random0815 0 Posted September 17, 2023 Posted September 17, 2023 Hi, i try to enable the decoder for converting movies, but unfortunately, he does not use the GPU. >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Advanced Info Checking: 'CUVID NVIDIA GeForce RTX 2080 Ti - H.265 (HEVC)' NoMatch Codec does not support level 'Level 6.2' Info Decoder does not match Info Checking: 'NVDEC NVIDIA GeForce RTX 2080 Ti - H.265 (HEVC)' NoMatch Codec does not support level 'Level 6.2' Info Decoder does not match Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' Can somebody help me with this problem? Best regards, phil ffmpeg-transcode-122c24a0-5e64-4c42-9c9d-660adde73466_1.txt
Luke 42244 Posted September 18, 2023 Posted September 18, 2023 Hi, looks like your GPU does not support the hevc level of this file. Does that answer your question? It's still using hardware for the encoding, just not decoding.
random0815 0 Posted September 24, 2023 Author Posted September 24, 2023 On 9/18/2023 at 8:39 PM, Luke said: Hi, looks like your GPU does not support the hevc level of this file. Does that answer your question? It's still using hardware for the encoding, just not decoding. Good morning, ok thats strange. If i start manual the process, the gpu is allocated... /bin/ffmpeg -hwaccel cuda -hwaccel_output_format cuda -i test.mkv -c:v h264_nvenc -preset default test2.mp4 ffmpeg version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) Execution Date: 2023-09-24 07:24:07 [matroska,webm @ 0x708180] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [matroska,webm @ 0x708180] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options Input #0, matroska,webm, from 'test.mkv': Metadata: encoder : libebml v1.4.2 + libmatroska v1.6.3 creation_time : 2021-07-08T22:39:39.000000Z Version : V1.1 Duration: 00:23:21.93, start: 0.000000, bitrate: 7093 kb/s Stream #0:0(jpn): Video: hevc (Main), yuv420p(tv), 1920x1080, SAR 1:1 DAR 16:9, Level 186, 23.98 fps, 23.98 tbr, 1k tbn (default) Stream #0:1(ger): Audio: dts (DTS-HD MA), 48000 Hz, stereo, s16p (default) Stream #0:2(jpn): Audio: dts (DTS-HD MA), 48000 Hz, stereo, s16p Stream #0:3(ger): Subtitle: hdmv_pgs_subtitle (default) (forced) Stream #0:4(ger): Subtitle: hdmv_pgs_subtitle File 'test2.mp4' already exists. Overwrite? [y/N] y Stream mapping: Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_nvenc)) Stream #0:1 -> #0:1 (dts (dca) -> aac (native)) Press [q] to stop, [?] for help Output #0, mp4, to 'test2.mp4': Metadata: Version : V1.1 encoder : Lavf59.17.100 Stream #0:0(jpn): Video: h264 (Main) (avc1 / 0x31637661), cuda(tv, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 2000 kb/s, 23.98 fps, 24k tbn (default) Metadata: encoder : Lavc59.21.100 h264_nvenc Side data: cpb: bitrate max/min/avg: 0/0/2000000 buffer size: 4000000 vbv_delay: N/A Stream #0:1(ger): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: encoder : Lavc59.21.100 aac elapsed=00:01:40.86 frame=33612 fps=333 q=20.0 Lsize= 355607kB time=00:23:21.94 bitrate=2077.9kbits/s throttle=off speed=13.9x video:332242kB audio:22273kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.308031% Last message repeated 1 times EXIT [aac @ 0x72c780] Qavg: 1176.521 Can i change the emby command for ffmpeg ? best regards
Luke 42244 Posted September 28, 2023 Posted September 28, 2023 @random0815please attach the emby server and hardware detection log files as well. Thanks.
random0815 0 Posted September 29, 2023 Author Posted September 29, 2023 here we are @Luke:-) embyserver-63831542418.txt hardware_detection-63831542427.txt
softworkz 5133 Posted November 19, 2023 Posted November 19, 2023 Your media file is encoded incorrectly. It indicates HEVC level 6.1, which means that it would have a bitrate between 60Mbps and 120Mbps, but actually it has only 7Mbps. The purpose of codec levels is to ensure that or determine whether certain content is playable on a device when decoding, or when encoding, it is to encode a video in a way that it will be playable on a certain device. Emby uses codec levels exactly like this (the intended purpose) for choosing a suitable decoder. When a video provides incorrect data, then it needs to be expected that things aren't going as desired..
Luke 42244 Posted December 19, 2023 Posted December 19, 2023 @random0815has this answered your question and helped you resolve your issue?
