knxville 3 Posted September 22, 2023 Posted September 22, 2023 Emby appears to select versions of files based on bitrate only and not resolution. Therefore, why do you put the "4K" and "1080" labels in the "Internet Quality" dropdown when theres no logic behind the labels? One would expect the logic be that Emby selects a version based off the selected resolution. If someone's server can't transcode 4K, then it makes Emby's "Auto Quality Selection Feature" useless. I believe either Emby supports their decision to just use bitrate and gets rid of the resolution labels, or a better solution imo, would be to support the users choice of resolution and add that logic to the dropdown. Cheers. 1
blgentry 51 Posted September 22, 2023 Posted September 22, 2023 I can't tell what you are asking or suggesting. Brian.
Q-Droid 1011 Posted September 22, 2023 Posted September 22, 2023 It's been discussed before and somewhat related to this FR.
knxville 3 Posted September 22, 2023 Author Posted September 22, 2023 Yes, I think it’s been discussed here multiple times and all have ended with no answer unfortunately. It should be using the max height logic that speechles is saying.
justinrh 270 Posted September 22, 2023 Posted September 22, 2023 @knxvilleyou are TOTALLY CORRECT! 100X This is nonsense. I've asked about it before and didn't get any sensible answer. How this was developed I can not imagine. Why would it need to be based on height and not just max bitrate?
knxville 3 Posted September 23, 2023 Author Posted September 23, 2023 It should respect the users choice of resolution. Simple as that. Anyone from Emby wish to chime in here? Cheers guys.
Luke 42287 Posted September 23, 2023 Posted September 23, 2023 Hi, we'll take a look at it. Thanks for reporting.
