socbutter 5 Posted September 12, 2023 Posted September 12, 2023 UNRAID Version: 6.12.4, EMBY Version 4.7.14.0 Ran Lyrics Finder, now how I display the lyrics on my SHIELD?
Luke 42245 Posted September 12, 2023 Posted September 12, 2023 HI, do you see them in the Emby web app?
socbutter 5 Posted September 12, 2023 Author Posted September 12, 2023 (edited) Yes both the Emby web app and iOS app display the lyrics. When i play a song with lyrics on the SHIELd PRO there is no cog wheel or button on the screen that depicts the lyric symbol. Edited September 12, 2023 by socbutter 1
socbutter 5 Posted September 14, 2023 Author Posted September 14, 2023 Log files. embyserver-63830246400.txt embyserver.txt 1
socbutter 5 Posted September 18, 2023 Author Posted September 18, 2023 UNRAID Version: 6.12.4, EMBY Version 4.7.14.0 Ran Lyrics Finder, now how I display the lyrics on my NVIDIA SHIELD PRO? both the Emby web app and iOS app display the lyrics. When i play a song with lyrics on the SHIELD PRO there is no cog wheel or button on the screen that depicts the lyric symbol. embyserver-63830246400.txt embyserver.txt
Luke 42245 Posted September 18, 2023 Posted September 18, 2023 Hi, I've merged your topics. We will respond to your original inquiry. Thanks.
ebr 16337 Posted September 18, 2023 Posted September 18, 2023 Hi. For lyrics functionality, you will need to use the standard Android app. You can sideload it on your Shield if you wish but we hope to have it in the store soon. https://emby.media/emby-for-android.html Thanks.
arrbee99 1836 Posted September 18, 2023 Posted September 18, 2023 I hope its going to be an addition to the store and not a replacement for the good version. 1
socbutter 5 Posted September 19, 2023 Author Posted September 19, 2023 Thank you everyone. I'll wait for the Google Store to have the updated version. 1
