Bcoy15 5 Posted September 10, 2023 Posted September 10, 2023 Pretty new user here so you will have to bear with me. I was in the dashboard and saw that I had an update. I closed "Embyserver" and clicked the link to download the new version. I have an M1 Mac so I selected that software for 4.7.14.0 and downloaded the zip file. I opened the zip file and it installed "Embyserver 2" and was showing in my task bar. I went to search for Embyserver in my finder and renamed "Embyserver 2" to just "Embyserver" and deleted the original to try to tidy things up. I feel like this is where things may have went wrong because now when I go to open Embyserver it shows that it is running in my tasks, but it no longer shows on my task bar. I can get to my media but any time I try to play anything it just spins and spins. Thanks in advance!
Luke 42238 Posted September 11, 2023 Posted September 11, 2023 Hi, the macOS arm version doesn't have the task bar icon yet, but we are working on adding it. Is the Emby Server 2 thing all cleared up? I've not heard of that happening before.
