muppet4k 10 Posted September 8, 2023 Posted September 8, 2023 Hi any update to speed up the refreshing guide ? tskes to long also for a few channels thx
Luke 42242 Posted September 8, 2023 Posted September 8, 2023 HI there, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks.
muppet4k 10 Posted September 8, 2023 Author Posted September 8, 2023 It’s same problem that all have no log required for that you told nice 2 years too improve it come on
muppet4k 10 Posted September 8, 2023 Author Posted September 8, 2023 How is epg working getting epg data wen I have only a m3u file ?
Luke 42242 Posted September 8, 2023 Posted September 8, 2023 Just now, muppet4k said: How is epg working getting epg data wen I have only a m3u file ? There's no epg data unless you add a guide data source.
muppet4k 10 Posted September 8, 2023 Author Posted September 8, 2023 But how does other apps working I downloaded a m3u app from Apple Store and alsp enter only the m3u list and I will get epg automatically
muppet4k 10 Posted September 8, 2023 Author Posted September 8, 2023 @Luke how are these apps working also only within a m3u list and now xml and also get epg data
Luke 42242 Posted September 8, 2023 Posted September 8, 2023 36 minutes ago, muppet4k said: But how does other apps working I downloaded a m3u app from Apple Store and alsp enter only the m3u list and I will get epg automatically The m3u list might have an epg url embedded. Can you check? we don’t support this yet but it’s on our to do list.
muppet4k 10 Posted September 8, 2023 Author Posted September 8, 2023 I will check it it would be good and more easy and comfortable to get this feature soon
muppet4k 10 Posted September 8, 2023 Author Posted September 8, 2023 I think many people like to have it so many have problems with that xml lets vote in the community?
Luke 42242 Posted September 8, 2023 Posted September 8, 2023 Hi, yes we plan to support it, but in the meantime you could grab the xml url from the m3u and just add that as a guide data source. That’s assuming it’s one url for the whole list. Sometimes there’s a different one for each channel.
