60 - Scan interval in minutes, default - every 60 minutes DEBUG false - Enable debug log messages
Ugnaughts 53 Posted December 28, 2023 Posted December 28, 2023 i use windows and haven't tinkered with dockers much. if i install windows docker, is this a script for it to auto install?
GrimEvil 73 Posted December 29, 2023 Posted December 29, 2023 On 28/12/2023 at 08:21, joekingcool said: i use windows and haven't tinkered with dockers much. if i install windows docker, is this a script for it to auto install? if you install docker, you should be able to select the image inside docker, install, run and then configure it from the wizard. It is normally straight forward once you get the hang of it.
Ugnaughts 53 Posted December 29, 2023 Posted December 29, 2023 thanks ill give it a shot. i just made one that monitors a list of shows and what season your on. then creates strm files. ideally i would like a groups that they have in the apollo app. like my list movies, my list shows, whats trending, etc. does yours do that? if so, do you have special link from apollo for that?
EladBar 4 Posted December 29, 2023 Author Posted December 29, 2023 I have another solution of Xtream providers that build the directory according to category, i can implement it like this if you would, not too complex
Ugnaughts 53 Posted December 29, 2023 Posted December 29, 2023 (edited) i made my script in autohotkey. its the only language im familiar with. ill post bellow to show what i got so far. auto strm maker.ahktest.csvauto strm maker.exe Edited December 29, 2023 by joekingcool mistake
Ugnaughts 53 Posted December 29, 2023 Posted December 29, 2023 i also created an app , that will auto download what ever movie or season of series from apollo for you to watch later. if you like, not sure if you use windows or linux?
Ugnaughts 53 Posted December 29, 2023 Posted December 29, 2023 having good bit of trouble just getting docker for windows to work. docker wont startup, wsl error. so i installed wsl. then uninstalled docker and reinstalled docker and still docker wont start up.
sinlogikal 0 Posted April 30, 2024 Posted April 30, 2024 I just found this and am trying to get it to work. I configured the docker through docker desktop on a Mac. It runs through and pulls the data from TMDB, but it says "Created 0 unique directories", and "Finalized 0 stream files". 2024-04-30 07:54:36 2024-04-30 11:54:36,067 INFO __main__ Loaded 16,362 items from TMDB, Duration: 455.816 seconds 2024-04-30 07:54:36 2024-04-30 11:54:36,114 INFO __main__ Merging TMDB data into streams 2024-04-30 07:54:56 2024-04-30 11:54:56,670 INFO __main__ Merged 138,877 streams from TMDB data, Duration: 20.556 seconds 2024-04-30 07:54:56 2024-04-30 11:54:56,769 INFO __main__ Preparing directories 2024-04-30 07:54:56 2024-04-30 11:54:56,795 INFO __main__ Created 0 unique directories, Duration: 0.026 seconds 2024-04-30 07:54:56 2024-04-30 11:54:56,796 INFO __main__ Finalizing stream files 2024-04-30 07:54:57 2024-04-30 11:54:57,404 INFO __main__ Finalized 0 stream files, Duration: 0.608 seconds 2024-04-30 07:54:57 2024-04-30 11:54:57,431 INFO __main__ Complete processing, Duration: 481.949 seconds I'm not sure if I setup the docker correctly. I believe I correctly set the environment variables, but not sure if I am supposed to set the Volumes. I've tried a docker with and without setting the Volume variables, but get the same issue.
EladBar 4 Posted August 19, 2024 Author Posted August 19, 2024 @sinlogikaldid you create the directories before in docker host? are they empty?
JIsenhour247 2 Posted December 5, 2024 Posted December 5, 2024 On 9/24/2023 at 7:54 AM, EladBar said: AGTV2STRM Convert Apollo Group TV M3U lists to STRM files, Extracts media (TV Show / Movie) details (Title, release date) from The Movie DB (TMDB). Available at: https://gitlab.com/elad.bar/agtv2strm How it works First execution can take up to 5 minutes to create all STRM files (~113k media streams), after then, it will fetch only gaps (~15 seconds), Interval of executions is 1 minute. Stage Duration More details Load up to date M3U list from Apollo Group TV 3 seconds Any cycle Extract streams (Movies / TV Episodes) from M3U lists 1 second Any cycle Load media details from TMDB 120 seconds Initial load is about 15k titles, once cache available, only new titles will be retrieved Merge data of TMDB into streams 2 seconds Any cycle Created unique directories under /app/media 11 seconds First cycle only Build STRM files under the /app/media directory 130 seconds List invalid streams that were not processed 0 Use case: AGTV reported stream as movie, TMDB reported it as tvshow Cache For faster loading of data and debugging, cache directory located at /app/cache, It is highly suggested to map to volume to avoid losing information after redeploy image. agtv.json - M3U list from Apollo Group TV - Debug only streams.json - Streams details tmdb.json - TMDB details How to install Prerequisites Apollo Group TV account The Movie DB account with API Key Docker Compose version: '3' services: agtv2strm: image: "registry.gitlab.com/elad.bar/agtv2strm:latest" container_name: "agtv2strm" hostname: "agtv2strm" restart: "unless-stopped" environment: - AGTV_USERNAME=Username - AGTV_PASSWORD=Password - TMDB_API_KEY=APIKEY - SCAN_INTERVAL=60 - DEBUG=False volumes: - $PWD/media:/app/media - $PWD/cache:/app/cache Environment Variables Variable Default Required Description AGTV_USERNAME - + Username to Apollo Group TV service AGTV_PASSWORD - + Password of the AGTV account TMDB_API_KEY - + The Movie DB API Key SCAN_INTERVAL 60 - Scan interval in minutes, default - every 60 minutes DEBUG false - Enable debug log messages this needs the urls updated it will not work as is here is my fork if anyone is interested https://github.com/Tw1zT3d2four7/AG_TV_M3U_2_STRM
