Samkook 18 Posted September 14, 2023 Posted September 14, 2023 Is there some place where the actual possible content of an emby metadata nfo is explained? I know it has been said before that emby uses the same thing as kodi for the metadata but that's not entirely accurate since things change over time and since I'm making custom nfo for some movies, I wanted to check if emby would work properly with what I'm doing. I know there was an issue a couple years back with emby not supporting a change in how kodi handles multi-episode files in tv shows so I'd like to know if there's something similar today. On 8/5/2021 at 1:52 PM, Happy2Play said: Not sure how Emby will parse this as it does not honor multi-episodes in a single nfo (kodi) style. Emby still uses the old style
GrimReaper 4845 Posted September 14, 2023 Posted September 14, 2023 Just now, Samkook said: I know there was an issue a couple years back with emby not supporting a change in how kodi handles multi-episode files in tv shows so I'd like to know if there's something similar today. That is still the case in respect to multi-episode NFOs. As is Emby having few of its own tags. Most of the others tags should be supported, though. Is they're any in particular you're concerned with?
Samkook 18 Posted September 14, 2023 Author Posted September 14, 2023 The <premiered> tag would pretty much be the only one I'm actually concerned with it potentially not supporting, but I mostly wanted to know if there was some place I could actually see what's the exact nfo format emby uses.
Solution GrimReaper 4845 Posted September 14, 2023 Solution Posted September 14, 2023 2 minutes ago, Samkook said: The <premiered> tag would pretty much be the only one I'm actually concerned with it potentially not supporting No issues with <premiered> tag for either Movies or TV Shows. 12 minutes ago, Samkook said: I mostly wanted to know if there was some place I could actually see what's the exact nfo format emby uses. Not that I know of. 1
Samkook 18 Posted September 14, 2023 Author Posted September 14, 2023 Alright, thanks for the info. I'll just hope for the best but sounds like everything should be fine. 1
