yocker 1414 Posted November 30, 2024 Posted November 30, 2024 On 11/27/2024 at 6:05 PM, Luke said: Hi there, why exactly do you feel like it wasn't meant to be used with a remote? It's hard to explain, IMO the Android TV app just feels better some how to use. If i was forced to say what was different i would say slightly more fluent, better looking and more options. How ever slight the differences are they do add up to something that feels better to use. The extra options like fx. down mix to stereo can be very useful when having trouble. 1 1
Luke 42243 Posted March 19, 2025 Posted March 19, 2025 On 11/18/2024 at 9:00 AM, mike3821 said: Still seems to be lagging in terms of speed and appears buggy in Live TV still. Close Captions on live tv do not work correctly which I have noted multiple times in other threads. Frustrating.. Hi, can you please try this build and see how things compare? Thanks !
jyeomans 1 Posted March 24, 2025 Posted March 24, 2025 I have to agree. Maybe it's my TV, which is a 4 year old Sony, but the universal Android app is so slow and laggy, that if it weren't for the Android TV app, sadly, I would probably cancel my Emby subscription and find another media system.
monkeyfella 14 Posted March 27, 2025 Posted March 27, 2025 (edited) On 3/24/2025 at 11:22 PM, jyeomans said: I have to agree. Maybe it's my TV, which is a 4 year old Sony, but the universal Android app is so slow and laggy, that if it weren't for the Android TV app, sadly, I would probably cancel my Emby subscription and find another media system. Same here, the regular app does not work well with a remote. Edited March 27, 2025 by monkeyfella
Luke 42243 Posted March 27, 2025 Posted March 27, 2025 18 minutes ago, monkeyfella said: Same here, the regular app does not work well with a remote. Hi there, can you please describe exactly what you mean by this?
monkeyfella 14 Posted March 31, 2025 Posted March 31, 2025 On 3/27/2025 at 6:55 PM, Luke said: Hi there, can you please describe exactly what you mean by this? android tv app, press back on remote, it goes back out of menus until it says "You want to exit?" you press yes and the app exits. When you open again you are greeted with the "Select user" page. Just like other tv apps. Regular app, press back and you will get a side menu to open up, and if you continue the app goes away into hiding but never really exit the same way the android tv app does. And there seem to be no way at all to get the app to start with "Select user" page..
Luke 42243 Posted March 31, 2025 Posted March 31, 2025 6 minutes ago, monkeyfella said: Regular app, press back and you will get a side menu to open up, and if you continue the app goes away into hiding but never really exit the same way the android tv app does. Hi, netflix and disney+ do this. Does that mean their apps also don't work well with a remote?
Luke 42243 Posted March 31, 2025 Posted March 31, 2025 7 minutes ago, monkeyfella said: And there seem to be no way at all to get the app to start with "Select user" page.. Have you explored the new startup behavior option in the app?
monkeyfella 14 Posted April 1, 2025 Posted April 1, 2025 (edited) 11 hours ago, Luke said: Have you explored the new startup behavior option in the app? I can’t find these settings, and use shield with the Emby for android 3.4.36 from the App Store Edited April 1, 2025 by monkeyfella
Happy2Play 9812 Posted April 1, 2025 Posted April 1, 2025 7 minutes ago, monkeyfella said: 12 hours ago, Luke said: Have you explored the new startup behavior option in the app? I can’t find these settings, and use shield with the Emby for android 3.4.36 from the App Store Not in app store yet as I have 3.4.36 also. 3.4.40 -02/23/2025 Add option to configure to login as specific user on startup Emby for Android Release Notes - Android - Emby Community
Luke 42243 Posted April 2, 2025 Posted April 2, 2025 Hi, sorry I thought it was in the store. Anyway we’ll have it up soon. Thanks.
