soltia 0 Posted September 19, 2023 Posted September 19, 2023 Apologies if already reported. Using on android, am unable to use down on my remote to get to the plus and minus buttons to operate the offset option.
softworkz 5133 Posted September 23, 2023 Posted September 23, 2023 On 9/19/2023 at 9:06 AM, soltia said: Apologies if already reported. Using on android, am unable to use down on my remote to get to the plus and minus buttons to operate the offset option. I have created a new bug entry in the WMC UI repo: https://github.com/EmbySupport/Emby.WMC.UI/issues/17 Will look at it shortly. Thanks a lot for reporting!
Luke 42238 Posted May 9, 2024 Posted May 9, 2024 Subtitle offset is being changed to a slider which should make it much easier now, and you still have the buttons to step up/down: 1
