Luke 42289 Posted September 19, 2023 Posted September 19, 2023 OK, that has nothing to do with port forwarding. Where did you press wake?
Torondo87 0 Posted September 19, 2023 Author Posted September 19, 2023 I pressed wake from the TV program on Emby I did some tests to see if it worked but I couldn't wake up the pc
Luke 42289 Posted September 19, 2023 Posted September 19, 2023 And then what happens if you wake it manually?
Torondo87 0 Posted September 19, 2023 Author Posted September 19, 2023 well, it doesn't respond from my TV no solution?
Neminem 1630 Posted September 20, 2023 Posted September 20, 2023 Did you look at this. On 9/19/2023 at 5:38 AM, jaycedk said: wake on lan windows - Google-søgning wake on lan windows10 - Search (bing.com) If you want wake on lan. Then your server need to be configured to use that. And that can be different from motherboard to motherboard.
Torondo87 0 Posted September 20, 2023 Author Posted September 20, 2023 yes i know i Activate the Wake-on-LAN option today in my mobo,but it didn't work
Luke 42289 Posted September 23, 2023 Posted September 23, 2023 What Emby app are you using on the TV?
Luke 42289 Posted September 24, 2023 Posted September 24, 2023 26 minutes ago, Torondo87 said: the simple emby What version number?
