rbjtech 5345 Posted September 15, 2023 Posted September 15, 2023 2 minutes ago, beefsnack said: ok - and the 2nd line (that you have blanked) is your WAN IP correct ? If yes, then your ISP is not using CGNAT - so we can rule that out. 1
rbjtech 5345 Posted September 15, 2023 Posted September 15, 2023 (edited) ok - so lets check a few basic items. In Windows - check the server networking is 'Private' and not 'Public' (despite the logic, Public is a lot more restricted that 'Private' on the LAN) In a browser - type 'what's my ip' in Google Is that WAN IP, the same WAN IP that the emby Dashboard is showing ? If yes, on a canyouseeme.org port 8096, using the above IP - is the port open ? If yes, then it should connect... if not, then maybe @Carlo needs to do a remote session as everything 'looks' to be ok ... edit - if you're happy to - ping me your WAN IP via PM - and I'm happy to check access (don't need any credentials, I'm just checking IP connectivity). Edited September 15, 2023 by rbjtech
beefsnack 17 Posted September 15, 2023 Author Posted September 15, 2023 PVT, yes, closed i got no prob with that
beefsnack 17 Posted September 15, 2023 Author Posted September 15, 2023 @rbjtech your pm's are off chief.
beefsnack 17 Posted September 16, 2023 Author Posted September 16, 2023 I found it in case anyone wanted to know, and was stupid enough to change their port like me to test and couldn't get back in, here is the way to edit it back to get your Emby back up! C:\Users\(your system)\AppData\Roaming\Emby-Server\programdata\config\ >(system.xml)< 1
beefsnack 17 Posted September 16, 2023 Author Posted September 16, 2023 No solution, I asked earlier how to fix an issue I screwed up but no one answered it, so I figured it out myself, so I let ppl know in case they do the stupid idea I had and can't figured it out they'll have that solution
beefsnack 17 Posted September 16, 2023 Author Posted September 16, 2023 and damn if I can't get any of these ports open, I am coming up with these Stealth closed Ports in the router problems a lot though...
beefsnack 17 Posted September 16, 2023 Author Posted September 16, 2023 (edited) not to 8096 negative or 8920 and they are both set in FW too tcp/udp Edited September 16, 2023 by beefsnack
beefsnack 17 Posted September 16, 2023 Author Posted September 16, 2023 I'm about to just nuke emby and start all over again see it it'll just fix it, I might have no other choice, I've had a few ppl already in my system trying to figure this crap out, doing the same crap I've done and going over the same things I've already done 5x
beefsnack 17 Posted September 16, 2023 Author Posted September 16, 2023 Plex is not going through a proxy nor the local, I got 7 people right now remotely connected as we speak, through an open port which I've checked No idea why it's working and the others aren't
Luke 42288 Posted September 17, 2023 Posted September 17, 2023 3 hours ago, beefsnack said: Plex is not going through a proxy nor the local, I got 7 people right now remotely connected as we speak, through an open port which I've checked No idea why it's working and the others aren't Remember they have a relay feature that automatically kicks in when a direct connection isn't possible. That could be what's happening, where they route everything through their own servers.
beefsnack 17 Posted September 21, 2023 Author Posted September 21, 2023 Well Plex's port is open and plex is still working and nothing I do is letting me let Emby work remotely and I'm running out of options here, Besides Crushing this router into itty bitty pieces and letting the dogs piss on it...
Luke 42288 Posted September 21, 2023 Posted September 21, 2023 Have you tried shutting down plex and using its public router port for Emby? How do you know that plex is actually getting through and that it’s not their relay feature?
beefsnack 17 Posted September 21, 2023 Author Posted September 21, 2023 yup and it turns EMBY into PLEX been there done that, don't recommend that one at all.
Luke 42288 Posted September 21, 2023 Posted September 21, 2023 3 minutes ago, beefsnack said: yup and it turns EMBY into PLEX been there done that, don't recommend that one at all. Sorry what does that mean? It’s just a port number.
beefsnack 17 Posted September 21, 2023 Author Posted September 21, 2023 Because it shows the port open when I check it it's gotta be my router, I have gone through it a 100 times and done so many rules to let so many ports pass through it it's not funny, and through firewalls as well, Nothing is getting allowed I even shutdown all security and tried it Nothing is getting through this machine, Nothing past this router, I'm gonna need to replace this pile of dung! You might be right on the Plex but it's still showing the port open On plex why I have no clue The rule is in there I set it Myself I should know
beefsnack 17 Posted September 21, 2023 Author Posted September 21, 2023 Yea, when I used that port # and opened up emby Plex would open up not emby I shit you not, Maybe because I run both but IDK but that's what happens...
Luke 42288 Posted September 21, 2023 Posted September 21, 2023 That doesn’t mean they’re actually using it though. All you need to do is remove the port assignment for plex and add a new one for Emby using that port. Or if you don’t want to touch the router just shut down plex and change the local port in Emby server to match whatever the local port is for plex.
beefsnack 17 Posted September 21, 2023 Author Posted September 21, 2023 (edited) That's exactly what I did. and when I opened up Emby on my browser Plex opened up, (Could be because of the UPnP settings in the router) Because of the port change, I can't explain it anymore than that, Plex was shut down and only EMBY was running, Then I had to edit the .xml to be able to open EMBY back up again to get EMBY to work again. I can't edit the UPnP settings, that part I don't know how. (Locked) Edited September 21, 2023 by beefsnack
beefsnack 17 Posted September 21, 2023 Author Posted September 21, 2023 And another Fail attempt at Modem/router reboot as per Spectrum Techs which according to them say it must be done in a certain way which I've already done 10x, they even suggested it wasn't their problem they couldn't connect into ports 8069 through 8920 and saw all my proper port forwarding rules and were stuck as well, so it's either a ghost in the machine or I need an exorcism to open my damn ports! Next!
Solution beefsnack 17 Posted September 22, 2023 Author Solution Posted September 22, 2023 Issues is now closed and fixed, as It turns out it was a simple fix, Unbelievable but unaware that I was not even thinking of it and why we have People here to help. Thanks to @Carloand @Luke For all the Help and everyone else who chimed in with an assist. And for the Fix. Just a simple TCP tweak without the IP in port forwarding did it. 1
Carlo 4561 Posted September 22, 2023 Posted September 22, 2023 It turned out to be a simple port redirection issue that was forwarding unsecured to secured ports rather than unsecured to unsecured or put another way. Port forwarding needed to be changed to 8096->8096 vs 8096->8920. 1 2
