TheShanMan 41 Posted September 11, 2023 Posted September 11, 2023 Because, as far as I was aware way back when, Theater doesn't have a key that's mapped as a one-click sign out, I have a key mapped to kill and restart Theater instead. For years that has always logged the user out, but in the last several days, when I go to log back in after restart, I don't have to enter my pin code. The pin code is active, however. If I sign out from the user menu and try to log back in, I have to enter the pin code. So for whatever reason, the most recent version of Theater (or is it Server???) has stopped forcing re-entry of the pin I guess because there was no explicit sign out. I do not keep the "Remember Me" option checked so that's not a contributing factor here. I looked for an option to change this behavior but haven't found one. I don't know if this would be considered a bug, but there is a change in behavior that's very inconvenient for me. Could the behavior be changed back? Or is there a key I can map on my remote to sign the user out in a single click?
Luke 42237 Posted September 11, 2023 Posted September 11, 2023 Hi, thanks for reporting. We'll take a look. 1
