Aviad_Dayan 0 Posted September 23, 2023 Posted September 23, 2023 Hello, i want to buy NAS storage and run Emby on it. what is the best 4 bay disk NAS that is recommended to have that is working good with Emby server and running 4K movies without any issue and blu-ray movies as well. important that network port will be 2.5GB and not 1GB.
Luke 42242 Posted September 23, 2023 Posted September 23, 2023 Hi, Synology has a number of models with a 2.5GB network port. My suggestion would be to get the best one of those based on whatever your budget is.
Aviad_Dayan 0 Posted September 23, 2023 Author Posted September 23, 2023 I have no expiries with this and don't know all models. i am not lock on Synology, id you recommend on a norther model i will be happy to know.
Aviad_Dayan 0 Posted September 23, 2023 Author Posted September 23, 2023 3 minutes ago, Luke said: Hi, Synology has a number of models with a 2.5GB network port. My suggestion would be to get the best one of those based on whatever your budget is. I have no expiries with this and don't know all models. i am not lock on Synology, id you recommend on a norther model i will be happy to know.
Luke 42242 Posted September 23, 2023 Posted September 23, 2023 it also depends on how much storage you need: https://www.synology.com/en-global/products/DS1823xs+#specs
Aviad_Dayan 0 Posted September 23, 2023 Author Posted September 23, 2023 1 minute ago, Luke said: it also depends on how much storage you need: https://www.synology.com/en-global/products/DS1823xs+#specs i am looking not more then 4 bay slots
Luke 42242 Posted September 24, 2023 Posted September 24, 2023 OK I think I was wrong. It's only the high end models that have the 2.5BG network, and they all come with lots of bay slots. Asustor is also a great choice: https://www.asustor.com/product/product_list Use the filters to select only the 4-bay models. It looks like all four models come with 2.5GB network ports.
Aviad_Dayan 0 Posted September 24, 2023 Author Posted September 24, 2023 8 hours ago, Luke said: OK I think I was wrong. It's only the high end models that have the 2.5BG network, and they all come with lots of bay slots. Asustor is also a great choice: https://www.asustor.com/product/product_list Use the filters to select only the 4-bay models. It looks like all four models come with 2.5GB network ports. i did google and i have a question, what is the best manufactory of NAS that will run Emby server and play and decoding 4K and Blu-Ray movies: Synology - (Will be happy to get a good model) QNAP TS-453D-4G Asustor Drivestor 4 Pro AS3304T
Luke 42242 Posted September 25, 2023 Posted September 25, 2023 17 hours ago, Aviad_Dayan said: i did google and i have a question, what is the best manufactory of NAS that will run Emby server and play and decoding 4K and Blu-Ray movies: Synology - (Will be happy to get a good model) QNAP TS-453D-4G Asustor Drivestor 4 Pro AS3304T They're all great choices. It's a matter of which one you prefer. I like the Synology web UI so that's why I looked at their models first, but Emby Server runs well on all of them.
Aviad_Dayan 0 Posted September 25, 2023 Author Posted September 25, 2023 2 hours ago, Luke said: They're all great choices. It's a matter of which one you prefer. I like the Synology web UI so that's why I looked at their models first, but Emby Server runs well on all of them. Yes but I need one with decoding options to run 4k and blu ray. do you have any recommendations
FrostByte 5453 Posted September 25, 2023 Posted September 25, 2023 7 hours ago, Aviad_Dayan said: Yes but I need one with decoding options to run 4k and blu ray. do you have any recommendations If transcoding, then get one with an Intel processor and gpu. None of the Ryzen models have a gpu and thus you can't take advantage of va-api. Most Synology plus models support link aggregation, though that of course uses 2 ports on each side vs just one.
