Torondo87 0 Posted September 17, 2023 Posted September 17, 2023 (edited) hi... I changed router today (i buy asus) and i still cant connect from my pc to to watch movies in my tv in a living room! if I connect my old router again,the connection is made normally Can you tell me the settings I need to make?because I don't remember at all Edited September 17, 2023 by Torondo87
Abobader 3491 Posted September 17, 2023 Posted September 17, 2023 Hello Torondo87, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
justinrh 270 Posted September 17, 2023 Posted September 17, 2023 You need to give some details, like client app, errors, etc. Are you connecting to the server with an IP address? Did the address change on the new router?
Torondo87 0 Posted September 17, 2023 Author Posted September 17, 2023 (edited) no i didn't change ip in my new router! a friend of mine has made the settings,when he had installed the emby program. I don't know what to do now Edited September 17, 2023 by Torondo87
Torondo87 0 Posted September 17, 2023 Author Posted September 17, 2023 from what I understand, I will have to change these here inside the router source ip which? port range 8096? local port 8096? and iocal ip is the ip from my pc?
pwhodges 2039 Posted September 17, 2023 Posted September 17, 2023 You are looking at port forwarding, which is required to access a network resource from outside the network. But presumably your TV and your PC are both connected to your internal network, so no router settings should be required. It is far more likely that either, or both, of your PC and TV have been allocated new addresses by the new router. So check what your PC's address really is now (in Windows type "ipconfig" at a command prompt and look at the line starting "IPv4 Address"), and check that your TV is connecting to that address. Paul 1
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 (edited) i find this k-local ipv6 adress... fe80:xxx etc 4 adress 192.168.xxx.etc net mask 255.255.xxx etc ault gateway 192.xxx.etc ipv4 is not recognized as an interntet or externalcommad I don't know what to do at all, I'll have to change the network settings from the TV?? Edited September 18, 2023 by Torondo87
pwhodges 2039 Posted September 18, 2023 Posted September 18, 2023 How are you connecting from the TV to the Emby server? Emby client or DLNA? In the client, you can tell it to change server and specify the new server using the IPv4 address that you saw on the PC. Paul
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 i think is emny clinet, can you show me an example how to change it?
pwhodges 2039 Posted September 18, 2023 Posted September 18, 2023 You should have a "head and shoulders" icon top right of the screen. Go to that and click it, which will open a menu. Click on "Change Server" in that menu, then choose the "Add Server" option and put the address in as indicated. Paul
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 all that I have to change? where should i go to what settings?
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 I changed from the TV and put a static ip, and I put the ip from the pc but still it didn't connect
pwhodges 2039 Posted September 18, 2023 Posted September 18, 2023 It might be worth checking whether your network is in "public" mode, instead of "private". Public restricts access and could be blocking the TV in this case. Paul
pwhodges 2039 Posted September 18, 2023 Posted September 18, 2023 If you have public, change it to private. Paul
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 (edited) oh my god it happened connected!! thank you so much! Do I also have to change any settings in my router in Enable Port Forwarding? Or do I not need to do anything? Edited September 18, 2023 by Torondo87
pwhodges 2039 Posted September 18, 2023 Posted September 18, 2023 You only touch the router if you want to access your server away from your network - from another house, or your phone, for instance. There are other things you need to do for that as well, though. Paul
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 (edited) and what are these things if I want to have access from someone else? and I also saw Emby can wake up a computer that is in sleep mode through the "Walk on Lan" feature, but only through the local netwo rk. what do i have to do to do this too? Edited September 18, 2023 by Torondo87
pwhodges 2039 Posted September 18, 2023 Posted September 18, 2023 There are settings in Emby you need to check; there's port-forwarding in the router. (If the router is set up to allow it, Emby can use uPNP to set up the forwarding; but enabling uPNP is inherently unsafe, in my opinion, so I recommend not using it.) If all you want is an HTTP connection using the IP address, that's it - but if you are also concerned about privacy or security, you might want to get a certificate and set up HTTPS - which also requires a domain name. Some people go further, with a reverse proxy (which actually can be the easiest way to get HTTPS), or a VPN connection - but those are strictly optional. I've never used Wake on Lan, so can't comment on it at present. Paul
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 (edited) I was just interested when the pc is in sleep mode and I'm sitting in the living room, and just press the wake and turn it on so I can see what I want on TV Edited September 18, 2023 by Torondo87
Luke 42289 Posted September 18, 2023 Posted September 18, 2023 1 hour ago, Torondo87 said: and what are these things if I want to have access from someone else? and I also saw Emby can wake up a computer that is in sleep mode through the "Walk on Lan" feature, but only through the local netwo rk. what do i have to do to do this too? Hi, please take a look at our guide and let us know if this helps: Remote Setup Thanks. 1
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 (edited) I made some changes from the quide in port forwrarding but it still doesn't wake up unfortunately Edited September 18, 2023 by Torondo87
Luke 42289 Posted September 18, 2023 Posted September 18, 2023 44 minutes ago, Torondo87 said: I made some changes from the quide in port forwrarding but it still doesn't wake up unfortunately What changes did you make? What exactly do you mean by "doesn't wake up" ?
Torondo87 0 Posted September 18, 2023 Author Posted September 18, 2023 port range 8096 and local port 8020 local ip for my pc I mean the pc was off and I went to the living room I turned on the TV I connected to emby I pressed wake and the pc didn't turn on
Neminem 1630 Posted September 19, 2023 Posted September 19, 2023 wake on lan windows - Google-søgning wake on lan windows10 - Search (bing.com)
