ebr 16304 Posted January 1, 2025 Posted January 1, 2025 19 hours ago, Quek9 said: Welp, maybe they should just say that. A little honesty goes a long way.
AllesMeins 27 Posted March 22, 2025 Author Posted March 22, 2025 20 minutes ago, Quek9 said: Just checking on the status... Without having any inside knowledge I'd say the status is the same that it has been for the last two years: "Dead, but we're not going to say it publicly." 1 1
MckayCox 0 Posted April 22, 2025 Posted April 22, 2025 I just purchases a lifetime key to emby premier to have 480p trailers FML...
MckayCox 0 Posted April 22, 2025 Posted April 22, 2025 On 12/2/2024 at 3:05 PM, ebr said: We stopped listing it as one of the features you get on the page where you purchase. Therefore, I would not expect someone to purchase Premiere just for that or even heavily for that feature. I love your product and don't regret the purchase, but i just bought Premier specifically to have trailers lol
Neminem 1591 Posted April 22, 2025 Posted April 22, 2025 @MckayCoxwhere do you see Tailers as a premier feature ? Screenshot of you claim and url to where you read that. Emby Premiere Feature Matrix | Emby Documentation
Neminem 1591 Posted April 22, 2025 Posted April 22, 2025 @MckayCoxSorry about that. @ebrIf this is no longer a premier feature, you need to change the description in the plugin catalog. Removing my key and I get this, what gives ? 1
AllesMeins 27 Posted April 22, 2025 Author Posted April 22, 2025 5 minutes ago, Neminem said: @MckayCoxwhere do you see Tailers as a premier feature ? Screenshot of you claim and url to where you read that. https://emby.media/premiere.html "Cinema Intros gives you the true cinema experience with trailers and custom intros before the feature"
darkassassin07 668 Posted April 22, 2025 Posted April 22, 2025 Cinema Intros is a seprate plugin that let's you automatically play trailers and other intro files before movies start. It's not required to manually play trailers, though that's not all that clear.
MckayCox 0 Posted April 22, 2025 Posted April 22, 2025 @Neminem Yeah, again, I'm not mad just a little upset. Hopefully they fix it in the near future.
Quek9 7 Posted April 22, 2025 Posted April 22, 2025 I wish there was a way to separate custume intros from trailers.
Quek9 7 Posted April 26, 2025 Posted April 26, 2025 On 4/22/2025 at 12:49 PM, Quek9 said: I wish there was a way to separate custume intros from trailers. Is there a way to accomplish the following: Play Custom Intro, 3 random trailers, Play Custom Outro, and then play the featurette (movie)?
JodyRamkissoon 0 Posted April 27, 2025 Posted April 27, 2025 (edited) 13 hours ago, Quek9 said: Edited April 27, 2025 by JodyRamkissoon
MangaAddict 15 Posted April 27, 2025 Posted April 27, 2025 14 hours ago, Quek9 said: Is there a way to accomplish the following: Play Custom Intro, 3 random trailers, Play Custom Outro, and then play the featurette (movie)? Search for a plugin named Vantage Point. You can set up intros, outros, bumpers, etc. Awesome addition to Emby
Quek9 7 Posted April 27, 2025 Posted April 27, 2025 16 hours ago, MangaAddict said: Search for a plugin named Vantage Point. You can set up intros, outros, bumpers, etc. Awesome addition to Emby Any advice on how to set this up? It is not clear to me.
visproduction 328 Posted April 28, 2025 Posted April 28, 2025 This works for HD trailers from the trailer button on each media page: Turn on .nfo files in local directories. If you have not had this turned on, you may need to reload the media again to get the .nfo files into the local directories. Find the <trailer>plugin://... line in all .nfo files Replace </trailer> with this at the end of each <trailer> line: ?iv_load_policy=3</trailer> So the trailer lines change from the old version to a new version: Example is 'Mickey 17' (2025) <trailer>plugin://plugin.video.youtube/play/?video_id=osYpGSz_0i4</trailer> <trailer>plugin://plugin.video.youtube/play/?video_id=tA1s65o_kYM</trailer> <trailer>plugin://plugin.video.youtube/play/?video_id=osYpGSz_0i4?iv_load_policy=3</trailer> <trailer>plugin://plugin.video.youtube/play/?video_id=tA1s65o_kYM?iv_load_policy=3</trailer> You can do this by finding all the .nfo files. Windows let's you do this using Windows Explorer, search for: *.nfo -"<trailer>". Open all these .nfo files in a good text editor like edit+, or your favorite, full featured, text editor. Step #2 above... search and replace through all the open .nfo files. Quote [Search through all .nfo files] </trailer> [Replace with] ?iv_load_policy=3</trailer> If you do it correctly, you should be able to change 1000+ media trailers to HD trailers, (if a HD quality trailer is available), with a couple of minutes work. Enjoy. 2 3
MangaAddict 15 Posted April 28, 2025 Posted April 28, 2025 6 hours ago, Quek9 said: Any advice on how to set this up? It is not clear to me. This is the community page for it, you should be able to get some assistance here
Luke 42171 Posted April 29, 2025 Posted April 29, 2025 For those on the beta server, once you've updated to 4.9.0.51, and gotten the trailer plugin update, with the following days after that you'll start to more trailers and higher quality trailers. It is all youtube now. Please note, Emby apps are going to require compatibility updates, so i wouldn't switch to beta solely for this just yet. But if you already happen to run the beta, then please leave feedback in the testing area of the community. Thanks. 2 2
MangaAddict 15 Posted April 29, 2025 Posted April 29, 2025 Thank you guys for not giving up on this! 1
Happy2Play 9798 Posted May 2, 2025 Posted May 2, 2025 On 4/30/2025 at 6:38 PM, STR8 said: Super excited for this as well can't wait! Should already be updated. 4.9.0.51/1.4.0.0 Not positive on resolution as all I see is DirectPlay.
hoopsdavis 27 Posted May 2, 2025 Posted May 2, 2025 1 hour ago, Happy2Play said: Should already be updated. 4.9.0.51/1.4.0.0 Not positive on resolution as all I see is DirectPlay. No improvements on my side. I'm not even surprised at this point
Lessaj 477 Posted May 2, 2025 Posted May 2, 2025 (edited) EDIT: Disregard, I don't think I have this plugin anyway. Edited May 2, 2025 by Lessaj
STR8 74 Posted May 2, 2025 Posted May 2, 2025 @Happy2Play I'm not using beta so I will need to wait a little longer but it's ok and I'm sure it will be worth the wait!
Quek9 7 Posted May 10, 2025 Posted May 10, 2025 On 4/29/2025 at 2:03 PM, Luke said: For those on the beta server, once you've updated to 4.9.0.51, and gotten the trailer plugin update, with the following days after that you'll start to more trailers and higher quality trailers. It is all youtube now. Please note, Emby apps are going to require compatibility updates, so i wouldn't switch to beta solely for this just yet. But if you already happen to run the beta, then please leave feedback in the testing area of the community. Thanks. How do we join the beta? 1
