gswim 2 Posted September 17, 2023 Posted September 17, 2023 Will EMBY ever accept Xtreme codes? I have a 5 year IPTV subscription and come to find out they don't do M3U only Xtreme. I've gone through the process of converting the Xtreme to M3u http://vip.tvis.us:826/get.php?username=XXXXX&password=XXXXX&output=ts&type=m3u_plus but I get the following error in emby. "There was an error saving the TV provider. Please ensure it is accessible and try again." Inquired to my provider and they claim they only deal in Xtreme. Pretty sure I converted it correctly, but I can send the real info if it will help.
Spaceboy 2573 Posted September 17, 2023 Posted September 17, 2023 try the url in vlc as a network stream. if it doesnt play there, its not playing in emby. i believe the devs have said multiple times in other threads that they will not be supporting xstream codes
tuckjordan20 3 Posted September 20, 2023 Posted September 20, 2023 There are providers that disable m3u urls so converting using the usual method won't work. You could try running it through a proxy such as m3u4u or iptvboss as they will accept xtreme codes details and produce an m3u. 1 1
Luke 42241 Posted May 24, 2025 Posted May 24, 2025 3 minutes ago, samplay said: Please I need Xtream code acct how do I get one hi, please check out our quick start guide to learn how to setup your own emby server: Quick Start
